Command in EditHelperAdvice [message #1782835] |
Fri, 02 March 2018 05:55  |
Hello everyone,
I created a new elementtype (derived from InvariantState) and I can add it to a sequence diagram. Well.
First, a stereotype is applied (thanks to a "Specialization Type Configuration"). Then, through an EditHelperAdvice class, a popup dialog box is opened to set an attribute of the stereotype. As a side option in the popup, I put a button to enable an easy access to another diagram.
What I want to obtain is the following behavior:
When the user click on the button:
- The pop up box is closed,
- The element is not created on the diagram (or delete immediately)
- And the wanted diagram is opened.
Unfortunately, I can't obtain this full behavior. Here is my simplified code (see comments in code)
protected ICommand getAfterConfigureCommand(final ConfigureRequest request) {
Shell shell = Display.getCurrent().getActiveShell();
EObject elementToConfigure = request.getElementToConfigure();
* some tests
CompositeCommand compositeCommand = new CompositeCommand("Configure created element");
// Create the dialogbox function of StateInvariant present on the lifeline
DialogBox dialog = new DialogBox(shell, elementToConfigure);
dialog.open();
if (IDialogConstants.OK_ID == dialog.getReturnCode()) {
//This is the standard case, not the problematic one
ICommand configureCommand = new ConfigureStateInvariantCommand(request, dialog.getSelectedEObject());
compositeCommand.add(configureCommand);
} else if (IDialogConstants.ABORT_ID == dialog.getReturnCode()) {
// the dialog box returns the ABORT_ID code when the famous button is clicked
ModelSet modelSet = getCurrentModelSet();
Resource notationResource = NotationUtils.getNotationResource(modelSet);
List<Diagram> diagramList = NotationUtils.getDiagrams(notationResource, dialog.getService());
for (Diagram diagram : diagramList) {
OpenDiagramCommand openDiagramCommand = new OpenDiagramCommand(modelSet.getTransactionalEditingDomain(), diagram);
compositeCommand.add(openDiagramCommand);
IElementEditService service = ElementEditServiceUtils.getCommandProvider(elementToConfigure);
DestroyElementRequest destroyRequest = new DestroyElementRequest(elementToConfigure, false);
compositeCommand.add(service.getEditCommand(destroyRequest));
return compositeCommand;
When I test this code and click on the famous button, the diagram that I want to open is opened but the element to create is not well destroyed. It is destroyed in the model but not in the diagram and I have an error message when reopening the model (dangling stereotype).
Is it a bug of the DestroyElementCommand or anything else?
What could be the workaround for this use case? I already tried to open directly the diagram in the listener of the button without success. Help would be greatly appreciated.
Thank you for reading.
Yoann.
FUDForum. Page generated in 0.12253 seconds
