[CDT 9.2] Run/Debug Configurations are HORROR ... [message #1782898] |
Sun, 04 March 2018 05:18  |
Where is the fucking manual for arguments specification ???
Else what is the logic ???
Use Case :
Here is submitted to the argument line (Debug configuations -> Arguments -> Program arguments) :
${project_loc_loc}${system_property:file.separator}intern${system_property:file.separator}
What is expected on Windows :
<project effective path>\intern\
What is actually obtained :
<project effective path>intern
Ok ! anti-slash is the special character. Well, I adapt :
${project_loc}\${system_property:file.separator}intern\${system_property:file.separator}
Obtained :
<project effective path>\\\\intern\\\\
My god ...
As a result :
The argument line interpreter acts like this :
- if there is a single anti-slash, then delete it
- if there are two consecutive anti-slashes, then double them.
So, it never returns a single anti-slash.
Don't mind ... trying with single quote enclosure :
${project_loc}'${system_property:file.separator}intern${system_property:file.separator}'
Obtained:
<project effective path>'\\intern\\'
Great ... not only anti-slashes are doubled inside single quotes but single quotes are preserved ...
True to its principle: follow no functional logic...
trying with double quote enclosure :
${project_loc}"${system_property:file.separator}intern${system_property:file.separator}"
Obtained ... A nightmare :
<project effective path>\\intern\"
The opening double quote is removed but the closing one, the first anti-slash is double but not the second one while it is in the same condition as the first one.
Can't be understood.
The software designer was drunk...
Is there a documentation about the argument line syntax ?
Else, how to make this right ?
I fed up.
Thanks a lot.
The one who has the solution must be rewarded.
[Updated on: Mon, 05 March 2018 06:36] by Moderator
Re: [CDT 9.2] Run/Debug Configurations are HORROR ... [message #1782932 is a reply to message #1782907] |
Mon, 05 March 2018 06:48  |
Thanks a lot, David.
I'm discovering :
What I want to do is not part of CDT but Eclipse workbench: to extend a variable path.
It is advisable to do this like documentation recommends.
This documentation is not there the user should expert to be.
And the contextual documentation itself is quiet about the subject. What a pity.
Thanks again and best regards, David.
[Updated on: Mon, 05 March 2018 06:48] by Moderator
FUDForum. Page generated in 0.03393 seconds
