Home » Modeling » Eclipse Layout Kernel » How Customized ELK to fit Sirius application?
How Customized ELK to fit Sirius application? [message #1785293] Thu, 12 April 2018 03:50 Go to next message
To whom it may concern,
I want to use the ELK in Sirius application ( I am the fresh man in this field).
I installed ELK to my Eclipse, it works well using the property to do.
But some times, I want to customized some BorderNode position (ElkPort), based on the semantic model information IN/OUT. It is hard to do.
I find a presentation 'introducing the Eclipse Layout Kernel' by Christoph Daniel Schulze, which includes the same example. As following description:
index.php/fa/32587/0/
But this example code just is partial code. And then I follow the 'Advanced Configuration' tutorial, find I can prepare the parameter before DiagramLayoutEngine. However, it maybe can not specify the layout option to corresponded semantic model element. (Because the mapping(LayoutMapping) can not prepared before the DiagramLayoutEngine).
Compare these, this information makes me confused.
1) What's the correct way to customized the layout, like using the semantic model information to impact the ELK? (like Daniel's presentation)
2) Is there any example/sample for ELK tool developer?
Thanks for your reply.
[Updated on: Thu, 12 April 2018 03:54] by Moderator
Re: How Customized ELK to fit Sirius application? [message #1785299 is a reply to message #1785293] Thu, 12 April 2018 04:38 Go to previous messageGo to next message
There are many ways to configure ELK layout. If you would like to reuse the code snipped that you posted, you could try the following:
  • Implement an ILayoutSetup (see e.g. GmfLayoutSetup) and register it with the org.eclipse.elk.core.service.layoutConnectors extension point.
  • In the Guice Module returned by your setup, bind DiagramLayoutEngine to a new subclass (e.g. CustomDiagramLayoutEngine).
  • In CustomDiagramLayoutEngine, override addDiagramConfig(Parameters, LayoutMapping) to add your configuration code.
protected void addDiagramConfig(Parameters params, LayoutMapping layoutMapping) {
    LayoutConfigurator layoutConfigurator = params.addLayoutRun();
    // Put your configuration code here
    super.addDiagramConfig(params, layoutMapping);
Re: How Customized ELK to fit Sirius application? [message #1785301 is a reply to message #1785299] Thu, 12 April 2018 04:51 Go to previous messageGo to next message
Caution: My proposed solution does not work well if you call DiagramLayoutEngine.invokeLayout(IWorkbenchPart, Object, Parameters) somewhere and configure the layout there. The effect would be that the layout would be computed twice, which is probably not what you want.
Alternative approaches are to use the aforementioned static invokeLayout method (but then you don't have access to the LayoutMapping) or to create a subclass of GmfDiagramLayoutConnector and set the configuration properties directly on the elements of the created layout graph.
Re: How Customized ELK to fit Sirius application? [message #1785306 is a reply to message #1785301] Thu, 12 April 2018 05:54 Go to previous messageGo to next message
Dear Miro Spönemann,
Thanks for you reply quickly.
I will try to create a subclass of GmfDiagramLayoutConnector and set the configuration properties directly. In my application.
Actually, I have tried the following, the layout have be computed twice.
LayoutMapping mapping = DiagramLayoutEngine.invokeLayout(...);
But I think using the Christoph Daniel Schulze's example, it looks very easy for user to configure the Layout Option. And https://www.eclipse.org/elk/documentation/tooldevelopers/usingeclipselayout/advancedconfiguration.html
also provide this kind of 'Advanced Configuration' way.
LayoutConfigurator configurator = new LayoutConfigurator();
// Configure layout options for a concrete graph object
configurator.configure(myVerySpecialNode)
    .setProperty(CoreOptions.INTERACTIVE, true)
    .setProperty(CoreOptions.PORT_CONSTRAINTS, PortConstraints.FIXED);
Is there any example project for this kind of 'Configuration'? I would like to know more about it.
Thanks.
Re: How Customized ELK to fit Sirius application? [message #1785312 is a reply to message #1785306] Thu, 12 April 2018 06:44 Go to previous messageGo to next message
Nicholas Kong wrote on Thu, 12 April 2018 11:54
Use ElkUtil.applyVisitors(graph, configurator) to apply such a configurator to a graph.
