Home » Eclipse Projects » Kura » Issue with kura installation on Raspberry Pi 2(Issue with kura installation on Raspberry Pi 2)
Issue with kura installation on Raspberry Pi 2 [message #1785871] Sat, 21 April 2018 10:55 Go to next message
Hi im new to kura, i have installed kura on raspberry pi B+ and i can access it in local web ui. but B+ is too slow so i thought of installing it in Pi 2 but i cant access kura in local web ui. it shows no internet connection.
the package that i installed on Pi 2 is Raspbian (Model 2 or 3) - Stable
Raspberry pi 2 have two versions one with ARMv7 (32 bit) and ARMv8 (64 bit), the one i have is 32 bit.... i tried installing Raspbian - Stable version also but the same problem on that too..
Re: Issue with kura installation on Raspberry Pi 2 [message #1785918 is a reply to message #1785871] Mon, 23 April 2018 03:18 Go to previous messageGo to next message
it should be working on raspberry pi 2.
Do you have ssh access? Could you please report what in the log files kura-console.log and kura.log in /var/log?
Matteo
Re: Issue with kura installation on Raspberry Pi 2 [message #1785949 is a reply to message #1785918] Mon, 23 April 2018 10:28 Go to previous messageGo to next message
pi@raspberrypi:~ $ tail -f /var/log/kura.log
2018-04-21 13:18:07,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:18:07,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:12,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:18:12,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:17,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:18:17,574 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:22,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:18:22,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:18:27,570 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:18:27,572 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
Re: Issue with kura installation on Raspberry Pi 2 [message #1785950 is a reply to message #1785949] Mon, 23 April 2018 10:32 Go to previous messageGo to next message
KURA.log
2018-04-21 13:10:45,323 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:10:45,370 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:10:46,385 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:10:49,203 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:10:49,207 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:10:49,208 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:10:49,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:10:49,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:10:49,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura home directory is /opt/eclipse/kura/kura
2018-04-21 13:10:49,213 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura snapshots directory is /opt/eclipse/kura/data/snapshots
2018-04-21 13:10:49,214 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura tmp directory is /tmp/.kura
2018-04-21 13:10:49,215 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version KURA_3.2.0 is starting
2018-04-21 13:10:49,280 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - activate...
2018-04-21 13:10:49,281 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - Opening database with url: jdbc:hsqldb:mem:kuradb
2018-04-21 13:10:51,980 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CertificatesManager - Bundle org.eclipse.kura.core.certificates.CertificatesManager has started!
2018-04-21 13:10:52,129 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - activate...
2018-04-21 13:10:52,145 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:10:52,837 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Unable to decrypt snapshot! Fallback to unencrypted snapshots mode.
2018-04-21 13:10:53,976 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Writing snapshot - Saving /opt/eclipse/kura/data/snapshots/snapshot_0.xml...
2018-04-21 13:10:54,396 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Writing snapshot - Saving /opt/eclipse/kura/data/snapshots/snapshot_0.xml... Done.
2018-04-21 13:10:54,400 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:10:55,073 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.db.H2DbService and factory pid: org.eclipse.kura.core.db.H2DbService
2018-04-21 13:10:55,075 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.db.H2DbService and pid org.eclipse.kura.db.H2DbService
2018-04-21 13:10:55,076 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.db.H2DbService
2018-04-21 13:10:55,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....
2018-04-21 13:10:55,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....Done
2018-04-21 13:10:55,162 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and factory pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,163 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,164 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:55,208 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....
2018-04-21 13:10:55,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....Done
2018-04-21 13:10:55,209 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.data.DataService and factory pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:55,210 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.data.DataService and pid org.eclipse.kura.data.DataService
2018-04-21 13:10:55,211 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.data.DataService
2018-04-21 13:10:55,239 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....
2018-04-21 13:10:55,240 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....Done
2018-04-21 13:10:55,263 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.cloud.CloudService and factory pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,264 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.cloud.CloudService and pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,265 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:55,287 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....
2018-04-21 13:10:55,287 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....Done
2018-04-21 13:10:55,329 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Trackers being opened...
2018-04-21 13:10:55,329 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Only tracking relevant services
2018-04-21 13:10:56,087 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport ...
2018-04-21 13:10:56,111 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:56,138 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:10:56,139 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbService ...
