Failed to find org.eclipse.rcptt.tesla.swt.workbenchProvider [message #1783824] |
Sun, 18 March 2018 15:34  |
I'm currently trying to make our Eclipse based application works with the last version of Eclipse RCP TT.
I am able to launch the AUT, but as soon as I make an action on the menu bar the result is the following :
java.lang.NullPointerException: Failed to find org.eclipse.rcptt.tesla.swt.workbenchProvider extension. Is org.eclipse.rcptt.tesla.swt.e*x extension loaded?
at org.eclipse.rcptt.tesla.swt.workbench.EclipseWorkbenchProvider.initialize(EclipseWorkbenchProvider.java:44)
at org.eclipse.rcptt.tesla.swt.workbench.EclipseWorkbenchProvider.getProvider(EclipseWorkbenchProvider.java:22)
at org.eclipse.rcptt.tesla.recording.core.swt.SWTEventRecorder.processSelection(SWTEventRecorder.java:940)
at org.eclipse.rcptt.tesla.recording.core.swt.SWTEventRecorder.recordEvent_(SWTEventRecorder.java:576)
at org.eclipse.rcptt.tesla.recording.core.swt.SWTEventRecorder.recordEvent(SWTEventRecorder.java:438)
at org.eclipse.rcptt.tesla.recording.aspects.SWTEventManager.recordEvent(SWTEventManager.java:113)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$1$bd9fb3e7(RecordingAspect.aj:77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Widget.sendSelectionEvent_aroundBody6(Widget.java:1094)
at org.eclipse.swt.widgets.Widget$AjcClosure7.run(Widget.java:1)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$10$4cdd93e9proceed(RecordingAspect.aj:258)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$10$4cdd93e9(RecordingAspect.aj:279)
at org.eclipse.swt.widgets.Widget.sendSelectionEvent(Widget.java:1089)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDBLCLK(Tree.java:6394)
at org.eclipse.swt.widgets.Control.windowProc_aroundBody2(Control.java:4563)
at org.eclipse.swt.widgets.Control$AjcClosure3.run(Control.java:1)
at org.eclipse.rcptt.tesla.swt.aspects.EventFilterAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_EventFilterAspect$1$602baf3eproceed(EventFilterAspect.aj:17)
at org.eclipse.rcptt.tesla.swt.aspects.EventFilterAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_EventFilterAspect$1$602baf3e(EventFilterAspect.aj:19)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4523)
at org.eclipse.swt.widgets.Tree.windowProc_aroundBody2(Tree.java:5977)
at org.eclipse.swt.widgets.Tree$AjcClosure3.run(Tree.java:1)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5726)
at org.eclipse.swt.widgets.Display.windowProc_aroundBody20(Display.java:4989)
at org.eclipse.swt.widgets.Display$AjcClosure21.run(Display.java:1)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4928)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at com.all4tec.matelo.ui.Application.start(Application.java:98)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Any idea about the direction I should go or how I can debug this issue?
Thanks for your help!
Tony
FUDForum. Page generated in 0.04922 seconds