Re: How Customized ELK to fit Sirius application? [message #1785314 is a reply to message #1785312] Thu, 12 April 2018 06:56 Go to previous messageGo to next message
Miro Spönemann.
Can I use this ElkUtil.applyVisitors(graph, configurator) before the DiagramLayoutEngine.invokeLayout() ?
It looks different with 'Advanced Configuration'.
DiagramLayoutEngine.Parameters params = new DiagramLayoutEngine.Parameters();
params.addLayoutRun(configurator);
DiagramLayoutEngine.invokeLayout(workbenchPart, diagramPart, params);
Re: How Customized ELK to fit Sirius application? [message #1785317 is a reply to message #1785314] Thu, 12 April 2018 07:01 Go to previous messageGo to next message
Nicholas Kong wrote on Thu, 12 April 2018 12:56
No. DiagramLayoutEngine.invokeLayout() calls GmfLayoutConnector.buildLayoutGraph() in order to obtain a graph instance, so you cannot apply the configurator before the graph has been created.
You can use ElkUtil.applyVisitors(graph, configurator) in a subclass of GmfLayoutConnector.
If you add a configurator to the DiagramLayoutEngine.Parameters, you don't need to apply it yourself because ELK will take care of that.
Re: How Customized ELK to fit Sirius application? [message #1785318 is a reply to message #1785317] Thu, 12 April 2018 07:12 Go to previous messageGo to next message
Thank you. Understanding is becoming clearer.
One more question:
Also 'Advanced Configuration' part. As the guide description:
About the comment describes the concrete graph object, what kinds of graph object I can configure? only ELK elements (ElkNode, ElkPort)?
Can I configure GMF node or Sirius node here?
Re: How Customized ELK to fit Sirius application? [message #1785319 is a reply to message #1785318] Thu, 12 April 2018 07:19 Go to previous messageGo to next message
Here graph objects are ElkGraphElements such as ElkNode, ElkPort etc.
If you want to configure on the GMF / Sirius node (EditPart) level, do it in a subclass of GmfLayoutConnector.
Re: How Customized ELK to fit Sirius application? [message #1785320 is a reply to message #1785319] Thu, 12 April 2018 07:44 Go to previous messageGo to next message
Gotcha. Miro Spönemann, Thank you very much.
Have a good night. ( ;
Re: How Customized ELK to fit Sirius application? [message #1786733 is a reply to message #1785319] Thu, 10 May 2018 03:49 Go to previous messageGo to next message
Hi Miro SpönemannFriend,
I want to use ELK to let some specified Nodes always on the left side, no matter them have edge or not.
How can I handle this scenario?
I try to use the 'LayeredOptions.LAYERING_LAYER_CONSTRAINT', but it does not met our opinion.
index.php/fa/32799/0/
  • Attachment: Capture.PNG
    (Size: 14.24KB, Downloaded 1005 times)
Re: How Customized ELK to fit Sirius application? [message #1787122 is a reply to message #1785319] Sat, 19 May 2018 06:00 Go to previous messageGo to next message
Dear Miro Spönemann:
I configured the ELK layout for Sirius diagram as you and Nicholas Kong discussed.
configurator.configure(ElkNode.class).setProperty(CoreOptions.ALGORITHM, "org.eclipse.elk.alg.layered")
.setProperty(CoreOptions.PORT_CONSTRAINTS, PortConstraints.FIXED_SIDE)
.setProperty(CoreOptions.PORT_LABELS_PLACEMENT, PortLabelPlacement.INSIDE)
.setProperty(CoreOptions.NODE_SIZE_OPTIONS,
.setProperty(CoreOptions.HIERARCHY_HANDLING, HierarchyHandling.INCLUDE_CHILDREN);
if(***){
port.setProperty(PortSide.WEST);
}else if(***){
port.setProperty(PortSide.EAST);
}else if(***){
port.setProperty(PortSide.NORTH);
}if(***){
port.setProperty(PortSide.SOUTH);
When I operate ELk layout, some of my diagrams occur an exception.
