Home » Archived » Eclipse SmartHome » New Build on Ubuntu 16.04 - Web services not loading(New Build on Ubuntu 16.04 - Web services not loading)
New Build on Ubuntu 16.04 - Web services not loading [message #1782657] Tue, 27 February 2018 07:43 Go to next message
I have a clean successful install on Ubuntu 16.04. According to the documentation, web services should be running and listening on port 8080 for Paper UI. I would also expect to see a port listening for the rest API. When I issue a netstat -lpn, these ports are not listed. I also notice that NPM and Node are not loaded. Are there additional steps I need to take in order to initiate these services?
Re: New Build on Ubuntu 16.04 - Web services not loading [message #1782746 is a reply to message #1782657] Wed, 28 February 2018 15:57 Go to previous message
Can you please explain the all steps that you have done (as much detailed as possible) to setup your ESH development environment?
Previous Topic:Override validateConfigurationParameters in binding to check config?
Next Topic:Eclipse SmartHome karaf Feature verification.......FAILURE
Current Time: Mon Jun 02 16:22:00 EDT 2025
Powered by FUDForum. Page generated in 0.04663 seconds
