Home » Modeling » OCL » Generic Enumeration Literal
Generic Enumeration Literal [message #1783968] Tue, 20 March 2018 15:44 Go to next message
I have a number of UML classes that share a similar structure. An enumeration "X" has a number of values, including X::other. When a class instance has X::other for this attribute, then another attribute, OtherType must be defined. The OCL constraint looks something like this:
self.Type = X::other implies not self.OtherType.oclIsUndefined()
This works well enough. However, each class has its own enumeration (of a different type) so the explicit referencing of a classifier will not work if I try to apply this rule to multiple elements. I tried something like:
self.Type = self.Type.oclType()::other implies not self.OtherType.oclIsUndefined()
but received an error regarding the use of ::
Is there a way to accomplish this?
Re: Generic Enumeration Literal [message #1784116 is a reply to message #1783968] Thu, 22 March 2018 12:03 Go to previous message
Generic functionality generally requires reflection, which OMG OCL explicitly excludes although there are aspects of the specification that require it.
The Pivot-based Eclipse OCL used within Payprus supports reflection. oclType() returns an OCL::Class which is pretty similar to a UML::Class except that property names are rationalized, so something like (untested) oclType().oclAsType(pivot::Enumeration).ownedLiterals->select(name='other') might help you. (The cast to Enumeration should probably be unnecessary._
Ed Willink
Previous Topic:def / derive in interactive OCL console
Next Topic:Validate OCL from ecore standalone => Exception java.lang.NullPointerException: null
Current Time: Mon Jul 21 02:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.14499 seconds