java.lang.ClassCastException: org.eclipse.elk.alg.layered.graph.LEdge cannot be cast to org.eclipse.elk.alg.layered.graph.LPort
at org.eclipse.elk.alg.layered.intermediate.greedyswitch.SwitchDecider.doesSwitchReduceCrossings(SwitchDecider.java:146)
at org.eclipse.elk.alg.layered.intermediate.greedyswitch.GreedySwitchHeuristic.switchIfImproves(GreedySwitchHeuristic.java:116)
at org.eclipse.elk.alg.layered.intermediate.greedyswitch.GreedySwitchHeuristic.sweepDownwardInLayer(GreedySwitchHeuristic.java:108)
at org.eclipse.elk.alg.layered.intermediate.greedyswitch.GreedySwitchHeuristic.continueSwitchingUntilNoImprovementInLayer(GreedySwitchHeuristic.java:96)
at org.eclipse.elk.alg.layered.intermediate.greedyswitch.GreedySwitchHeuristic.minimizeCrossings(GreedySwitchHeuristic.java:65)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:239)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNode(LayerSweepCrossingMinimizer.java:274)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNodes(LayerSweepCrossingMinimizer.java:253)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:237)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossingsNoCounter(LayerSweepCrossingMinimizer.java:155)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.lambda$1(LayerSweepCrossingMinimizer.java:122)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossings(LayerSweepCrossingMinimizer.java:131)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMjava.lang.ClassCastException: org.eclipse.elk.alg.layered.graph.LEdge cannot be cast to org.eclipse.elk.alg.layered.graph.LPort
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.process(LayerSweepCrossingMinimizer.java:110)
at org.eclipse.elk.alg.layered.KlayLayered.hierarchicalLayout(KlayLayered.java:233)
at org.eclipse.elk.alg.layered.KlayLayered.doCompoundLayout(KlayLayered.java:179)
at org.eclipse.elk.alg.layered.LayeredLayoutProvider.layout(LayeredLayoutProvider.java:58)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layoutRecursively(RecursiveGraphLayoutEngine.java:181)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:60)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:725)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:655)
at org.eclipse.elk.core.service.DiagramLayoutEngine$1.execute(DiagramLayoutEngine.java:414)
at org.eclipse.elk.core.service.util.MonitoredOperation.runOperation(MonitoredOperation.java:374)
at org.eclipse.elk.core.service.util.MonitoredOperation.access$2(MonitoredOperation.java:359)
at org.eclipse.elk.core.service.util.MonitoredOperation$4.run(MonitoredOperation.java:313)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)inimizer.process(LayerSweepCrossingMinimizer.java:110)
If I comment "setProperty(CoreOptions.HIERARCHY_HANDLING, HierarchyHandling.INCLUDE_CHILDREN)", the exception will not show up.
It seems that there is something wrong with customizing port side with the property "HierarchyHandling.INCLUDE_CHILDREN". Can you give me some suggestions or guide about how to correct my customized layout ?
Thanks in advance and hope for your reply.
Re: How Customized ELK to fit Sirius application? [message #1787206 is a reply to message #1787122] Tue, 22 May 2018 02:56 Go to previous messageGo to next message
An exception like that is a bug. Please check whether it has already been reported at https://github.com/eclipse/elk/issues and create an issue if it's not there yet.
Re: How Customized ELK to fit Sirius application? [message #1787215 is a reply to message #1785293] Tue, 22 May 2018 04:14 Go to previous messageGo to next message
Deactivating greedy switch should help.
Nevertheless, it would helpful if you could share the the graph (in ELK graph format) such that we can debug the issue. There's a method 'exportLayoutGraph(...)' in the DiagramLayoutEngine to do so.
Re: How Customized ELK to fit Sirius application? [message #1794366 is a reply to message #1785314] Wed, 29 August 2018 11:33 Go to previous message
Nicholas Kong wrote on Thu, 12 April 2018 11:56
Miro Spönemann.
Dear Nicholas. Can you share your code or explain where the workbenchPart comes from?
If I do "PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActivePart()" to get my WorkbenchPart
it gives an error "No layout connector is available for the given selection blablabla.", basically because I have multiple Dialog windows (I guess...).
Thank you for your help.
Previous Topic:Compound node layout
Next Topic:Grouping of Nodes using KLay Layered Layout
Current Time: Mon Jul 21 06:12:32 EDT 2025
Powered by FUDForum. Page generated in 0.07336 seconds
