Home » Eclipse Projects » Kura » Issue with kura installation on Raspberry Pi 2(Issue with kura installation on Raspberry Pi 2)
Issue with kura installation on Raspberry Pi 2 [message #1785871] |
Sat, 21 April 2018 10:55  |
Hi im new to kura, i have installed kura on raspberry pi B+ and i can access it in local web ui. but B+ is too slow so i thought of installing it in Pi 2 but i cant access kura in local web ui. it shows no internet connection.
the package that i installed on Pi 2 is Raspbian (Model 2 or 3) - Stable
Raspberry pi 2 have two versions one with ARMv7 (32 bit) and ARMv8 (64 bit), the one i have is 32 bit.... i tried installing Raspbian - Stable version also but the same problem on that too..
Re: Issue with kura installation on Raspberry Pi 2 [message #1785949 is a reply to message #1785918] |
Mon, 23 April 2018 10:28   |
pi@raspberrypi:~ $ tail -f /var/log/kura.log
2018-04-21 13:18:07,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:18:07,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:12,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:18:12,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:17,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:18:17,574 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:22,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:18:22,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:27,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:18:27,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
Re: Issue with kura installation on Raspberry Pi 2 [message #1785950 is a reply to message #1785949] |
Mon, 23 April 2018 10:32   |
KURA.log
2018-04-21 13:10:45,323 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:10:45,370 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:10:46,385 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:10:49,203 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:10:49,207 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:10:49,208 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:10:49,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:10:49,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:10:49,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura home directory is /opt/eclipse/kura/kura
2018-04-21 13:10:49,213 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura snapshots directory is /opt/eclipse/kura/data/snapshots
2018-04-21 13:10:49,214 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura tmp directory is /tmp/.kura
2018-04-21 13:10:49,215 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version KURA_3.2.0 is starting
2018-04-21 13:10:49,280 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - activate...
2018-04-21 13:10:49,281 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - Opening database with url: jdbc:hsqldb:mem:kuradb
2018-04-21 13:10:51,980 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CertificatesManager - Bundle org.eclipse.kura.core.certificates.CertificatesManager has started!
2018-04-21 13:10:52,129 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - activate...
2018-04-21 13:10:52,145 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:10:52,837 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Unable to decrypt snapshot! Fallback to unencrypted snapshots mode.
2018-04-21 13:10:53,976 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Writing snapshot - Saving /opt/eclipse/kura/data/snapshots/snapshot_0.xml...
2018-04-21 13:10:54,396 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Writing snapshot - Saving /opt/eclipse/kura/data/snapshots/snapshot_0.xml... Done.
2018-04-21 13:10:54,400 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:10:55,073 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.db.H2DbService and factory pid: org.eclipse.kura.core.db.H2DbService
2018-04-21 13:10:55,075 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.db.H2DbService and pid org.eclipse.kura.db.H2DbService
2018-04-21 13:10:55,076 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.db.H2DbService
2018-04-21 13:10:55,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....
2018-04-21 13:10:55,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....Done
2018-04-21 13:10:55,162 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and factory pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,163 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,164 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,208 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....
2018-04-21 13:10:55,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....Done
2018-04-21 13:10:55,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.data.DataService and factory pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:55,210 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.data.DataService and pid org.eclipse.kura.data.DataService
2018-04-21 13:10:55,211 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.data.DataService
2018-04-21 13:10:55,239 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....
2018-04-21 13:10:55,240 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....Done
2018-04-21 13:10:55,263 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.cloud.CloudService and factory pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,264 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.cloud.CloudService and pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,265 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,287 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....
2018-04-21 13:10:55,287 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....Done
2018-04-21 13:10:55,329 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Trackers being opened...
2018-04-21 13:10:55,329 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Only tracking relevant services
2018-04-21 13:10:56,087 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport ...
2018-04-21 13:10:56,111 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:56,138 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:56,139 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbService ...
2018-04-21 13:10:56,181 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.db.H2DbService
2018-04-21 13:10:56,182 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.data.DataService ...
2018-04-21 13:10:56,186 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:56,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:56,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbServer ...
2018-04-21 13:10:56,213 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.ssl.SslManagerService ...
2018-04-21 13:10:56,216 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:10:56,248 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:10:56,387 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.CloudService ...
2018-04-21 13:10:56,389 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:56,441 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:56,442 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.app.command.CommandCloudApp ...
2018-04-21 13:10:56,442 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:10:56,473 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:10:56,578 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...
