Different types of files that acceleo can generate [message #1784730] |
Tue, 03 April 2018 06:22  |
Good morning,
I want to generate a .qml file from an Ecore model using acceleo, I'm using Eclipse JUNO, I've succeeded in generating different files .h and .cpp but I couldn't manage to find the "property" that's responsible in determining the generated file type (.cpp/ .js/ .qml or any other type).
So, how can I determine the type (extension) of the generated file?)
Thank u in advance ^^
Re: Different types of files that acceleo can generate [message #1784782 is a reply to message #1784756] |
Wed, 04 April 2018 03:41   |
Good morning,
So I guess this is the java code, you'll find it below, that I should manipulate in order to get my .qml file ?!
* This can be used to launch the generation from a standalone application.
* @param args
* Arguments of the generation.
* @generated
try {
if (args.length < 2) {
System.out.println("Arguments not valid : {model, folder}.");
} else {
URI modelURI = URI.createFileURI(args[0]);
File folder = new File(args[1]);
List<String> arguments = new ArrayList<String>();
* If you want to change the content of this method, do NOT forget to change the "@generated"
* tag in the Javadoc of this method to "@generated NOT". Without this new tag, any compilation
* of the Acceleo module with the main template that has caused the creation of this class will
* revert your modifications.
* Add in this list all the arguments used by the starting point of the generation
* If your main template is called on an element of your model and a String, you can
* add in "arguments" this "String" attribute.
Generate generator = new Generate(modelURI, folder, arguments);
* Add the properties from the launch arguments.
* If you want to programmatically add new properties, add them in "propertiesFiles"
* You can add the absolute path of a properties files, or even a project relative path.
* If you want to add another "protocol" for your properties files, please override
* "getPropertiesLoaderService(AcceleoService)" in order to return a new property loader.
* The behavior of the properties loader service is explained in the Acceleo documentation
* (Help -> Help Contents).
for (int i = 2; i < args.length; i++) {
generator.addPropertiesFile(args[i]);
generator.doGenerate(new BasicMonitor());
} catch (IOException e) {
e.printStackTrace();
FUDForum. Page generated in 0.05231 seconds