2018-04-21 13:10:56,181 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.db.H2DbService
2018-04-21 13:10:56,182 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.data.DataService ...
2018-04-21 13:10:56,186 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:56,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:10:56,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbServer ...
2018-04-21 13:10:56,213 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.ssl.SslManagerService ...
2018-04-21 13:10:56,216 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:10:56,248 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:10:56,387 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.CloudService ...
2018-04-21 13:10:56,389 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:56,441 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:10:56,442 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.app.command.CommandCloudApp ...
2018-04-21 13:10:56,442 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:10:56,473 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:10:56,578 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...
2018-04-21 13:10:56,580 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - Default H2DbService instance configuration found
2018-04-21 13:10:56,580 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...done
2018-04-21 13:10:56,702 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 ...
2018-04-21 13:10:56,704 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:10:56,743 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:10:56,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.watchdog.WatchdogService ...
2018-04-21 13:10:56,771 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:10:56,820 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:10:56,878 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....
2018-04-21 13:10:56,878 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....Done
2018-04-21 13:10:56,915 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...
2018-04-21 13:10:56,915 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:10:56,925 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - Opening database with url: jdbc:h2:mem:kuradb
2018-04-21 13:11:00,587 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:11:00,588 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...done
2018-04-21 13:11:00,674 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.clock.ClockService ...
2018-04-21 13:11:00,677 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:11:00,720 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:11:00,774 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Activate. Current Time: Sat Apr 21 13:11:00 UTC 2018
2018-04-21 13:11:00,787 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:11:00,804 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:11:00,818 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....
2018-04-21 13:11:00,820 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....Done
2018-04-21 13:11:00,957 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:00,997 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.position.PositionService ...
2018-04-21 13:11:00,998 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:11:01,061 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:11:01,134 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:11:01,135 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Activating... Done.
2018-04-21 13:11:01,147 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....
2018-04-21 13:11:01,147 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....Done
2018-04-21 13:11:01,279 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - activate...
2018-04-21 13:11:01,322 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....
2018-04-21 13:11:01,323 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....Done
2018-04-21 13:11:01,362 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:11:01,364 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:11:01,397 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - updated...
2018-04-21 13:11:01,529 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Updated...
2018-04-21 13:11:01,531 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:11:01,533 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:11:01,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:01,547 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:11:01,581 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2018-04-21 13:11:01,638 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.BluetoothLeServiceImpl - Activating Bluetooth Le Service...
2018-04-21 13:11:06,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (1)
2018-04-21 13:11:06,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:11,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (2)
2018-04-21 13:11:11,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:16,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (3)
2018-04-21 13:11:16,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:21,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (4)
2018-04-21 13:11:21,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:26,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (5)
2018-04-21 13:11:26,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:31,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:11:31,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:36,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:11:36,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:41,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:11:41,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:46,533 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:11:46,538 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:51,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:11:51,534 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:11:56,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (11)
2018-04-21 13:11:56,536 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:01,078 [Component Resolve Thread (Bundle 7)] ERROR o.e.k.i.b.BluetoothLeServiceImpl - Failed to start bluetooth service
java.lang.RuntimeException: Error getting object manager client: Error calling StartServiceByName for org.bluez: GDBus.Error:org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out
at tinyb.BluetoothManager.getNativeAPIVersion(Native Method)
at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:217)
at org.eclipse.kura.internal.ble.BluetoothLeServiceImpl.activate(BluetoothLeServiceImpl.java:38)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
2018-04-21 13:12:01,141 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.b.BluetoothLeBeaconManagerImpl - Activating Bluetooth Le Beacon Manager...
2018-04-21 13:12:01,204 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.i.BluetoothLeIBeaconServiceImpl - Activating Bluetooth Le IBeacon Service...
2018-04-21 13:12:01,254 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.e.BluetoothLeEddystoneServiceImpl - Activating Bluetooth Le Eddystone Service...
2018-04-21 13:12:01,342 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.internal.rest.provider.RestService ...
2018-04-21 13:12:01,347 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
2018-04-21 13:12:01,379 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.internal.rest.provider.RestService
2018-04-21 13:12:01,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (12)
2018-04-21 13:12:01,533 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:02,497 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - activating...
2018-04-21 13:12:02,499 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - updating...
