Home » Newcomers » Newcomers » Problem installing and running Eclipse(Run Eclipse(oxygen) and it shuts down without starting)
Problem installing and running Eclipse [message #1782912] Sun, 04 March 2018 16:51 Go to next message
I just downloaded eclipse oxygen. Was having a hard time installing it and i followed the instructions in askubuntu
Even the Eclipse main site, i though everything will be there in 'Getting started' but wasn't.
I want to use it for Java and J2EE.
I'm using Ubuntu 16.04 LTS.
Re: Problem installing and running Eclipse [message #1782914 is a reply to message #1782912] Sun, 04 March 2018 21:55 Go to previous messageGo to next message
Connel Asikong wrote on Sun, 04 March 2018 16:51
This doesn't actually tell us what those instructions were, which file you downloaded, or anything about the specific problem you're having. Could you explain those?
[Updated on: Sun, 04 March 2018 21:56] by Moderator
Re: Problem installing and running Eclipse [message #1782931 is a reply to message #1782914] Mon, 05 March 2018 06:06 Go to previous message
https://askubuntu.com/questions/26632/how-to-install-eclipse this is the site i got it from.
I downloaded the eclipse-oxygen the latest.
After much frustration on installing it on Ubuntu16.04LTS it finally looked like it install cos i change the 'eclipse.desktop' file to executable.
Now i can search eclipse on applications and see it, open it but won't load.
Previous Topic:you are installing software that contains unsigned content
Next Topic:Templates created in RAD not working in Eclipse
Current Time: Wed Jul 30 17:08:52 EDT 2025
Powered by FUDForum. Page generated in 0.09252 seconds
