Home » Modeling » GMF (Graphical Modeling Framework) » Select All + Arrange All
Select All + Arrange All [message #178568] Fri, 21 March 2008 06:26 Go to next message
Hi Team,
I have a situation here. Intention is to fire a command that selects
editparts in the active editor and perform arrange all.
For select all I am using -
IDiagramGraphicalViewer viewer = ((IDiagramWorkbenchPart)
ViewHelper.getInstance().getActiveEditorPart().getSite().get Part()).getDiagramGraphicalViewer();
if (viewer != null) {
//listEditPart is the list of editparts (nodes and edges) under current
diagram
if (!listEditPart.isEmpty()) {
viewer.setSelection(new StructuredSelection(listEditPart));
-This works fine.
For Arrange All I am using -
ArrangeRequest arrangeRequest = new
ArangeRequest(ActionIds.ACTION_ARRANGE_ALL);
arrangeRequest.setPartsToArrange(listEditPart);
DiagramDocumentEditor diagramEditor = (DiagramDocumentEditor)
ViewHelper.getInstance().getActiveEditorPart();
CompoundCommand cc1 = new CompoundCommand("Arrange All");
Command command1 =
diagramEditor.getDiagramEditPart().getCommand(arrangeRequest );
cc1.add(command1);
diagramEditor.getDiagramEditDomain().getDiagramCommandStack( )
.execute(cc1, new NullProgressMonitor());
diagramEditor.getDiagramEditPart().refresh();
Although It selects correctly, it doesnt perform the arrange all operation
as we see from the menu action.
Any idea why?
Re: Select All + Arrange All [message #178871 is a reply to message #178568] Tue, 25 March 2008 05:00 Go to previous messageGo to next message
I found that Arrange All is arranging the selection, but only considering
the outermost object. Its behaving as if I have only selected the
outermost shape, and not done "Select All Shape" action.
Re: Select All + Arrange All [solved] [message #179468 is a reply to message #178871] Fri, 28 March 2008 02:13 Go to previous messageGo to next message
Hi Guys,
The following code seems to work. Have an initial look. I will refactor
this a bit and update later
//Set the focus to the diagram editor
diagramEditor.setFocus();
//Sets the correct newly added elements as selected components.
// listEditPart is a list of editParts we want to select and arrange
//Ensure that the focus shifts back to the DiagramEditor,
diagramEditor.getDiagramEditPart().setFocus(true); diagramEditor.getEditorSite().getPage().activate(diagramEdit or.getSite().getPart());
//Arrange The selected components.
//Two times running the action give better layout
ArrangeAction arrange =
ArrangeAction.createArrangeAllAction(diagramEditor.getEditor Site().getPage());
arrange.init();
arrange.setActionDefinitionId(ActionIds.ACTION_ARRANGE_ALL);
arrange.setup();
arrange.run( new SubProgressMonitor(monitor, 100));
//Deselects newly added elements
viewer.select(diagramEditor.getDiagramEditPart());
Re: Select All + Arrange All [solved] [message #179500 is a reply to message #179468] Fri, 28 March 2008 04:36 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
I tried your code, but this ArrangeAction class - where does it come
from? Is it a custom class? (also what is ViewHelper?)
Why not use ArrangeRequest?
I do this with:
ArrangeRequest arrangeRequest = new ArrangeRequest(
RequestConstants.REQ_ARRANGE_DEFERRED);
arrangeRequest.setViewAdaptersToArrange(editList);
selectedElement.getDiagramEditDomain().getDiagramCommandStac k().
execute(selectedElement.getCommand(arrangeRequest));
Tomas Zijdemans
Sandip wrote:
> Hi Guys,
> //Arrange The selected components. //Two times running the action give
> better layout
> arrange.init();
> arrange.setup();
> //Deselects newly added elements if (viewer != null) {
Re: Select All + Arrange All [solved] [message #179546 is a reply to message #179500] Fri, 28 March 2008 05:13 Go to previous messageGo to next message
Hi Tomas,
We already tried that piece of code. Didnt seem to solve our purpose where
we need to rearrange inner components and connections.
Later we moved to ArrangeAction from
org.eclipse.gmf.runtime.diagram.ui.actions and it seem to work fine.
Re: Select All + Arrange All [solved] [message #179678 is a reply to message #179546] Fri, 28 March 2008 10:28 Go to previous messageGo to next message
Sandip wrote:
> Hi Tomas,
> where we need to rearrange inner components and connections.
Ok.. I don't have that class in my package, so I guess you subclassed:
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.
Re: Select All + Arrange All [solved] [message #180401 is a reply to message #179468] Wed, 02 April 2008 07:55 Go to previous messageGo to next message
Originally posted by: marsha.rohrer.swisscom.com
Hi Sandip,
Maybe a bit a silly question...but in which method did you add your code
extracts?
Marsha
Re: Select All + Arrange All [solved] [message #180409 is a reply to message #180401] Wed, 02 April 2008 08:16 Go to previous messageGo to next message
Hi Marsha, I do not have a specific place to put this code. I have a
wizard from where I am adding few domain components in the diagram. The
intention was to auto arrange the editparts that got newly created. You
shud b able to run it from whereever you want. Ensure you have the list of
editparts and your active editor. Rest the code can help you.
Re: Select All + Arrange All [solved] [message #180438 is a reply to message #180409] Wed, 02 April 2008 09:51 Go to previous messageGo to next message
Ok...I was asking because I can't find the ViewHelper you are using....
Marsha
Re: Select All + Arrange All [message #184611 is a reply to message #178568] Mon, 28 April 2008 15:56 Go to previous message
Originally posted by: birar01.ca.com
In case this is helpful to anyone:
I wanted to kick off an arrange all when the editor is started. I added the
following code to the generated DiagramEditor:
protected void initializeGraphicalViewerContents() {
super.initializeGraphicalViewerContents();
ArrangeRequest(ActionIds.ACTION_ARRANGE_ALL);
IGraphicalEditPart rootEP = (IGraphicalEditPart)
getDiagramGraphicalViewer().getRootEditPart().getContents();
List l = new ArrayList();
l.add(rootEP);
arrangeRequest.setPartsToArrange(l);
Command cmd = rootEP.getCommand(arrangeRequest);
getCommandStack().execute(cmd);
"Sandip" <sandip.b@in.bosch.com> wrote in message
news:6af76885b722de035e420af80ec3a31f$1@www.eclipse.org...
> Hi Team,
> if (viewer != null) { //listEditPart is the list of editparts (nodes and
> edges) under current diagram
> -This works fine.
> Command command1 =
> cc1.add(command1);
> Any idea why?
Previous Topic:persisted edges
Next Topic:Hidden connections still displayed
Current Time: Wed Nov 05 05:54:12 EST 2025
Powered by FUDForum. Page generated in 0.04142 seconds