2018-04-21 13:10:56,580 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - Default H2DbService instance configuration found
2018-04-21 13:10:56,580 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...done
2018-04-21 13:10:56,702 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 ...
2018-04-21 13:10:56,704 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:10:56,743 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:10:56,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.watchdog.WatchdogService ...
2018-04-21 13:10:56,771 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:10:56,820 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:10:56,878 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....
2018-04-21 13:10:56,878 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....Done
2018-04-21 13:10:56,915 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...
2018-04-21 13:10:56,915 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:10:56,925 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - Opening database with url: jdbc:h2:mem:kuradb
2018-04-21 13:11:00,587 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:11:00,588 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...done
2018-04-21 13:11:00,674 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.clock.ClockService ...
2018-04-21 13:11:00,677 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:11:00,720 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:11:00,774 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Activate. Current Time: Sat Apr 21 13:11:00 UTC 2018
2018-04-21 13:11:00,787 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:11:00,804 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:11:00,818 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....
2018-04-21 13:11:00,820 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....Done
2018-04-21 13:11:00,957 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:00,997 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.position.PositionService ...
2018-04-21 13:11:00,998 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:11:01,061 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:11:01,134 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:11:01,135 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Activating... Done.
2018-04-21 13:11:01,147 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....
2018-04-21 13:11:01,147 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....Done
2018-04-21 13:11:01,279 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - activate...
2018-04-21 13:11:01,322 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....
2018-04-21 13:11:01,323 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....Done
2018-04-21 13:11:01,362 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:11:01,364 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:11:01,397 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - updated...
2018-04-21 13:11:01,529 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Updated...
2018-04-21 13:11:01,531 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:11:01,533 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:11:01,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:01,547 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:11:01,581 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2018-04-21 13:11:01,638 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.BluetoothLeServiceImpl - Activating Bluetooth Le Service...
2018-04-21 13:11:06,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (1)
2018-04-21 13:11:06,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:11,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (2)
2018-04-21 13:11:11,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:16,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (3)
2018-04-21 13:11:16,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:21,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (4)
2018-04-21 13:11:21,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:26,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (5)
2018-04-21 13:11:26,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:31,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:11:31,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:36,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:11:36,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:41,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:11:41,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:46,533 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:11:46,538 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:51,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:11:51,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:56,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (11)
2018-04-21 13:11:56,536 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:01,078 [Component Resolve Thread (Bundle 7)] ERROR o.e.k.i.b.BluetoothLeServiceImpl - Failed to start bluetooth service
java.lang.RuntimeException: Error getting object manager client: Error calling StartServiceByName for org.bluez: GDBus.Error:org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out
at tinyb.BluetoothManager.getNativeAPIVersion(Native Method)
at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:217)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.activate(BluetoothLeServiceImpl.java:38)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
2018-04-21 13:12:01,141 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.b.BluetoothLeBeaconManagerImpl - Activating Bluetooth Le Beacon Manager...
2018-04-21 13:12:01,204 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.i.BluetoothLeIBeaconServiceImpl - Activating Bluetooth Le IBeacon Service...
2018-04-21 13:12:01,254 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.e.BluetoothLeEddystoneServiceImpl - Activating Bluetooth Le Eddystone Service...
2018-04-21 13:12:01,342 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.internal.rest.provider.RestService ...
2018-04-21 13:12:01,347 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
2018-04-21 13:12:01,379 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
2018-04-21 13:12:01,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (12)
2018-04-21 13:12:01,533 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:02,497 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - activating...
2018-04-21 13:12:02,499 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - updating...
2018-04-21 13:12:02,600 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - updating...done
2018-04-21 13:12:02,601 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - activating...done
2018-04-21 13:12:02,607 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....
2018-04-21 13:12:02,608 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....Done
2018-04-21 13:12:02,776 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance ...
2018-04-21 13:12:02,777 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
2018-04-21 13:12:02,793 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
2018-04-21 13:12:02,837 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....
2018-04-21 13:12:02,838 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....Done
2018-04-21 13:12:02,860 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance ...
2018-04-21 13:12:02,861 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
2018-04-21 13:12:02,876 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
2018-04-21 13:12:02,907 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....
2018-04-21 13:12:02,908 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....Done
2018-04-21 13:12:02,947 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.h.DeploymentHookManager - Hook registered: FileMoveHook
2018-04-21 13:12:03,057 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordStore ...
2018-04-21 13:12:03,058 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordFilter ...
2018-04-21 13:12:03,282 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.CloudSubscriber ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.RegexFilter ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Logger ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordFilter ...
