Home » Archived » Jubula » Jubula can not map objects on the installer that built by InstallAnywhere2015(Jubula can not map objects on the installer that built by InstallAnywhere2015)
Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1783977] Tue, 20 March 2018 22:40 Go to next message
Jubula can not map objects on any component like button and textfield on the SWING UI installer that built by InstallAnywhere2015.
After launching the installer through Jubula, the object mapping icon is active. I clicked it to get the component mapping id, but AUT will wait for nearly ten minutes, and reported error "Could not request components from AUT", see details below.
This installer is quite simple, it is SWING application, AUT cannot get the Next button on the first page.
Attachment please find the installer I tested, there are two files, installer.bat and installer.exe. Please use installer.bat as executable file, because installer.exe is regarded as non-executable jar file by Jubula.
Very appreciate for any suggestion.
2018-03-19 18:37:01.284 [Worker-879] ERROR o.e.j.c.c.c.AUTConnection - Error occurred while establishing connection to AUT.
org.eclipse.jubula.tools.internal.exception.CommunicationException: Could not request components from AUT.
at org.eclipse.jubula.client.core.communication.AUTConnection.getAllComponentsFromAUT(AUTConnection.java:494) [org.eclipse.jubula.client.core_6.0.0.201802230740.jar:na]
at org.eclipse.jubula.client.core.communication.AUTConnection.setup(AUTConnection.java:413) [org.eclipse.jubula.client.core_6.0.0.201802230740.jar:na]
at org.eclipse.jubula.client.core.communication.AUTConnection.connectToAutImpl(AUTConnection.java:260) [org.eclipse.jubula.client.core_6.0.0.201802230740.jar:na]
at org.eclipse.jubula.client.core.communication.AUTConnection.connectToAut(AUTConnection.java:178) [org.eclipse.jubula.client.core_6.0.0.201802230740.jar:na]
at org.eclipse.jubula.client.core.ClientTestImpl.startObjectMapping(ClientTestImpl.java:436) [org.eclipse.jubula.client.core_6.0.0.201802230740.jar:na]
at org.eclipse.jubula.client.ui.rcp.handlers.StartObjectMappingModeHandler$StartObjectMappingModeJob.run(StartObjectMappingModeHandler.java:157) [org.eclipse.jubula.client.ui.rcp_6.0.0.201802230740.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56) [org.eclipse.core.jobs_3.9.2.v20171030-1027.jar:na]
  • Attachment: install.zip
    (Size: 4.88MB, Downloaded 172 times)
[Updated on: Tue, 27 March 2018 03:57] by Moderator
Re: Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1784172 is a reply to message #1783977] Fri, 23 March 2018 04:26 Go to previous messageGo to next message
what toolkit does the AUT use?
Alex
Re: Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1784336 is a reply to message #1784172] Mon, 26 March 2018 21:48 Go to previous messageGo to next message
The toolkit I used is SWING
Re: Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1784352 is a reply to message #1784172] Tue, 27 March 2018 03:58 Go to previous messageGo to next message
I updated the attached installer I tested. There are two files, installer.bat and installer.exe. Please use installer.bat as executable file, because installer.exe is regarded as non-executable jar file by Jubula.
Re: Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1784777 is a reply to message #1783977] Wed, 04 April 2018 02:54 Go to previous messageGo to next message
Dear Tobi,
may I ask you which version of Jubula you are using?
Kind Regards
Elena
Re: Jubula can not map objects on the installer that built by InstallAnywhere2015 [message #1784780 is a reply to message #1784777] Wed, 04 April 2018 03:24 Go to previous message
Dear Toby,
I just tested it with Jubula version 8.4.1.123 as you see on the picture (Forum) I could map the lable, buttons and text components.
It is important that you configure your AUT correctly.
Please ensure that you selected the correct toolkit in the AUT configuration (see picture Forum2)
Kind Regards
Elena
  • Attachment: Forum2.PNG
    (Size: 18.07KB, Downloaded 169 times)
  • Attachment: Forum.PNG
    (Size: 184.94KB, Downloaded 168 times)
Previous Topic:Internal error 3003: Unexpected error occurred - NullPointerException
Next Topic:Web Automation - HTML
Current Time: Sun Jul 20 21:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.05245 seconds
