Home » Eclipse Projects » Eclipse Scout » properties are not found while starting client in dev mode(properties are not found while starting client in dev mode in Helloworld app)
properties are not found while starting client in dev mode [message #1784331] Mon, 26 March 2018 18:55 Go to next message
Could someone guide me what is the problem.
When I'm trying to run client of HelloWorld sample app according to 'Scout for beginners guide' I get error as follows:
2018-03-27 01:28:46,275 INFO  [Thread-9] org.eclipse.scout.rt.shared.servicetunnel.RegisterTunnelToServerPlatformListener.registerTunnelToServerProxies(RegisterTunnelToServerPlatformListener.java:68) - Tunnel to server proxies registered. - MDC[]
2018-03-27 01:28:46,288 ERROR [Thread-9] org.eclipse.scout.rt.platform.internal.PlatformImplementor.validateConfiguration(PlatformImplementor.java:192) - Config property with key 'scout.ui.prebuild.files' does not exist or has an invalid value. - MDC[]
2018-03-27 01:28:46,288 ERROR [Thread-9] org.eclipse.scout.rt.platform.internal.PlatformImplementor.validateConfiguration(PlatformImplementor.java:192) - Config property with key 'scout.ui.prebuild' does not exist or has an invalid value. - MDC[]
2018-03-27 01:28:46,288 ERROR [Thread-9] org.eclipse.scout.rt.platform.internal.PlatformImplementor.validateConfiguration(PlatformImplementor.java:192) - Config property with key 'scout.ui.theme' does not exist or has an invalid value. - MDC[]
2018-03-27 01:28:46,317 ERROR [Thread-9] org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:144) - Error during platform startup - MDC[]
org.eclipse.scout.rt.platform.exception.PlatformException: Cannot start platform due to 3 invalid config properties: [scout.ui.prebuild.files, scout.ui.prebuild, scout.ui.theme]
	at org.eclipse.scout.rt.platform.internal.PlatformImplementor.validateConfiguration(PlatformImplementor.java:196)
	at org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:137)
	at org.eclipse.scout.rt.platform.internal.PlatformStarter.run(PlatformStarter.java:29)
Exception in thread "Thread-9" org.eclipse.scout.rt.platform.exception.PlatformException: Cannot start platform due to 3 invalid config properties: [scout.ui.prebuild.files, scout.ui.prebuild, scout.ui.theme]
2018-03-27 01:28:46,318 WARN  [main] org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:549) - Failed startup of context o.e.s.d.j.P_WebAppContext@23fe1d71{/,file:///D:/eclipse-workspace/helloworld/helloworld.ui.html.app.dev/src/main/webapp/,UNAVAILABLE} - MDC[]
org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
	at org.eclipse.scout.rt.platform.internal.PlatformImplementor.throwOnPlatformInvalid(PlatformImplementor.java:94)
	at org.eclipse.scout.rt.platform.internal.PlatformImplementor.awaitPlatformStarted(PlatformImplementor.java:84)
	at org.eclipse.scout.rt.server.commons.WebappEventListener.contextInitialized(WebappEventListener.java:43)
	at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:876)
	at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:532)
	at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:839)
	at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:344)
	at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1480)
	at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1442)
	at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:799)
	at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:261)
	at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:540)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131)
	at org.eclipse.jetty.server.Server.start(Server.java:452)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:105)
	at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
	at org.eclipse.jetty.server.Server.doStart(Server.java:419)
	at org.eclipse.scout.dev.jetty.JettyServer.start(JettyServer.java:95)
	at org.eclipse.scout.dev.jetty.JettyServer.main(JettyServer.java:56)
2018-03-27 01:28:46,341 INFO  [main] org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:280) - Started ServerConnector@28c4711c{HTTP/1.1,[http/1.1]}{0.0.0.0:8082} - MDC[]
Exception in thread "main" org.eclipse.scout.rt.platform.exception.PlatformException: The platform is in an invalid state.
Nothing was changed after creating the project, so all settings are default.
I guess these files should be generated in dev mode but they are not.
IDE - Eclipse for Scout Developers
Version: Oxygen.3 Release (4.7.3)
Build id: 20180308-1800
Re: properties are not found while starting client in dev mode [message #1784342 is a reply to message #1784331] Tue, 27 March 2018 02:54 Go to previous messageGo to next message
Hi Anton
I've downloaded the Oxygen.3 Release, created a new Scout project and started client and server. Everything worked and both applications were started without any errors.
My generated config.properties of the UI app contains the following lines:
### UI
scout.ui.theme=application
scout.ui.prebuild=false
scout.ui.prebuild.files=/index.html,/login.html,/logout.html,/popup-window.html
Are these entries missing in your generated file (helloworld.ui.html.app.dev\src\main\resources\config.properties)?