2018-04-21 13:12:03,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Fifo ...
2018-04-21 13:12:03,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Timer ...
2018-04-21 13:12:03,285 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.CloudPublisher ...
2018-04-21 13:12:03,285 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordStore ...
2018-04-21 13:12:03,490 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.WireService ...
2018-04-21 13:12:03,490 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.wire.WireService
2018-04-21 13:12:03,510 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.wire.WireService
2018-04-21 13:12:03,560 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Activating Wire Service...
2018-04-21 13:12:03,561 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Updating Wire Service Component...
2018-04-21 13:12:03,600 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Opening Wire Component Service tracker...
2018-04-21 13:12:03,603 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Opening Wire Component Service tracker...done
2018-04-21 13:12:03,604 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Updating Wire Service Component...Done
2018-04-21 13:12:03,604 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Activating Wire Service...Done
2018-04-21 13:12:03,615 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.wire.WireService....
2018-04-21 13:12:03,616 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.wire.WireService....Done
2018-04-21 13:12:03,640 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.misc.cloudcat.CloudCat ...
2018-04-21 13:12:03,770 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.u.log - Logging initialized @97400ms to org.eclipse.jetty.util.log.Slf4jLog
2018-04-21 13:12:04,620 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.Server - jetty-9.4.7.v20170914
2018-04-21 13:12:04,759 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - DefaultSessionIdManager workerName=node0
2018-04-21 13:12:04,760 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - No SessionScavenger set, using defaults
2018-04-21 13:12:04,771 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - Scavenging every 600000ms
2018-04-21 13:12:05,381 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.h.ContextHandler - Started o.e.j.s.ServletContextHandler@4b237d{/,null,AVAILABLE}
2018-04-21 13:12:06,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (13)
2018-04-21 13:12:06,533 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:07,972 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.AbstractConnector - Started ServerConnector@78d170{HTTP/1.1,[http/1.1]}{0.0.0.0:80}
2018-04-21 13:12:07,978 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.Server - Started @101607ms
2018-04-21 13:12:08,183 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.camel.cloud.factory.CamelFactory ...
2018-04-21 13:12:08,248 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.camel.xml.XmlRouterComponent ...
2018-04-21 13:12:08,250 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
2018-04-21 13:12:08,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
2018-04-21 13:12:08,357 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.AbstractCamelComponent - Starting camel router
2018-04-21 13:12:08,407 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Starting...
2018-04-21 13:12:08,408 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Stopping...
2018-04-21 13:12:08,432 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Setting routes...
2018-04-21 13:12:08,449 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....
2018-04-21 13:12:08,450 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....Done
2018-04-21 13:12:08,477 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Conditional ...
2018-04-21 13:12:08,524 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Join ...
2018-04-21 13:12:08,789 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.g.GPIOServiceImpl - Loaded File jdk.dio.properties: /opt/eclipse/kura/kura/jdk.dio.properties
2018-04-21 13:12:08,818 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.CloudConnectionStatusServiceImpl - Activating CloudConnectionStatus service...
2018-04-21 13:12:08,831 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-04-21 13:12:08,877 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.t.m.MqttDataTransport - Activating org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport...
2018-04-21 13:12:09,175 [Component Resolve Thread (Bundle 7)] WARN o.e.k.l.n.w.WifiOptions - Failed to execute iwconfig eth0
2018-04-21 13:12:09,404 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Activating org.eclipse.kura.data.DataService...
2018-04-21 13:12:09,408 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Get Throttle with burst length 1 and send a message every 1000 millis
2018-04-21 13:12:09,416 [DataServiceImpl:Submit] INFO o.e.k.c.d.DataServiceImpl - DataPublisherService not connected
2018-04-21 13:12:09,437 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - H2DbService instance found
2018-04-21 13:12:10,054 [DataServiceImpl:Submit] INFO o.e.k.c.d.DataServiceImpl - DataPublisherService not connected
2018-04-21 13:12:10,086 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.c.CloudCallServiceImpl - Activating...
2018-04-21 13:12:10,132 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CloudServiceImpl - activate org.eclipse.kura.cloud.CloudService...
2018-04-21 13:12:10,149 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for CONF-V1...
2018-04-21 13:12:10,177 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.a.c.CommandCloudApp - Cloudlet CMD-V1 has started with config!
2018-04-21 13:12:10,178 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for CMD-V1...
