Home » Newcomers » Newcomers » Problems with exporting to jar with images in eclipse - getting instability
Problems with exporting to jar with images in eclipse - getting instability [message #1785875] Sat, 21 April 2018 13:35 Go to next message
I tried to export as a jar and a runnable jar, but either way, the program worked fine but no pictures showed up in my game.
I read a bunch of stackoverflow forums and found something that semi-worked. I changed the path to:
zappa = new ImageIcon(getClassLoader().getResource("/images/zappa2.jpg"));
When I exported to a jar, the pictures showed in the game! However, whenever I comment out my old path and use the new getResource path, the game becomes very unstable. It only loads a rare number of times out of a set of attempts. In both eclipse and the exported jar, most of the times I try to load the program, I just get an empty frame, and on some occasions, I get game play, but my paddle is unresponsive to the mouse.
I want the stability of my first path, but the pictures exporting correctly of my second path.
Suggestions?
Also, what do I want: jar or runnable jar? This is my first GUI program. Previously, I've made text programs, exported to jar, and ran them thru terminal.
Thank you, core
Re: Problems with exporting to jar with images in eclipse - getting instability [message #1786273 is a reply to message #1785875] Sun, 29 April 2018 03:35 Go to previous message
We're not a general Java programming forum. This looks like the sort of question to take somewhere like
StackOverflow or the relevant JavaRanch forum, https://coderanch.com/f/2/GUI .
Previous Topic:How to create a new eclipse console from java code?
Next Topic:Remove red box around brackets
Current Time: Fri Jul 25 11:16:05 EDT 2025
Powered by FUDForum. Page generated in 0.09662 seconds