2018-04-21 13:12:02,600 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - updating...done
2018-04-21 13:12:02,601 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.r.p.RestService - activating...done
2018-04-21 13:12:02,607 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....
2018-04-21 13:12:02,608 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.internal.rest.provider.RestService....Done
2018-04-21 13:12:02,776 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance ...
2018-04-21 13:12:02,777 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
2018-04-21 13:12:02,793 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance
2018-04-21 13:12:02,837 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....
2018-04-21 13:12:02,838 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.simple.mqtt.BrokerInstance....Done
2018-04-21 13:12:02,860 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance ...
2018-04-21 13:12:02,861 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
2018-04-21 13:12:02,876 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.broker.artemis.xml.BrokerInstance
2018-04-21 13:12:02,907 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....
2018-04-21 13:12:02,908 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.broker.artemis.xml.BrokerInstance....Done
2018-04-21 13:12:02,947 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.h.DeploymentHookManager - Hook registered: FileMoveHook
2018-04-21 13:12:03,057 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordStore ...
2018-04-21 13:12:03,058 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.H2DbWireRecordFilter ...
2018-04-21 13:12:03,282 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.CloudSubscriber ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.RegexFilter ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Logger ...
2018-04-21 13:12:03,283 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordFilter ...
2018-04-21 13:12:03,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Fifo ...
2018-04-21 13:12:03,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Timer ...
2018-04-21 13:12:03,285 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.CloudPublisher ...
2018-04-21 13:12:03,285 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.DbWireRecordStore ...
2018-04-21 13:12:03,490 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.WireService ...
2018-04-21 13:12:03,490 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.wire.WireService
2018-04-21 13:12:03,510 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.wire.WireService
2018-04-21 13:12:03,560 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Activating Wire Service...
2018-04-21 13:12:03,561 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Updating Wire Service Component...
2018-04-21 13:12:03,600 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Opening Wire Component Service tracker...
2018-04-21 13:12:03,603 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Opening Wire Component Service tracker...done
2018-04-21 13:12:03,604 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Updating Wire Service Component...Done
2018-04-21 13:12:03,604 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.w.WireServiceImpl - Activating Wire Service...Done
2018-04-21 13:12:03,615 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.wire.WireService....
2018-04-21 13:12:03,616 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.wire.WireService....Done
2018-04-21 13:12:03,640 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.misc.cloudcat.CloudCat ...
2018-04-21 13:12:03,770 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.u.log - Logging initialized @97400ms to org.eclipse.jetty.util.log.Slf4jLog
2018-04-21 13:12:04,620 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.Server - jetty-9.4.7.v20170914
2018-04-21 13:12:04,759 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - DefaultSessionIdManager workerName=node0
2018-04-21 13:12:04,760 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - No SessionScavenger set, using defaults
2018-04-21 13:12:04,771 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.session - Scavenging every 600000ms
2018-04-21 13:12:05,381 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.h.ContextHandler - Started o.e.j.s.ServletContextHandler@4b237d{/,null,AVAILABLE}
2018-04-21 13:12:06,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (13)
2018-04-21 13:12:06,533 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:07,972 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.AbstractConnector - Started ServerConnector@78d170{HTTP/1.1,[http/1.1]}{0.0.0.0:80}
2018-04-21 13:12:07,978 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.j.s.Server - Started @101607ms
2018-04-21 13:12:08,183 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.camel.cloud.factory.CamelFactory ...
2018-04-21 13:12:08,248 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.camel.xml.XmlRouterComponent ...
2018-04-21 13:12:08,250 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
2018-04-21 13:12:08,284 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.camel.xml.XmlRouterComponent
2018-04-21 13:12:08,357 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.AbstractCamelComponent - Starting camel router
2018-04-21 13:12:08,407 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Starting...
2018-04-21 13:12:08,408 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Stopping...
2018-04-21 13:12:08,432 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.r.CamelRunner - Setting routes...
2018-04-21 13:12:08,449 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....
2018-04-21 13:12:08,450 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.camel.xml.XmlRouterComponent....Done
2018-04-21 13:12:08,477 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Conditional ...
2018-04-21 13:12:08,524 [Start Level: Equinox Container: a086445f-6545-0018-1ba1-91a020f04cc0] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.wire.Join ...
