Home » Archived » Eclipse SmartHome » [SOLVED] create_binding_skeleton errors(Errors when trying to create a binding skeleton with the script)
[SOLVED] create_binding_skeleton errors [message #1734777] Sat, 11 June 2016 16:09 Go to next message
I am trying to create a new binding, starting with the creation of a skeleton.
I cloned the repo https://github.com/eclipse/smarthome.git
When I run the script create_binding_skeleton.sh / or .cmd (tried both on linux/windows) in /extensions/binding I get the following error:
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 27.758 s
[INFO] Finished at: 2016-06-11T21:54:18+02:00
[INFO] Final Memory: 32M/78M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:2.4:generate (default-cli) on project pom: The desired archetype does not exist (org.eclipse.smarthome.archetype:org.eclipse.smarthome.archetype.binding.test:0.9.0-SNAPSHOT) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] ...
Any help to solve the issue is appreciated.
Thx, Juergen
[Updated on: Tue, 14 June 2016 17:05] by Moderator
Re: create_binding_skeleton errors [message #1734784 is a reply to message #1734777] Sun, 12 June 2016 05:48 Go to previous messageGo to next message
You need to first run a Maven build of the repo - or at least run a build within tools/archetype.
This info was indeed missing, I have added it to the OH2 documentation with https://github.com/openhab/openhab-docs/pull/21.
(In the ESH docu, we do not have any section that explains the archetype, is that correct? I at least couldn't find any...)
Kai
Re: create_binding_skeleton errors [message #1734788 is a reply to message #1734784] Sun, 12 June 2016 10:29 Go to previous messageGo to next message
works now.
Thx a lot.
Re: create_binding_skeleton errors [message #1783707 is a reply to message #1734788] Fri, 16 March 2018 00:13 Go to previous messageGo to next message
I am trying to use the create_binding_skeleton.cmd script to generate a ESB binding, but I am getting the same error as above. This is what I executed:
cd  openhab2-master\git\smarthome\tools\archetype
mvn install
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse SmartHome Archetypes 0.10.0-SNAPSHOT ....... SUCCESS [ 16.637 s]
[INFO] Eclipse Smarthome Binding Archetype ................ SUCCESS [ 16.831 s]
[INFO] Eclipse Smarthome Binding Archetype Testsuite 0.10.0-SNAPSHOT SUCCESS [  0.179 s]
[INFO] BUILD SUCCESS
cd ..\..\extensions\binding
create_binding_skeleton.cmd SampleBinding "Flavio Costa"
[WARNING] Archetype not found in any catalog. Falling back to central repository.
[WARNING] Add a repsoitory with id 'archetype' in your settings.xml if archetype's repository is elsewhere.
[INFO] Total time: 19.593 s
[INFO] Finished at: 2018-03-15T22:44:41-04:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:3.0.1:generate (default-cli) on project pom: The desired archetype does not exist (org.eclipse.smarthome.archetype:org.eclipse.smarthome.archetype.binding:0.10.0-SNAPSHOT) -> [Help 1]
I think the "run a build within tools/archetype" above would be covered by the mvn install executed first, but the error still comes up when trying to generate the code skeleton. I have both Eclipse Projects\Smart Home and Github projects\openHAB projects on my Eclipse IDE. What else could still be causing this error message?
Re: create_binding_skeleton errors [message #1783711 is a reply to message #1783707] Fri, 16 March 2018 04:00 Go to previous messageGo to next message
Hi Flavio,
the first execution and install of the two archetypes into your local maven repository looks good. However:
Please check if the generated archetype artifacts are present in your local maven repository. By default it can be found in <user_home>/.m2/repository/org/eclipse/smarthome/archetype
Also please check if you have a custom settings.xml for your maven installation which points to different repositories.
Re: create_binding_skeleton errors [message #1783782 is a reply to message #1783711] Sat, 17 March 2018 00:22 Go to previous messageGo to next message
Hi Henning,
Thanks for the prompt feedback. On .m2\repository\org\eclipse\smarthome\archetype I do see both archetypes:
dir
2018-03-15  22:20    <DIR>          .
2018-03-15  22:20    <DIR>          ..
2018-03-15  22:20    <DIR>          org.eclipse.smarthome.archetype.binding
2018-03-15  22:20    <DIR>          org.eclipse.smarthome.archetype.binding.test
               0 File(s)              0 bytes
               4 Dir(s)  291,777,130,496 bytes free
These two archetypes are also referenced on .m2\archetype-catalog.xml:
    <archetype>
      <groupId>org.eclipse.smarthome.archetype</groupId>
      <artifactId>org.eclipse.smarthome.archetype.binding</artifactId>
      <version>0.10.0-SNAPSHOT</version>
      <description>This is the Maven-Archetype for building new bindings for Eclipse SmartHome.</description>
    </archetype>
    <archetype>
      <artifactId>org.eclipse.smarthome.archetype.binding.test</artifactId>
      <description>This is the Maven-Archetype for building tests for bindings for Eclipse SmartHome.</description>
    </archetype>
If I am to follow the error messages from create_binding_skeleton.cmd, I understand that the system is not finding or considering this archetype-catalog.xml. Under .m2 subdirectories, I cannot find any find named settings.xml where I could "Add a repsoitory with id 'archetype'". Any idea why the relevant catalog is not being loaded?
Re: create_binding_skeleton errors [message #1785130 is a reply to message #1783782] Mon, 09 April 2018 16:56 Go to previous message
I have fixed the problem... it looks like create_binding_skeleton.cmd started working after I tried to execute create_openhab_binding_skeleton for the first time.
Not sure what is the dependency is between the two, and if this is something that should be expected in any way, but at least it seems to work fine now!
Previous Topic:Thoughts on a new Sitemap Concept
Next Topic:Is P2 is really necessary for Eclipse Smart Home core
Current Time: Mon Jul 21 07:20:19 EDT 2025
Powered by FUDForum. Page generated in 0.04333 seconds
