Help System under 3.4 [message #1781944] |
Wed, 14 February 2018 16:51  |
Hi everybody,
I cannot use the help system under RAP 3.4 due to the incompatibility of the javax.servlet library.
The help system needs javax.servlet 3.0 oder earlier. I used to link javax.servlet.jar 2.4. to the bundle list.
However, RAP 3.4. needs javax.servlet 3.1 or higher.
If I start the RAP application with javax.servlet 3.0 the whole web app cannot be started due to the missing class javax/servlet/http/HttpSessionIdListener. This is a new class in 3.1 that RAP 3.4 apparently needs.
If, however, I add javax.servlet 3.1 to the runtime environment, the help system does not work due to incopatibilities with the other libraries. One of the error messages is: org.apache.jasper.JasperException: java.lang.ClassNotFoundException: org.apache.jsp.index_jsp
If I add both libraries of javax.servlet to the bundle list, the bundle rg.eclipse.equinox.jsp.jasper.registry gets problems, because it resolves both javax.servlet libraries via different ways.
Can anybody give me hints how to run the help system under RAP 3.4?
Thanks for your help in advance!
Sebastian
Re: Help System under 3.4 [message #1782004 is a reply to message #1781955] |
Thu, 15 February 2018 15:07   |
Hi Ivan,
Thank you very much for your fast response!
The bundle, that tries to instantiate the HttpSessionIdListener is indeed org.eclipse.equinox.http.jetty_3.4.0.v20170503-2025.jar.
The Class-not-found exception can be seen below. This exception is thrown, when javax.servlet 3.0 or lower is used. That makes sense, as the HttpSessionIdListener has been added in javax.servlet 3.1.
Interestingly, the bundle org.eclipse.equinox.http.jetty has the following imported package specification in the manifest:
javax.servlet;version="[2.6.0,4.0.0)",javax.servlet.ht
tp;version="[2.6.0,4.0.0)"
This should be wrong as the bundle requires a class from 3.1, shouldn't it?
Does these hints help you?
Sebastian
__________________________________________________
Caused by: java.lang.ClassNotFoundException: javax.servlet.http.HttpSessionIdListener cannot be found by org.eclipse.equinox.http.jetty_3.4.0.v20170503-2025
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
... 32 more
Re: Help System under 3.4 [message #1783507 is a reply to message #1782551] |
Tue, 13 March 2018 13:18   |
Hi all,
unfortunately, I still have a problem with running the help system in my rap application. The help system works fine, when I start the rap application from the eclipse development environment. However, if I deploy the application under tomcat, the help system won't start.
If I connect the osgi console to the tomcat web-app, I can see that the org.eclipse.help.webapp is installed (see screen shot). If I, however, try to start the bundle, it complains that javax.servlet cannot be resolved.
However, the bundle should not be added according to the rap documentation.
Has somebody an idea, how I could solve this problem?
Thanks in advance,
Sebastian
Re: Help System under 3.4 [message #1783588 is a reply to message #1783507] |
Wed, 14 March 2018 08:22  |
Hi all,
I found a way to solve the problem. I had to modify the Manifest.mf in the org.eclipse.help.webapp_3.9.1.v20170816-0843.jar bundle.
In the manifest there was the following import requirement:
Import-Package: com.ibm.icu.text;version="3.8.0",javax.servlet;version
="3.1.0",javax.servlet.http;version="3.1.0",org.osgi.service.http;ver
sion="1.2.0"
I removed the dependency from javax.servlet und javax.servlet.http from the manifest. Then the help system could be used again.
Sebastian
FUDForum. Page generated in 0.04591 seconds