2018-04-21 13:12:08,789 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.g.GPIOServiceImpl - Loaded File jdk.dio.properties: /opt/eclipse/kura/kura/jdk.dio.properties
2018-04-21 13:12:08,818 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.CloudConnectionStatusServiceImpl - Activating CloudConnectionStatus service...
2018-04-21 13:12:08,831 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-04-21 13:12:08,877 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.t.m.MqttDataTransport - Activating org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport...
2018-04-21 13:12:09,175 [Component Resolve Thread (Bundle 7)] WARN o.e.k.l.n.w.WifiOptions - Failed to execute iwconfig eth0
2018-04-21 13:12:09,404 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Activating org.eclipse.kura.data.DataService...
2018-04-21 13:12:09,408 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - Get Throttle with burst length 1 and send a message every 1000 millis
2018-04-21 13:12:09,416 [DataServiceImpl:Submit] INFO o.e.k.c.d.DataServiceImpl - DataPublisherService not connected
2018-04-21 13:12:09,437 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.DataServiceImpl - H2DbService instance found
2018-04-21 13:12:10,054 [DataServiceImpl:Submit] INFO o.e.k.c.d.DataServiceImpl - DataPublisherService not connected
2018-04-21 13:12:10,086 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.c.CloudCallServiceImpl - Activating...
2018-04-21 13:12:10,132 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CloudServiceImpl - activate org.eclipse.kura.cloud.CloudService...
2018-04-21 13:12:10,149 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for CONF-V1...
2018-04-21 13:12:10,177 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.a.c.CommandCloudApp - Cloudlet CMD-V1 has started with config!
2018-04-21 13:12:10,178 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for CMD-V1...
2018-04-21 13:12:10,179 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.a.c.CommandCloudApp - updated...: org.eclipse.equinox.internal.ds.impl.ReadOnlyDictionary@18eb3a9
2018-04-21 13:12:10,185 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....
2018-04-21 13:12:10,186 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.app.command.CommandCloudApp....Done
2018-04-21 13:12:10,224 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.CloudDeploymentHandlerV2 - Cloud Deployment v2 is starting
2018-04-21 13:12:10,225 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for DEPLOY-V2...
2018-04-21 13:12:10,245 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.i.InstallImpl - Ready to send Confirmations
2018-04-21 13:12:10,252 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....
2018-04-21 13:12:10,253 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2....Done
2018-04-21 13:12:10,281 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.Cloudlet - Getting CloudApplicationClient for ASSET-V1...
2018-04-21 13:12:10,955 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask started.
2018-04-21 13:12:10,956 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask: Delete confirmed messages...
2018-04-21 13:12:11,059 [HouseKeeperTask] INFO o.e.k.c.d.s.HouseKeeperTask - HouseKeeperTask ended.
2018-04-21 13:12:11,532 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (14)
2018-04-21 13:12:11,535 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:14,725 [Component Resolve Thread (Bundle 7)] INFO o.a.c.c.o.OsgiDefaultCamelContext - Apache Camel 2.17.2 (CamelContext: camel-1) is starting
2018-04-21 13:12:14,736 [Component Resolve Thread (Bundle 7)] INFO o.a.c.m.ManagedManagementStrategy - JMX is enabled
2018-04-21 13:12:37,919 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:12:37,967 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:12:38,903 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:12:41,942 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:12:41,946 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:12:41,947 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:12:41,948 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:12:41,949 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:12:41,951 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura home directory is /opt/eclipse/kura/kura
2018-04-21 13:12:41,952 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura snapshots directory is /opt/eclipse/kura/data/snapshots
2018-04-21 13:12:41,954 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura tmp directory is /tmp/.kura
2018-04-21 13:12:41,955 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version KURA_3.2.0 is starting
2018-04-21 13:12:42,026 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - activate...
2018-04-21 13:12:42,028 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.HsqlDbServiceImpl - Opening database with url: jdbc:hsqldb:mem:kuradb
2018-04-21 13:12:44,421 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.CertificatesManager - Bundle org.eclipse.kura.core.certificates.CertificatesManager has started!
2018-04-21 13:12:44,547 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - activate...
2018-04-21 13:12:44,556 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Loading init configurations from: 0...
