Home » Eclipse Projects » BPMN 2.0 Modeler » Feature null
Feature null [message #1782798] Thu, 01 March 2018 10:07 Go to next message
I'm having an other problem.
I can display my customTask. But in the PropertySection class, in the createBindings() part, I have this very classic code.
TargetRuntime rt = getTargetRuntime();
CustomTaskDescriptor ctd = rt.getCustomTask(CUSTOM_TASK_ID);
EStructuralFeature feature = ctd.getModelDecorator().getEStructuralFeature(be, "myTaskConfig");
But the EStructuralFeature feature is always null.
What does it means ?
Re: Feature null [message #1782809 is a reply to message #1782798] Thu, 01 March 2018 13:06 Go to previous messageGo to next message
And I have a Java exception when I open or create a BPMN diagram :
org.eclipse.core.runtime.AssertionFailedException: null argument:
	at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
	at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
	at org.eclipse.bpmn2.modeler.core.runtime.Bpmn2SectionDescriptor.addAppliesToClass(Bpmn2SectionDescriptor.java:156)
	at org.eclipse.bpmn2.modeler.core.runtime.Bpmn2SectionDescriptor.<init>(Bpmn2SectionDescriptor.java:116)
	at org.eclipse.bpmn2.modeler.core.runtime.PropertyTabDescriptor.<init>(PropertyTabDescriptor.java:67)
	at sun.reflect.GeneratedConstructorAccessor20.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at org.eclipse.bpmn2.modeler.core.runtime.TargetRuntime.createRuntimeExtensionDescriptor(TargetRuntime.java:933)
	at org.eclipse.bpmn2.modeler.core.runtime.TargetRuntime.loadExtensions(TargetRuntime.java:902)
	at org.eclipse.bpmn2.modeler.core.runtime.TargetRuntime.createTargetRuntimes(TargetRuntime.java:526)
	at org.eclipse.bpmn2.modeler.ui.adapters.Bpmn2EditorItemProviderAdapterFactory$Bpmn2ExtendedPropertiesSwitch.<init>(Bpmn2EditorItemProviderAdapterFactory.java:188)
	at org.eclipse.bpmn2.modeler.ui.adapters.Bpmn2EditorItemProviderAdapterFactory.<init>(Bpmn2EditorItemProviderAdapterFactory.java:178)
	at org.eclipse.bpmn2.modeler.ui.Activator.<clinit>(Activator.java:61)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:763)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:716)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
	at org.eclipse.osgi.container.Module.doStart(Module.java:581)
	at org.eclipse.osgi.container.Module.start(Module.java:449)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin.lambda$0(WorkbenchPlugin.java:288)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:285)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:232)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:293)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:331)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:955)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:992)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:661)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:767)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:738)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:716)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1293)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:675)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:546)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:530)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:137)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:79)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:61)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:704)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1076)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Re: Feature null [message #1783025 is a reply to message #1782809] Tue, 06 March 2018 13:00 Go to previous messageGo to next message
I based my extension on the example org.eclipse.bpmn2.modeler.examples.dynamic.
If I don't define a PropertySection class for my customTask, I can use my extension without error (but of course I can't change the values of my properties).
If I define a PropertySection class, I got the AssertionFailedException.
However, I use the same PropertySection class as in the dynamic example.
Any idea ?
Re: Feature null [message #1784586 is a reply to message #1783025] Thu, 29 March 2018 12:53 Go to previous messageGo to next message
Anybody has an idea ?
Re: Feature null [message #1784669 is a reply to message #1784586] Sun, 01 April 2018 16:36 Go to previous messageGo to next message
have you tried to get the feature directly form your be class:
for (ExtensionAttributeValue eav : be.getExtensionValues()) {
           // check all extensionAttribute values...
           for (FeatureMap.Entry entry : eav.getValue()) {
              if (entry.getEStructuralFeature() == feature) {
Ralph
[Updated on: Sun, 01 April 2018 16:38] by Moderator
Re: Feature null [message #1784670 is a reply to message #1784669] Sun, 01 April 2018 16:44 Go to previous messageGo to next message
Also take a look at the tutorial code:
https://github.com/rsoika/bpmn2-tutorial
Let me know if you solved your problem.
Ralph
Re: Feature null [message #1784926 is a reply to message #1784670] Thu, 05 April 2018 17:19 Go to previous message
I solved the problem (I made an error in the PropertySection...).
Thank you for helping.
Previous Topic:Icon in the customTask shape
Next Topic:BPMN Plugin extraction
Current Time: Sat Jul 19 01:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.06526 seconds
