Problems with building a native app (FX Build Configuration) [message #1783170] |
Thu, 08 March 2018 12:33  |
Java 9.0.4
Eclipse 4.7.2
e(fx)clipse 3.0.0.201705220750
Building a swing app
target is a windows EXE
build.xml doesn't work.
Problem #1)
<file name="${java.home}\..\lib\ant-javafx.jar"/>
should be for java 9 (at least - dunno java 8)
<file name="${java.home}\lib\ant-javafx.jar"/>
Problem #2)
basedir is not a supported property of fx:platform
Problem #3)
After fixing problems #1 and #2 in the build, it still doesn't work, claiming it cannot find any modules.
Still working #3
Ideas?
Re: Problems with building a native app (FX Build Configuration) [message #1783646 is a reply to message #1783170] |
Wed, 14 March 2018 17:50   |
Upgraded to e(fx)clipse 3.1.0 , which should be more obviously available.
No change, so I guess it doesn't matter.
As for problem #3, using jmod to build modules from my code, and adding them to the build seems to work. Would be nice to have an ant task for jmod, but I can build that myself.
But, after that, Inno Setup exits code 2.
Wix gets a bit further, but now fussing with license files and desktop shortcuts not working.
Not sure if any of this stuff is supposed to work anyway. Really, really, not ready for prime time.
FUDForum. Page generated in 0.05916 seconds