2018-04-21 13:12:45,629 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.db.H2DbService and factory pid: org.eclipse.kura.core.db.H2DbService
2018-04-21 13:12:45,631 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.db.H2DbService and pid org.eclipse.kura.db.H2DbService
2018-04-21 13:12:45,632 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.db.H2DbService
2018-04-21 13:12:45,655 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....
2018-04-21 13:12:45,655 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.db.H2DbService....Done
2018-04-21 13:12:45,672 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and factory pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,673 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport and pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,673 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:45,692 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....
2018-04-21 13:12:45,693 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport....Done
2018-04-21 13:12:45,694 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.data.DataService and factory pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:45,695 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.data.DataService and pid org.eclipse.kura.data.DataService
2018-04-21 13:12:45,695 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.data.DataService
2018-04-21 13:12:45,715 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....
2018-04-21 13:12:45,716 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.data.DataService....Done
2018-04-21 13:12:45,731 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating configuration with pid: org.eclipse.kura.cloud.CloudService and factory pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,732 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Creating new configuration for factory pid org.eclipse.kura.cloud.CloudService and pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,733 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Updating newly created configuration for pid org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:45,749 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....
2018-04-21 13:12:45,750 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.cloud.CloudService....Done
2018-04-21 13:12:45,767 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Trackers being opened...
2018-04-21 13:12:45,768 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Only tracking relevant services
2018-04-21 13:12:46,344 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport ...
2018-04-21 13:12:46,362 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:46,382 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport
2018-04-21 13:12:46,383 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbService ...
2018-04-21 13:12:46,400 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.db.H2DbService
2018-04-21 13:12:46,401 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.data.DataService ...
2018-04-21 13:12:46,404 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:46,426 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.data.DataService
2018-04-21 13:12:46,427 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.db.H2DbServer ...
2018-04-21 13:12:46,428 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.ssl.SslManagerService ...
2018-04-21 13:12:46,430 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:12:46,448 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.ssl.SslManagerService
2018-04-21 13:12:46,563 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.CloudService ...
2018-04-21 13:12:46,565 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:46,994 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.CloudService
2018-04-21 13:12:46,995 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.cloud.app.command.CommandCloudApp ...
2018-04-21 13:12:46,996 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:12:47,021 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.cloud.app.command.CommandCloudApp
2018-04-21 13:12:47,130 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...
2018-04-21 13:12:47,132 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - Default H2DbService instance configuration found
2018-04-21 13:12:47,133 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbHelper - activating...done
2018-04-21 13:12:47,218 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 ...
2018-04-21 13:12:47,220 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:12:47,243 [Start Level: Equinox Container: d0508aa1-6545-0018-1882-d3b8fac3ead4] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
2018-04-21 13:12:47,264 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.watchdog.WatchdogService ...
2018-04-21 13:12:47,266 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:12:47,283 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.watchdog.WatchdogService
2018-04-21 13:12:47,320 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....
2018-04-21 13:12:47,321 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.watchdog.WatchdogService....Done
2018-04-21 13:12:47,349 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...
2018-04-21 13:12:47,350 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:12:47,357 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - Opening database with url: jdbc:h2:mem:kuradb
2018-04-21 13:12:48,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:12:48,212 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - activating...done
2018-04-21 13:12:48,272 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.clock.ClockService ...
2018-04-21 13:12:48,274 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:12:48,565 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.clock.ClockService
2018-04-21 13:12:48,598 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Activate. Current Time: Sat Apr 21 13:12:48 UTC 2018
2018-04-21 13:12:48,606 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:12:48,612 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:12:48,617 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....
2018-04-21 13:12:48,618 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.clock.ClockService....Done
2018-04-21 13:12:48,685 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:48,723 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.position.PositionService ...
2018-04-21 13:12:48,726 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Merging configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:12:48,751 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.kura.position.PositionService
2018-04-21 13:12:48,794 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:12:48,797 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Activating... Done.
2018-04-21 13:12:48,803 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....
2018-04-21 13:12:48,804 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.position.PositionService....Done
2018-04-21 13:12:48,871 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - activate...
2018-04-21 13:12:48,893 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....
2018-04-21 13:12:48,894 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering ConfigurableComponent - org.eclipse.kura.ssl.SslManagerService....Done
2018-04-21 13:12:48,916 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...
