Home » Eclipse Projects » e(fx)clipse » Problems with building a native app (FX Build Configuration)
Problems with building a native app (FX Build Configuration) [message #1783170] Thu, 08 March 2018 12:33 Go to next message
Java 9.0.4
Eclipse 4.7.2
e(fx)clipse 3.0.0.201705220750
Building a swing app
target is a windows EXE
build.xml doesn't work.
Problem #1)
<file name="${java.home}\..\lib\ant-javafx.jar"/>
should be for java 9 (at least - dunno java 8)
<file name="${java.home}\lib\ant-javafx.jar"/>
Problem #2)
basedir is not a supported property of fx:platform
Problem #3)
After fixing problems #1 and #2 in the build, it still doesn't work, claiming it cannot find any modules.
Still working #3
Ideas?
Re: Problems with building a native app (FX Build Configuration) [message #1783646 is a reply to message #1783170] Wed, 14 March 2018 17:50 Go to previous messageGo to next message
Upgraded to e(fx)clipse 3.1.0 , which should be more obviously available.
No change, so I guess it doesn't matter.
As for problem #3, using jmod to build modules from my code, and adding them to the build seems to work. Would be nice to have an ant task for jmod, but I can build that myself.
But, after that, Inno Setup exits code 2.
Wix gets a bit further, but now fussing with license files and desktop shortcuts not working.
Not sure if any of this stuff is supposed to work anyway. Really, really, not ready for prime time.
Re: Problems with building a native app (FX Build Configuration) [message #1784502 is a reply to message #1783646] Wed, 28 March 2018 15:00 Go to previous messageGo to next message
Please file a ticket at https://github.com/eclipse/efxclipse-eclipse - but I can guarantee to take a look at this soon :-(
Re: Problems with building a native app (FX Build Configuration) [message #1806973 is a reply to message #1783170] Mon, 20 May 2019 08:56 Go to previous messageGo to next message
jdk1.8.0_202
Eclipse Version: 2018-12 (4.10.0)
e(fx)clipse 3.3.0
Building a javafx app
I downloaded and installed Inno Setup 6.0.2. When working in Eclipse, I received the message: Detected [iscc.exe] version 0 but version 5 is required. Advice to fix: Download Inno Setup 5 or later from http://www.jrsoftware.org and add it to the PATH.
I checked up. Indeed version 0. Download versions 5.6.0 and 5.5.9. History repeated. I texted to Inno Setup developers and got reply: You should ask the Eclipse people to remove this check or to implement it in a proper way.
In the mean time I will readd a version number to the ISCC banner even though one shouldn't use that to try and detect a version.
Greetings,
Martijn Laan
Is there a solution to this problem?
[Updated on: Thu, 30 May 2019 09:37] by Moderator
Re: Problems with building a native app (FX Build Configuration) [message #1807866 is a reply to message #1806973] Tue, 11 June 2019 04:05 Go to previous message
I'm sorry but we can't do anything here until the new packager from OpenJDK is released. All we do it to call out to java-packager
Previous Topic:Code Compensator Dependecies?
Next Topic:Product based on efxclipse 3.5 can not be build in Tycho with Maven 3.6.1
Current Time: Wed Sep 03 17:40:11 EDT 2025
Powered by FUDForum. Page generated in 0.07205 seconds
