Home » Archived » BIRT » BIRT query is executed twice
BIRT query is executed twice [message #1782443] Fri, 23 February 2018 09:30 Go to next message
Hello all,
I have noticed that when generating a report with BIRT, the same SQL query is executed twice. First time with limit 1 and 2nd time with default limit.
2018-02-23T14:18:44.107184Z 4 Query SET SQL_SELECT_LIMIT=1
2018-02-23T14:18:44.107184Z 4 Query select id from game where id >= 1
2018-02-23T14:18:44.125145Z 4 Query SET SQL_SELECT_LIMIT=DEFAULT
2018-02-23T14:18:44.125145Z 4 Query select id from game where id >= 1
I'm using MySQL DB (5.7) - jdbc mysql driver 5.1.45 (I also tried it w/ 5.1.35). I tried it with BIRT 4.5, 4.6 and 4.7.
I also tried to add "?cacheResultSetMetadata=true" to the JDBC connection URL as it seems the first SQL is used to retrieve metadata (column names, types, etc.), but it didn't help.
It looks similar to this old bug - marked as resolved:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=234553
The issue is even worse when using report parameters as the first SQL does not use the parameters which provoke big performance issues:
2018-02-22T20:12:27.769128Z 51 Query SET SQL_SELECT_LIMIT=1
2018-02-22T20:12:27.769644Z 51 Query select id,username from customer where id = '' and username != ''
2018-02-22T20:12:27.783031Z 51 Query SET SQL_SELECT_LIMIT=DEFAULT
2018-02-22T20:12:27.783031Z 51 Query select id,username from customer where id = 123123 and username != 'dsdsadsa'
Any idea what I could do? This affects badly the performance of the report.
Leonardo
Re: BIRT query is executed twice [message #1783687 is a reply to message #1782443] Thu, 15 March 2018 10:19 Go to previous message
Anyone?
Previous Topic:BIRT XML Data Source tutorial
Next Topic:Multiline Parameter
Current Time: Thu Jul 24 23:48:54 EDT 2025
Powered by FUDForum. Page generated in 0.05970 seconds