2018-04-21 13:12:48,919 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.d.H2DbServiceImpl - updating...done
2018-04-21 13:12:48,950 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SslManagerServiceImpl - updated...
2018-04-21 13:12:49,067 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.ClockServiceImpl - Updated...
2018-04-21 13:12:49,069 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Perform periodic clock updates every 3600 sec
2018-04-21 13:12:49,072 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (0)
2018-04-21 13:12:49,073 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:49,087 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.p.PositionServiceImpl - Updating... Done.
2018-04-21 13:12:49,123 [Component Resolve Thread (Bundle 7)] INFO o.e.k.l.b.BluetoothServiceImpl - Activating Bluetooth Service...
2018-04-21 13:12:49,171 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.b.BluetoothLeServiceImpl - Activating Bluetooth Le Service...
2018-04-21 13:12:54,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (1)
2018-04-21 13:12:54,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:12:59,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (2)
2018-04-21 13:12:59,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:04,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (3)
2018-04-21 13:13:04,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:09,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (4)
2018-04-21 13:13:09,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:14,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (5)
2018-04-21 13:13:14,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:19,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (6)
2018-04-21 13:13:19,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:24,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (7)
2018-04-21 13:13:24,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:29,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (8)
2018-04-21 13:13:29,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:34,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (9)
2018-04-21 13:13:34,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:39,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (10)
2018-04-21 13:13:39,072 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:13:44,071 [AbstractNtpClockSyncProvider:schedule] INFO o.e.k.l.c.AbstractNtpClockSyncProvider - Try to sync clock (11)
2018-04-21 13:13:44,074 [AbstractNtpClockSyncProvider:schedule] WARN o.e.k.l.c.JavaNtpClockSyncProvider - Error while synchronizing System Clock with NTP host 0.pool.ntp.org. Please verify network connectivity ...
2018-04-21 13:17:20,309 [Start Level: Equinox Container: 40276c4b-6645-0018-1800-af06638bea56] INFO o.a.c.i.o.Activator - Camel activator starting
2018-04-21 13:17:20,356 [Start Level: Equinox Container: 40276c4b-6645-0018-1800-af06638bea56] INFO o.a.c.i.o.Activator - Camel activator started
2018-04-21 13:17:21,697 [UdevHotplugThread] INFO o.e.k.l.u.LinuxUdevNative - Starting LinuxUdevNative Thread ...
2018-04-21 13:17:24,320 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura.properties: file:/opt/eclipse/kura/kura/kura.properties
2018-04-21 13:17:24,323 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Loaded URL kura_custom.properties: file:/opt/eclipse/kura/kura/kura_custom.properties
2018-04-21 13:17:24,324 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura has net admin? true
2018-04-21 13:17:24,325 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Is Kura web interface enabled? true
2018-04-21 13:17:24,326 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura version? KURA_3.2.0
2018-04-21 13:17:24,328 [Component Resolve Thread (Bundle 7)] INFO o.e.k.c.s.SystemServiceImpl - Kura h
Re: Issue with kura installation on Raspberry Pi 2 [message #1785951 is a reply to message #1785949] Mon, 23 April 2018 10:32 Go to previous messageGo to next message
Obviously this is not enough to understand. But Kura seems to be working.
Please double check to not have conflicts due to multiple services that run on port 80.
It would be better to install Kura in a clean raspbian installation.
Matteo
Re: Issue with kura installation on Raspberry Pi 2 [message #1785952 is a reply to message #1785951] Mon, 23 April 2018 10:33 Go to previous messageGo to next message
Kura-Console.log
Kura Started (pid=348) ...
!SESSION 2018-04-21 12:52:33.464 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_162
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_GB
Command-line arguments: -configuration /tmp/.kura/configuration -console 5002 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:53:09.861
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.configuration.CloudConfigurationHandler. The reference is: Reference[name = CloudService, interface = org.eclipse.kura.cloud.CloudService, policy = dynamic, cardinality = 0..1, target = (kura.service.pid=org.eclipse.kura.cloud.CloudService), bind = setCloudService, unbind = unsetCloudService]
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:53:12.628
!MESSAGE Could not bind a reference of component org.eclipse.kura.core.deployment.hook.DeploymentHookManager. The reference is: Reference[name = DeploymentHook, interface = org.eclipse.kura.deployment.hook.DeploymentHook, policy = dynamic, cardinality = 0..n, target = null, bind = bindHook, unbind = unbindHook]
(process:348): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
terminate called after throwing an instance of 'tinyb::BluetoothException'
what(): No adapter installed or not recognized by system
Kura Started (pid=339) ...