2018-04-21 13:12:10,179 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.a.c.CommandCloudApp - updated...: org.eclipse.equinox.internal.ds.impl.ReadOnlyDictionary@18eb3a9
2018-04-21 13:12:10,185 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....
2018-04-21 13:12:10,186 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....Done
2018-04-21 13:12:10,224 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.CloudDeploymentHandlerV2 - Cloud Deployment v2 is starting
2018-04-21 13:12:10,225 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for DEPLOY-V2...
2018-04-21 13:12:10,245 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.i.InstallImpl - Ready to send Confirmations
2018-04-21 13:12:10,252 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....
2018-04-21 13:12:10,253 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....Done
2018-04-21 13:12:10,281 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for ASSET-V1...
2018-04-21 13:12:10,955 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask started.
2018-04-21 13:12:10,956 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask: Delete confirmed messages...
2018-04-21 13:12:11,059 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask ended.
2018-04-21 13:12:11,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (14)
2018-04-21 13:12:11,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:14,725 [Component Resolve Thread (Bundle 7)] INFO o.a.c.c.o.OsgiDefaultCamelContext - Apache Camel 2.17.2 (CamelContext: camel-1) is starting
2018-04-21 13:12:14,736 [Component Resolve Thread (Bundle 7)] INFO o.a.c.m.ManagedManagementStrategy - JMX is enabled
2018-04-21 13:12:37,919 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:12:37,967 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:12:38,903 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:12:41,942 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:12:41,946 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:12:41,947 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:12:41,948 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:12:41,949 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:12:41,951 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura home directory is /opt/eclipse/kura/kura
2018-04-21 13:12:41,952 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura snapshots directory is /opt/eclipse/kura/data/snapshots
2018-04-21 13:12:41,954 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura tmp directory is /tmp/.kura
2018-04-21 13:12:41,955 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version KURA_3.2.0 is starting
2018-04-21 13:12:42,026 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - activate...
2018-04-21 13:12:42,028 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - Opening database with url: jdbc:hsqldb:mem:kuradb
2018-04-21 13:12:44,421 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CertificatesManager - Bundle org.eclipse.kura.core.certificates.CertificatesManager has started!
2018-04-21 13:12:44,547 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - activate...
2018-04-21 13:12:44,556 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:12:45,629 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.db.H2DbService and factory pid: org.eclipse.kura.core.db.H2DbService
2018-04-21 13:12:45,631 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.db.H2DbService and pid org.eclipse.kura.db.H2DbService
2018-04-21 13:12:45,632 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.db.H2DbService
2018-04-21 13:12:45,655 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....
2018-04-21 13:12:45,655 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....Done
2018-04-21 13:12:45,672 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and factory pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,673 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,673 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,692 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....
2018-04-21 13:12:45,693 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....Done
2018-04-21 13:12:45,694 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.data.DataService and factory pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:45,695 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.data.DataService and pid org.eclipse.kura.data.DataService
2018-04-21 13:12:45,695 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.data.DataService
2018-04-21 13:12:45,715 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....
2018-04-21 13:12:45,716 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....Done
2018-04-21 13:12:45,731 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.cloud.CloudService and factory pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,732 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.cloud.CloudService and pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,733 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,749 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....
2018-04-21 13:12:45,750 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....Done
2018-04-21 13:12:45,767 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Trackers being opened...
2018-04-21 13:12:45,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Only tracking relevant services
2018-04-21 13:12:46,344 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport ...
2018-04-21 13:12:46,362 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:46,382 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:46,383 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbService ...
2018-04-21 13:12:46,400 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.db.H2DbService
2018-04-21 13:12:46,401 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.data.DataService ...
2018-04-21 13:12:46,404 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:46,426 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:46,427 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbServer ...
2018-04-21 13:12:46,428 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.ssl.SslManagerService ...
2018-04-21 13:12:46,430 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:12:46,448 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:12:46,563 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.CloudService ...
2018-04-21 13:12:46,565 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:46,994 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:46,995 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.app.command.CommandCloudApp ...
2018-04-21 13:12:46,996 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:12:47,021 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:12:47,130 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...
2018-04-21 13:12:47,132 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - Default H2DbService instance configuration found
2018-04-21 13:12:47,133 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...done
2018-04-21 13:12:47,218 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 ...
2018-04-21 13:12:47,220 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:12:47,243 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:12:47,264 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.watchdog.WatchdogService ...
2018-04-21 13:12:47,266 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:12:47,283 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:12:47,320 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....
2018-04-21 13:12:47,321 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....Done
2018-04-21 13:12:47,349 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...
