Home » Eclipse Projects » Sirius » cannot open update site for ObeoNetwork/BPMN-Designer (cannot open update site for ObeoNetwork/BPMN-Designer)
cannot open update site for ObeoNetwork/BPMN-Designer [message #1785230] Wed, 11 April 2018 04:56 Go to next message
for Obeo BPMN designer ( at https://github.com/ObeoNetwork/BPMN-Designer )
the install process mentions the update site is at:
https://s3-eu-west-1.amazonaws.com/obeo-bpmndesigner-releases/3.5.0/repository/
when I open this I only see:
Error>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>3.5.0/repository/</Key>
<RequestId>58215770305BEF76</RequestId>
<HostId>
Td5JWo2AgS+meeJMXeLmRXQ7z3u8XaogWQ24qZQ5OfQraoZwSDLQzR7IaWsqUvwHWqDMagGmHf0=
</HostId>
</Error>
Is commercial support available for Obeo BPMN designer? Should it work with eclipse Oxygen?
Neil
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785250 is a reply to message #1785230] Wed, 11 April 2018 10:16 Go to previous messageGo to next message
The bpmn designer update site must be used in the "Install new software..." wizard of your eclipse runtime.
Guillaume
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785251 is a reply to message #1785230] Wed, 11 April 2018 10:29 Go to previous messageGo to next message
Neil Mackenzie wrote on Wed, 11 April 2018 10:56
You can contact Obeo to get a commercial support for the BPMN designer :
https://www.obeo.fr/en/contact
Mélanie
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785264 is a reply to message #1785251] Wed, 11 April 2018 13:33 Go to previous messageGo to next message
Thanks, I solved the problem, actually my workplace firewall and security rules didnt like that the link had https. I solved this by removing the s!
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785266 is a reply to message #1785264] Wed, 11 April 2018 13:57 Go to previous messageGo to next message
Thanks Melanie,
I will talk to my employer about this. I am looking at all the different BPMN tools for them. The primary thing that we need is to show is subprocesses inside subprocesses (which seems to be disallowed visually in Obeo BPMN designer) and the ability to collapse a subprocess to a smaller size (collapsing in Obeo designer seems to keep the same size and make the contents invisible) Do you know if these features are available? I am using the latest version with ObeoDesigner 10 and I also point to the eclipse oxygen release update site.
Neil
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785294 is a reply to message #1785266] Thu, 12 April 2018 03:57 Go to previous messageGo to next message
Actually I can see the advantage of just making subprocess elements invisible and not collapsing them. But I am surprised that the tool does not display sub-processes inside subprocesses (like ecore tools displays packages contained by packages). It can store subprocesses contained by subprocesses in the model instance, but just not display them, unless this is a case of user error!
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785337 is a reply to message #1785294] Thu, 12 April 2018 12:36 Go to previous messageGo to next message
I can get the tool to allow display and creation of Subprocesses contained by other subprocesses by editing the .odesign file. It might be that my solution is a bit hacky or causes other problems though. I could consider adding it as a pull request if it is useful.
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785390 is a reply to message #1785337] Fri, 13 April 2018 08:06 Go to previous messageGo to next message
Do not hesitate to push a pull request, we really appreciate contributions!
Mélanie
Re: cannot open update site for ObeoNetwork/BPMN-Designer [message #1785494 is a reply to message #1785390] Sun, 15 April 2018 11:56 Go to previous message
I have created a pull request.
Previous Topic:Reuse of a Dialog in properties view
Next Topic:Master-Detail with properties view
Current Time: Tue Jul 29 03:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.06511 seconds