!SESSION 2018-04-21 12:57:25.343 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:57:57.180
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 12:58:01.202
(process:339): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=319) ...
!SESSION 2018-04-21 13:04:58.544 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:05:22.952
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:05:24.667
(process:319): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=304) ...
!SESSION 2018-04-21 13:10:32.037 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:10:56.648
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:11:01.495
!SESSION 2018-04-21 13:12:23.077 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:12:47.180
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:12:49.031
Kura Started (pid=305) ...
!SESSION 2018-04-21 13:17:08.188 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:30.718
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:32.265
!ENTRY org.eclipse.equinox.ds 2 0 2018-04-21 13:18:32.431
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@1eec833; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2018-04-21 13:18:32.605
!MESSAGE [SCR] Enabling components of bundle org.eclipse.kura.ble.provider did not complete in 60000 ms
(process:305): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Kura Started (pid=282) ...
!SESSION 2018-04-21 13:17:09.163 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:32.002
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:33.548
Kura Started (pid=351) ...
!SESSION 2018-04-21 13:17:08.793 -----------------------------------------------
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:33.448
!ENTRY org.eclipse.equinox.ds 1 0 2018-04-21 13:17:37.532
(process:351): GLib-GIO-CRITICAL **: g_dbus_interface_get_info: assertion 'G_IS_DBUS_INTERFACE (interface_)' failed
Re: Issue with kura installation on Raspberry Pi 2 [message #1785954 is a reply to message #1785951] Mon, 23 April 2018 10:34 Go to previous messageGo to next message
i installed kura on clean rasbian
Re: Issue with kura installation on Raspberry Pi 2 [message #1785955 is a reply to message #1785951] Mon, 23 April 2018 10:36 Go to previous messageGo to next message
i didn't understand what you mean by this "Please double check to not have conflicts due to multiple services that run on port 80."
Re: Issue with kura installation on Raspberry Pi 2 [message #1785956 is a reply to message #1785955] Mon, 23 April 2018 10:38 Go to previous messageGo to next message
Sorry, I've replied before you pushed the updated versions of the logs.
From this last version of the logs, it seems that the framework continuously restarts itself.
I'll try to look at it
Re: Issue with kura installation on Raspberry Pi 2 [message #1785958 is a reply to message #1785955] Mon, 23 April 2018 10:53 Go to previous messageGo to next message
try with "sudo netstat -tulpn" and check that there aren't multiple applications that try to use the port 80.
However, the following log lines are interesting:
It seems that there are some problems with the Bluetooth lib and this can cause these log messages and problem with Kura. Which version of raspbian are you using? Which version on bluez is installed on your system?
Best,
Pierantonio
Re: Issue with kura installation on Raspberry Pi 2 [message #1786033 is a reply to message #1785958] Tue, 24 April 2018 07:58 Go to previous messageGo to next message
pi@raspberrypi:~ $ sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 282/named
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 333/sshd
tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 282/named
tcp6 0 0 :::53 :::* LISTEN 282/named
tcp6 0 0 :::22 :::* LISTEN 333/sshd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 285/avahi-daemon: r
udp 0 0 0.0.0.0:57868 0.0.0.0:* 285/avahi-daemon: r
udp 0 0 127.0.0.1:53 0.0.0.0:* 282/named
udp6 0 0 :::5353 :::* 285/avahi-daemon: r
udp6 0 0 :::37282 :::* 285/avahi-daemon: r
udp6 0 0 :::53 :::* 282/named
Re: Issue with kura installation on Raspberry Pi 2 [message #1786034 is a reply to message #1785958] Tue, 24 April 2018 08:03 Go to previous message
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.3 (stretch)
Release: 9.3
Codename: stretch
Previous Topic:Publish PPMP Protocol
Next Topic:Issues with GPIO connection Kura/Eclipse
Current Time: Mon Jul 21 04:59:57 EDT 2025
Powered by FUDForum. Page generated in 0.08170 seconds