2018-04-21 13:12:47,350 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:12:47,357 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - Opening database with url: jdbc:h2:mem:kuradb
2018-04-21 13:12:48,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:12:48,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...done
2018-04-21 13:12:48,272 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.clock.ClockService ...
2018-04-21 13:12:48,274 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:12:48,565 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:12:48,598 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Activate. Current Time: Sat Apr 21 13:12:48 UTC 2018
2018-04-21 13:12:48,606 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:12:48,612 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:12:48,617 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....
2018-04-21 13:12:48,618 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....Done
2018-04-21 13:12:48,685 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:48,723 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.position.PositionService ...
2018-04-21 13:12:48,726 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:12:48,751 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:12:48,794 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:12:48,797 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Activating... Done.
2018-04-21 13:12:48,803 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....
2018-04-21 13:12:48,804 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....Done
2018-04-21 13:12:48,871 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - activate...
2018-04-21 13:12:48,893 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....
2018-04-21 13:12:48,894 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....Done
2018-04-21 13:12:48,916 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:12:48,919 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:12:48,950 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - updated...
2018-04-21 13:12:49,067 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Updated...
2018-04-21 13:12:49,069 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:12:49,072 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:12:49,073 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:49,087 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:12:49,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2018-04-21 13:12:49,171 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.BluetoothLeServiceImpl - Activating Bluetooth Le Service...
2018-04-21 13:12:54,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (1)
2018-04-21 13:12:54,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:59,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (2)
2018-04-21 13:12:59,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:04,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (3)
2018-04-21 13:13:04,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:09,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (4)
2018-04-21 13:13:09,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:14,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (5)
2018-04-21 13:13:14,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:19,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:13:19,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:24,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:13:24,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:29,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:13:29,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:34,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:13:34,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:39,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:13:39,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:44,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (11)
2018-04-21 13:13:44,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:17:20,309 [Start Level: Equinox Container: 40276c4b-6645-0018-1800-af06638bea56] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:17:20,356 [Start Level: Equinox Container: 40276c4b-6645-0018-1800-af06638bea56] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:17:21,697 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:17:24,320 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:17:24,323 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:17:24,324 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:17:24,325 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:17:24,326 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:17:24,328 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura h
Re: Issue with kura installation on Raspberry Pi 2 [message #1785952 is a reply to message #1785951] |
Mon, 23 April 2018 10:33   |
Kura-Console.log
Kura Started (pid=348) ...
!SESSION 2018-04-21 12:52:33.464 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_162
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_GB
Command-line arguments: -configuration /tmp/.kura/configuration -console 5002 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:53:09.861
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.configuration.CloudConfigurationHandler. The reference is: Reference[name = CloudService, interface = org.eclipse.kura.cloud.CloudService, policy = dynamic, cardinality = 0..1, target = (kura.service.pid=org.eclipse.kura.cloud.CloudService), bind = setCloudService, unbind = unsetCloudService]
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:53:12.628
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.deployment.hook.DeploymentHookManager. The reference is: Reference[name = DeploymentHook, interface = org.eclipse.kura.deployment.hook.DeploymentHook, policy = dynamic, cardinality = 0..n, target = null, bind = bindHook, unbind = unbindHook]
(process:348): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
terminate called after throwing an instance of 'tinyb::BluetoothException'
what(): No adapter installed or not recognized by system
Kura Started (pid=339) ...
!SESSION 2018-04-21 12:57:25.343 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:57:57.180
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:58:01.202
(process:339): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=319) ...
!SESSION 2018-04-21 13:04:58.544 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:05:22.952
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:05:24.667
(process:319): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=304) ...
!SESSION 2018-04-21 13:10:32.037 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:10:56.648
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:11:01.495
!SESSION 2018-04-21 13:12:23.077 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:12:47.180
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:12:49.031
Kura Started (pid=305) ...
!SESSION 2018-04-21 13:17:08.188 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:30.718
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:32.265
!ENTRY org.eclipse.equinox.ds 2 0 2018-04-21 13:18:32.431
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@1eec833; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2018-04-21 13:18:32.605
!MESSAGE [SCR] Enabling components of bundle org.eclipse.kura.ble.provider did not complete in 60000 ms
(process:305): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=282) ...
!SESSION 2018-04-21 13:17:09.163 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:32.002
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:33.548
Kura Started (pid=351) ...
!SESSION 2018-04-21 13:17:08.793 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:33.448
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:37.532
(process:351): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Current Time: Mon Jul 21 07:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.05741 seconds
