Home » Modeling » VIATRA » Annotation of @Edge can't work
Annotation of @Edge can't work [message #1784454] Wed, 28 March 2018 03:42 Go to next message
Today, I research on the EMF-inquery example of 'emfxcel'(https://github.com/viatra/EMF-IncQuery-Examples/tree/master/emfxcel), I found it adapt to VIATRA2(My version is 1.5.1), so I modified the suffix of query file and some dependencies. Then I found in the 'Query Results' exporer I can see the the query result, and when I "reinitialize VIATRA viewer " , only seperate student and teacher nodes are displayed in the 'Zest Graph' view, but the edges cann't be shown, Did I omit any part to be modified ?
Thanks in advance!
Re: Annotation of @Edge can't work [message #1784455 is a reply to message #1784454] Wed, 28 March 2018 03:51 Go to previous messageGo to next message
in general, the annotated patterns from that example should work if the model contains corresponding matches. More precisely, an Edge is only shown when both the `source` and `target` parameters represent an EMF model object that have a corresponding match where it is used as an Item. In other words, I would look at the matches of both the Item and Edge patterns, and ensure they are in synch.
If this is not helpful, I'd look at the example if you could share somehow the current version with an example model specified.
Zoltán
[Updated on: Wed, 28 March 2018 03:52] by Moderator
Re: Annotation of @Edge can't work [message #1784461 is a reply to message #1784455] Wed, 28 March 2018 04:48 Go to previous messageGo to next message
Sorry, it is hard for me to share my current verti with u, But I can describe my problem as detailed as possible, also you can get the example from https://github.com/viatra/EMF-IncQuery-Examples/tree/master/emfxcel.
Edge annotation is defined as follows:
@Edge(source = studentId, target = teacherName, label = "taughtBy")
pattern enrolledStudent(courseName, teacherName, studentId) {
find valueInNamedColumn("Courses", "Course", rowNum, courseName);
find valueInNamedColumn("Courses", "Teacher", rowNum, teacherName);
find valueInNamedColumn("Courses", "Student Identifier", rowNum, studentId);
Query result and zest graph are shown in attacnment.
Re: Annotation of @Edge can't work [message #1784462 is a reply to message #1784461] Wed, 28 March 2018 04:55 Go to previous messageGo to next message
looking at the screenshots, I see that students are represented by IDs, e.g. 'AH2'; but there is no node named 'AH2' in the Zest graph. This means to me that there is no pattern marked with @Item that enumerates the students for the visualization; and thus the edge cannot be displayed. I see a potential pattern in https://github.com/viatra/EMF-IncQuery-Examples/blob/master/emfxcel/net.istvanrath.emfxcel.incquery/src/net/istvanrath/emfxcel/incquery/demo/SzakiranyDemo.eiq#L26 that could be used for this case.
Zoltán
Re: Annotation of @Edge can't work [message #1784464 is a reply to message #1784462] Wed, 28 March 2018 05:13 Go to previous messageGo to next message
student Item annotation is below,
@Item(item = id, label = "$name$")
pattern student(name, id) {
find valueInNamedColumn("Students", "First name", rowNum, firstName);
find valueInNamedColumn("Students", "Last name", rowNum, lastName);
find valueInNamedColumn("Students", "Identifier", rowNum, id);
name == eval(firstName + " " + lastName);
we can see it just use the student's name as the label content, that will not change object of students. And above pattern also works well. refer to attachments.
Re: Annotation of @Edge can't work [message #1784466 is a reply to message #1784464] Wed, 28 March 2018 05:20 Go to previous messageGo to next message
You are right, I have missed this pattern and the matching by name. I don't have any idea right now what might be incorrect, so I have to try it out. For that, I also have to update the example; and thus I also have to forward-port. I will try to allocate some time for that, but I don't know how soon I will be able to do that.
Zoltán
Re: Annotation of @Edge can't work [message #1784476 is a reply to message #1784466] Wed, 28 March 2018 08:16 Go to previous messageGo to next message
Thanks for your attention, I try to solve the problem but fail. So hope for your modification!
Re: Annotation of @Edge can't work [message #1790139 is a reply to message #1784476] Tue, 05 June 2018 15:32 Go to previous message
I am sorry for being so slow to reproduce the example and find the answer. The short answer is that this example does not work correctly; all current versions of VIATRA Viewers (including the version 1.5.1 you were using) does only support drawing edges between EObject instances, but does not work for plain Java models, such as Strings used in the current example. I have opened a bug in our issue tracker to look for the root cause of this issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=535568
For a bit more detail: when the original EMFxcel example was developed, Viewers had an older implementation that worked with Java Objects, but in the meantime, the internal behavior was replaced completely, and for some reason we have missed the case for connecting Java Objects in the visualization.
As a workaround, please write your patterns in a way that creates Items to be connected from EMF model elements instead of Java objects such as names.
Sorry for the inconvenience,
Zoltán
Previous Topic:Simscape Support for Massif
Next Topic:Querying FeatureMap constructs ?
Current Time: Wed Jul 30 07:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.05594 seconds
