Home » Eclipse Projects » Kura » LED not blinking on RPI3(gpio library)
LED not blinking on RPI3 [message #1782792] Thu, 01 March 2018 09:19 Go to next message
I am starting with Kura, and I wanted to turn on simple LEDs, I wrote this program in java and when I upload it to my PI it did't work.
Can anyone help me please.
protected void activate(ComponentContext componentContext) {
try {
KuraGPIOPin p = this.gpioService.getPinByTerminal(27, KuraGPIODirection.OUTPUT,
KuraGPIOMode.OUTPUT_OPEN_DRAIN, KuraGPIOTrigger.NONE);
p.open();
p.setValue(true);
System.out.println("=============LED is ON===================");
} catch (KuraGPIODeviceException e) {
e.printStackTrace();
} catch (KuraUnavailableDeviceException e) {
} catch (IOException e) {
} catch (KuraClosedDeviceException e) {
Re: LED not blinking on RPI3 [message #1782793 is a reply to message #1782792] Thu, 01 March 2018 09:21 Go to previous messageGo to next message
do you see any error in the log files?
The application is effectively running in the framework?
What is the status of the framework, accessing the OSGi console?
Matteo
Re: LED not blinking on RPI3 [message #1782797 is a reply to message #1782793] Thu, 01 March 2018 09:57 Go to previous messageGo to next message
Dear Matteo,
Thank you for your fast reply.
I didn't see any errors in the log, and I have attached a text file with the log ouput.
The state of the bundle is active.
I couldn't figure out the problem
Thank you for your helping
  • Attachment: log.txt
    (Size: 90.40KB, Downloaded 221 times)
Re: LED not blinking on RPI3 [message #1782800 is a reply to message #1782797] Thu, 01 March 2018 10:34 Go to previous messageGo to next message
I'm sorry, but the first thing I see from your log is an exception:
!MESSAGE [SCR] Exception while activating instance org.eclipse.kura.blink.Blink@6446d5 of component org.eclipse.kura.blink.Blink
!STACK 0
	at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
	at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
	at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)
	at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260)
	at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:343)
	at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222)
	at org.eclipse.equinox.metatype.impl.Activator$SAXParserFactoryTrackerCustomizer.registerMetaTypeService(Activator.java:229)
	at org.eclipse.equinox.metatype.impl.Activator$SAXParserFactoryTrackerCustomizer.swapFactories(Activator.java:143)
	at org.eclipse.equinox.metatype.impl.Activator$SAXParserFactoryTrackerCustomizer.addingService(Activator.java:137)
	at org.eclipse.equinox.metatype.impl.Activator$SAXParserFactoryTrackerCustomizer.addingService(Activator.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
	at org.eclipse.equinox.metatype.impl.Activator.start(Activator.java:69)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
	at org.eclipse.osgi.container.Module.doStart(Module.java:581)
	at org.eclipse.osgi.container.Module.start(Module.java:449)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
	at org.eclipse.kura.blink.Blink.activate(Blink.java:52)
	... 71 more
It seems that your bundle throws a NullPointerException.
Matteo
Re: LED not blinking on RPI3 [message #1782801 is a reply to message #1782800] Thu, 01 March 2018 10:55 Go to previous messageGo to next message
any suggestions what can cause that or how to solve it ?
Re: LED not blinking on RPI3 [message #1782803 is a reply to message #1782801] Thu, 01 March 2018 11:05 Go to previous messageGo to next message
No idea what corresponds to your line 52.
I would suggest to have a look and start protecting against null pointers.
Matteo
Re: LED not blinking on RPI3 [message #1782805 is a reply to message #1782803] Thu, 01 March 2018 11:27 Go to previous messageGo to next message
Dea Matteo,
Thank you very much for your fast replies
The line 53 :
KuraGPIOPin p = this.gpioService.getPinByTerminal(27, KuraGPIODirection.OUTPUT, KuraGPIOMode.OUTPUT_OPEN_DRAIN, KuraGPIOTrigger.NONE);
it looks fine for me;
can you help me please
Re: LED not blinking on RPI3 [message #1782806 is a reply to message #1782805] Thu, 01 March 2018 11:35 Go to previous message
I believe that the exception is thrown because this.gpioService is null.
Please give it a check and verify that you are correctly getting the gpioService.
Matteo
Previous Topic:how to resolve jdk.dio-CloseDeviceException
Next Topic:How to get advertisement data via new "BluetoothLeAdapter"
Current Time: Wed Jul 30 18:48:31 EDT 2025
Powered by FUDForum. Page generated in 0.06973 seconds