Kind regards
Stephan
Re: properties are not found while starting client in dev mode [message #1784349 is a reply to message #1784342] Tue, 27 March 2018 03:38 Go to previous messageGo to next message
Hi Stephan,
I have exact the same that you showed
### Application
scout.application.name=My Application
scout.application.version=development
### UI
### Environment
scout.dev.mode=true
#scout.auth.cookie.session.validate.secure=false
### Service tunnel
scout.server.url=http://localhost:8080
scout.auth.privatekey=MD4CAQAwEAYHKoZIzj0CAQYFK4EEAAoEJzAlAgEBBCB9jHQ9uIhvoZyH+vgMgH98Vocqiaqx/Dn7BVkS8EvUuQ==
### Security
scout.auth.credentials=admin:admin;scott:tiger
scout.auth.credentials.plaintext=true
### Storage location for FileSystemUserPreferencesStorageService
user.area=${user.home}/org.eclipse.scout.apps-helloworld.ui.html.dev
Maybe something with my env settings . As I new to Eclipse I guess that something is missed...Weird
Is there any additional settings in Eclipse for Windows environment, I mean directories , paths etc...?
Re: properties are not found while starting client in dev mode [message #1784350 is a reply to message #1784349] Tue, 27 March 2018 03:48 Go to previous messageGo to next message
Hi Anton
What is the value of the property 'org.eclipse.scout.rt.version' in the helloworld/pom.xml?
Mat
Re: properties are not found while starting client in dev mode [message #1784361 is a reply to message #1784350] Tue, 27 March 2018 05:04 Go to previous messageGo to next message
Hi Mat,
Here it is:
<properties>
		<org.eclipse.scout.apps.helloworld.version>${project.version}</org.eclipse.scout.apps.helloworld.version>
		<jdk.source.version>1.8</jdk.source.version>
		<org.eclipse.scout.rt.version>7.0.300.005_Oxygen_3</org.eclipse.scout.rt.version>
	</properties>
Anton
Re: properties are not found while starting client in dev mode [message #1784395 is a reply to message #1784361] Tue, 27 March 2018 11:19 Go to previous messageGo to next message
Hi Anton
This seems to be correct. I have the same values on my side.
Can you please add a breakpoint to org.eclipse.scout.rt.platform.config.ConfigPropertyValidator.isValid(String, String) on every line that may return false (should be two places).
Then you can start the application in debug mode and check why the property seems to be wrong.
Is the key part of the map getAllConfigProperties() within that class?
Thank you for your help
Mat
Re: properties are not found while starting client in dev mode [message #1784435 is a reply to message #1784395] Tue, 27 March 2018 19:31 Go to previous messageGo to next message
Hi Mat,
thanks for your suggestion
I checked it debug and see that it returns Property = null for:
scout.ui.theme
scout.ui.prebuild
and I did not find them in org.eclipse.scout.rt.platform.config classes.
https://eclipsescout.github.io/7.1/migration-guide.html#config-properties - there are also no information about changes with this properties.
Maybe these properties are somewhere else?
thanks, Anton
Re: properties are not found while starting client in dev mode [message #1784438 is a reply to message #1784435] Tue, 27 March 2018 21:01 Go to previous messageGo to next message
Actually, the issue was in org.eclipse.scout.rt.ui.html.7.0.300.005_Oxygen_3 package that has "invalid loc header (bad signature)" when I tried to reach it.
all problematic properties are in org.eclipse.scout.rt.ui.html.UiHtmlConfigProperties class, but since the package was not readable these properties could not be found.
Problem with package is happening when I am creating a new helloworld scout project and only with 7.0.300.005_Oxygen_3 , but If I change package manually afterwards - everything becomes fine.
Previous version 1.0.200... works ok even just to change pom.xml.
BR, Anton
Re: properties are not found while starting client in dev mode [message #1784448 is a reply to message #1784438] Wed, 28 March 2018 02:55 Go to previous messageGo to next message
Hi Anton
Not really sure, just a guess. Delete the appropriate file/folder in the local maven repo and fetch them again (Alt+F5 in Eclipse). Maybe the download of de JAR failed somehow.
Kind regards
Stephan
[Updated on: Wed, 28 March 2018 02:56] by Moderator
Re: properties are not found while starting client in dev mode [message #1784463 is a reply to message #1784448] Wed, 28 March 2018 04:56 Go to previous message
Hi Stephan,
Yeah, that works, thank you.
Will see why mvn downloading doesn't work properly..
BR,
Anton
Previous Topic:How to install Eclipse Oxygen Scout behind a proxy
Next Topic:[Oxygen] Eclipse Scout/ Spring Boot - MapStruct and Lombok and Maven
Current Time: Sat Jul 26 23:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.46920 seconds
