Home » Archived » Jubula » Web Automation - HTML(web automation - HTML)
Web Automation - HTML [message #1785163] Tue, 10 April 2018 03:53 Go to next message
I would like to do automation on a web page using Jubula.
For example, i want to make use of the following url: http://newtours.demoaut.com/mercuryregister.php
Could someone help me how to start automation on this specific url?
Re: Web Automation - HTML [message #1785511 is a reply to message #1785163] Mon, 16 April 2018 02:08 Go to previous message
Dear Ziyaad Ellahee,
please follow the instruction on our user manuel how to set up your AUT configuration:
https://testing.bredex.de/files/content/software/documentation/userManual/tasks/ch03s08s06.html
The webpage you send to us, does work with Jubula.
Please keep in mind that Jubula cant test all webpages, try to configure the AUT and test if you can start it. If so, please check if it is possible to map the components.
If you have allready problems with starting it or mapping, that means you cant use Jubula for your testautomation.
Kind Regards
Elena
Previous Topic:Jubula can not map objects on the installer that built by InstallAnywhere2015
Next Topic:Testing content of SwingNode in JavaFX application
Current Time: Sun Jul 20 23:54:47 EDT 2025
Powered by FUDForum. Page generated in 0.03885 seconds
