Home » Eclipse Projects » Oomph » Forcing a P2 Update site inside the Eclipse "Update Sites" preferences
Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1784919] Thu, 05 April 2018 14:36 Go to next message
Trying to figure out based on the documentation how to force the Help -> Check for Updates to use our internal mirrors. The preferences still have the 'default' outside URL listed.
I've used the "record" preference option but I still don't see the update URL.
What is the best way to centrally manage the P2 Update URL's , so that it points to our artifactory server. if I missed it in the docs please redirect me.
I need this to be the default for everyone who will be using this model, so if it is a user setup how do I add that to the main package? Each version of Eclipse has a different internal artifactory location due to historical reasons.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1784932 is a reply to message #1784919] Fri, 06 April 2018 00:33 Go to previous messageGo to next message
The preference recorder only records instance-scoped preferences and even the Capture Preferences dialog in the Setup Editor toolbar only shows instance preferences. If you install the Oomph Preferences Management feature, i.e., the IU "org.eclipse.oomph.preferences.feature.group'" , the preferences dialog will include Oomph -> All lPreferences and that has an Edit... button to open the preference explorer editor. That editor has a button in the toolbar to "Keep the editor synchronized with changes to the underlying preference store". This allows you to explore all preferences of all scopes and when any preference is changed, the editor will select the modified preference.
Using this approach you'll see that unfortunately these p2 update URL preferences are stored as profile-scoped preferences. And even worse, the key is an encoded URI of the profile's location on disk. I.e., it depends on where the installation is created. The actual *.pref files are located in the profile's folder so when using a shared bundle pool, they're located in, by default, ~/.p2/org.eclipse.equinox.p2.engine/profileRegistry/*.profile/.data/.settings/*.pref.
Worse still, the content metadata of a product IU can include touch point instructions like this:
          <instruction key='configure'>
            org.eclipse.equinox.p2.touchpoint.eclipse.addRepository(type:0,location:http${#58}//download.eclipse.org/releases/latest,name:Latest Eclipse Release,enabled:false);org.eclipse.equinox.p2.touchpoint.eclipse.addRepository(type:1,location:http${#58}//download.eclipse.org/releases/latest,name:Latest Eclipse Release,enabled:false);
          </instruction>
It's all definitely not easy to manage or influence as a result of this overall design. Perhaps the URI(s) you don't want are coming from these touch point instructions and you can change that behavior/result by changing their values in your mirror's metadata (content.jar/content.xml.xz).
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1784985 is a reply to message #1784932] Fri, 06 April 2018 11:43 Go to previous messageGo to next message
How does Eclipse decide which ones to show per-Eclipse version?
For example if I look at '.p2\org.eclipse.equinox.p2.engine\.settings\org.eclipse.equinox.p2.artifact.repository.prefs' I can see Neon and Oxygen base installs listed.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1784996 is a reply to message #1784985] Fri, 06 April 2018 14:20 Go to previous messageGo to next message
Sorry, I really don't know the details of how p2 manages all its various preferences. But I do know that in ~/.p2/org.eclipse.equinox.p2.engine/profileRegistry/*.profile/.data/.settings/*.pref for each specific *.profile corresponding to each specific installation that this is where the preference you change in the IDE are stored.
For your case it's probably more important to consider where are these values coming from, e.g., if it's from touch points in your mirrored p2 update site you can change it in your update site and not worry about where p2 ends up putting them all.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785127 is a reply to message #1784996] Mon, 09 April 2018 15:16 Go to previous messageGo to next message
how would you convert C:\MYDIR\NAME\oomph\java-latest-release\eclipse.profile to C__MYDIR_NAME_oomph_java-latest-released_eclipse.profile
I've tried the variablefilters but can't figure out how to convert it properly.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785155 is a reply to message #1785127] Tue, 10 April 2018 03:18 Go to previous messageGo to next message
Hi David, I've added a "pathEncode" filter and updated the documentation accordingly. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=533408
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785157 is a reply to message #1785127] Tue, 10 April 2018 03:25 Go to previous messageGo to next message
Yes, that's the unfortunate part. There is no filter that does this. Perhaps more direct would be if there were a variable containing the path/URI of the profile; of the self profile in the installation itself and of the target profile in the installer.
Please open a Bugzilla enhancement request, explaining how you want to use this value in your tasks and I can look into what's all needed when I'm back from traveling next week.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785211 is a reply to message #1785155] Tue, 10 April 2018 23:38 Go to previous messageGo to next message
Eike,
thanks this works by the looks of things:
${install.root|uri}/.p2/org.eclipse.equinox.p2.engine/profileRegistry/${installation.location|pathEncode}_eclipse.profile/.data/.settings/org.eclipse.equinox.p2.metadata.repository.prefs
It's a bit of a mouth-full for a path, but it works.
<xmi:XMI xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0">
  <setup:ResourceCreationTask
      content="eclipse.preferences.version=1&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/url=http\://mydomain.com/dist/eclipseide/update/4.7qa/common/site/&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/enabled=true&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/isSystem=false&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/name=Eclipse 4.7qa Repository"
      targetURL="${install.root|uri}/.p2/org.eclipse.equinox.p2.engine/profileRegistry/${installation.location|pathEncode}_eclipse.profile/.data/.settings/org.eclipse.equinox.p2.metadata.repository.prefs"
      encoding="UTF-8"/>
      content="eclipse.preferences.version=1&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/url=http\://mydomain.com/dist/eclipseide/update/4.7qa/common/site/&#xA;repositories/http\:__myweb.ms.com_dist_eclipseide_update_4.7qa_common_site/enabled=true&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/isSystem=false&#xA;repositories/http\:__mydomain.com_dist_eclipseide_update_4.7qa_common_site/name=Eclipse 4.7qa Repository"
      targetURL="${install.root|uri}/.p2/org.eclipse.equinox.p2.engine/profileRegistry/${installation.location|pathEncode}_eclipse.profile/.data/.settings/org.eclipse.equinox.p2.artifact.repository.prefs"
      encoding="UTF-8"/>
</xmi:XMI>
Wondering if this is worth putting up on the Authoring Wiki as an example similar to PDE example etc.
I really appreciate your quick turnaround for this fix. It has made my life much easier.... until my next roadblock
[Updated on: Tue, 10 April 2018 23:45] by Moderator
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785215 is a reply to message #1785211] Wed, 11 April 2018 02:09 Go to previous messageGo to next message
I'm glad that it works. I also agree with Ed, that new variables would be more direct and easier to use in this case. If you open a bugzilla we can look at that.
Re: Forcing a P2 Update site inside the Eclipse "Update Sites" preferences [message #1785260 is a reply to message #1785215] Wed, 11 April 2018 12:27 Go to previous message
I'll look at the bugzilla later, restrictions limit it currently.
One thing to note for those reading this thread, As of April 11 2018 - you will need to also patch your Eclipse Install to either auto-update to the April 10 2018 oomph.setup.ui feature or patch the core install.
Previous Topic:Subproject selection behaviour
Next Topic:Filter by path pattern in Dynamic Working Sets
Current Time: Wed Jul 23 23:29:29 EDT 2025
Powered by FUDForum. Page generated in 0.05215 seconds
