Home » Eclipse Projects » RCP Testing Tool » Some text fields cannot be filled when replaying(The text fields in Dialog box cannot be filled when replayer)
Some text fields cannot be filled when replaying [message #1782523] Sun, 25 February 2018 17:16 Go to next message
Dear Sir/Madam:
Many thanks for your help in advance.
We have a large RCP application that needs automatic regression test every week. We are trying to use RCPTT recorder and replayer. We can record our test case successfully but some text fiels cannot be filled automatically when replaying. Could you please help?
Following is the ECL script:
get-view "Device Models" | get-table | select "VMS-3x18"
with [get-view Devices] {
click
get-button "Add a new device to the configuration" | click
with [get-window "Add a new VMS-3x18 Device"] {
get-editbox -after [get-label "Device ID"] | set-text VMS8
get-editbox -after [get-label "Device Name"] | set-text VMS8
get-button "Next >" | click
get-combo -after [get-label Controller] | select "RTA_SC::VMSC8"
get-editbox -after [get-label "Group Id"] | set-text 1
get-editbox -after [get-label "Sign Id"] | set-text 1
get-button Finish | click
get-view Devices | get-table | select "+VMS8" | get-menu -path "Remove Device(s)" | click
with [get-window "Remove Device(s)"] {
get-list | select VMS8
get-button OK | click
get-menu -path "File/Exit" | click
wait-until-eclipse-is-ready
The replay process does not work properly at (please check the attached picture):
There is no errors from the console.log or .log for this issue.
BTW: Where is the RCPTT code to execute the ECL scripts?
Re: Some text fields cannot be filled when replaying [message #1782615 is a reply to message #1782523] Tue, 27 February 2018 02:22 Go to previous messageGo to next message
Hi Aizhong,
RCPTT is open source and its code is placed here: https://github.com/xored/rcptt
According to your problem, try to replace
with
get-editbox -index 0 | set-text 1
get-editbox -index 1 | set-text 1
Will it work?
Re: Some text fields cannot be filled when replaying [message #1782641 is a reply to message #1782615] Tue, 27 February 2018 05:26 Go to previous messageGo to next message
Many thanks for your help, Viktoria.
I will try it tomorrow morning and let you know the result.
Alan
Re: Some text fields cannot be filled when replaying [message #1782684 is a reply to message #1782615] Tue, 27 February 2018 15:41 Go to previous messageGo to next message
Hi Viktoria,
I just checked your advice. Unfortunately, I am not lucky. It is not working.
I have got the rcptt code and make it running in my computer. Could you possibly let me know which project or package (tesla or ecl.core) I can trace when this issue happen?
Since our RCP application is large and complicate enough, if RCPTT can be successfully used in testing our application, it must be used in most of the RCP application test.
Following I took some log messages during running RCPTT from its code to test our application, our above test case started from "EclTcpSession:readInput", but I cannot debug it step by step. And I do not know where to take the log message for the test script (such as: get-editbox, get-label, ...) running. Please give some more advice.
Many thanks again for your advice.
>>>>>>EclTcpSession:localhost:7003
EclTcpSession:node:command:org.eclipse.rcptt.ecl.core.impl.SequenceImpl:start...
EMFStreamPipe:write:out:java.io.DataOutputStream:org.eclipse.rcptt.ecl.core.impl.SequenceImpl
object is SequenceImpl
EMFStreamPipe:write:eObject:org.eclipse.rcptt.ecl.core.impl.SequenceImpl
EMFStreamPipe:write:contents:org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsEList
ECLBinaryResourceImpl:doSave
ECLBinaryResourceImpl:outputStream:java.io.BufferedOutputStream
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.SequenceImpl@3a2d7 (host: null)
ECLBinaryResourceImpl:writeURI:uri:devicepath://www.eclipse.org/ecl/core.ecore:path:/ecl/core.ecore
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.PipelineImpl@41a28e00 (host: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@212be4c4 (host: null) (namespace: null, name: get-view) (column: 1, line: 1, length: 24, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:writeURI:uri:devicepath://www.eclipse.org/ecl/ast.ecore:path:/ecl/ast.ecore
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@2b3ae071 (name: null) (literal: Device Models, format: null) (column: 9, line: 1, length: 15, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@8b1e8ba (host: null) (namespace: null, name: get-table) (column: 28, line: 1, length: 9, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@7474b8b5 (host: null) (namespace: null, name: select) (column: 40, line: 1, length: 17, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@640a9a29 (name: null) (literal: VMS-3x18, format: null) (column: 46, line: 1, length: 10, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@287ffd46 (host: null) (namespace: null, name: with) (column: 1, line: 2, length: 100, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.ExecutableParameterImpl@6c7f138a (name: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@65968571 (host: null) (namespace: null, name: get-view) (column: 7, line: 2, length: 16, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@3d9fb59c (name: null) (literal: Devices, format: null) (column: 15, line: 2, length: 7, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@55a7d06a (name: null) (literal:
click
, format: null) (column: 24, line: 2, length: 76, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@6f24c71e (host: null) (namespace: null, name: with) (column: 1, line: 6, length: 384, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.ExecutableParameterImpl@33ab5313 (name: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@68fe5e9 (host: null) (namespace: null, name: get-window) (column: 7, line: 6, length: 38, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@5864fcf5 (name: null) (literal: Add a new VMS-3x18 Device, format: null) (column: 17, line: 6, length: 27, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@3e51c8f7 (name: null) (literal:
, format: null) (column: 46, line: 6, length: 338, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.PipelineImpl@6acc606e (host: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@6c8368e1 (host: null) (namespace: null, name: get-view) (column: 1, line: 15, length: 16, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@17c59e90 (name: null) (literal: Devices, format: null) (column: 9, line: 15, length: 7, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@57094aff (host: null) (namespace: null, name: get-table) (column: 20, line: 15, length: 9, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@52361e5a (host: null) (namespace: null, name: select) (column: 32, line: 15, length: 14, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@7e1f74b0 (name: null) (literal: +VMS8, format: null) (column: 38, line: 15, length: 7, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@54667f55 (host: null) (namespace: null, name: get-menu) (column: 49, line: 15, length: 33, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@4e391df4 (name: path) (literal: Remove Device(s), format: null) (column: 63, line: 15, length: 18, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@23d5c158 (host: null) (namespace: null, name: click) (column: 85, line: 15, length: 5, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@3f4b21b9 (host: null) (namespace: null, name: with) (column: 1, line: 16, length: 93, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.ExecutableParameterImpl@3699bd0d (name: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@1b07eaf5 (host: null) (namespace: null, name: get-window) (column: 7, line: 16, length: 29, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@3b4b643d (name: null) (literal: Remove Device(s), format: null) (column: 17, line: 16, length: 18, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@39cb27f0 (name: null) (literal:
, format: null) (column: 37, line: 16, length: 56, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.PipelineImpl@68896edb (host: null)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@7f871364 (host: null) (namespace: null, name: get-menu) (column: 1, line: 20, length: 26, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstLiteralImpl@40da73d (name: path) (literal: File/Exit, format: null) (column: 15, line: 20, length: 11, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.gen.ast.impl.AstExecImpl@1f934fc3 (host: null) (namespace: null, name: click) (column: 30, line: 20, length: 5, resourceID: _fIT2cBv7Eeiunu2wIgG6xA)
EclTcpSession:readInput:inputpipe:port:-1
EclTcpSession:readInput:pipe:port:7003
EclTcpSession:readInput:org.eclipse.core.runtime.Status
EMFStreamPipe:write:out:java.io.DataOutputStream:org.eclipse.core.runtime.Status
EMFStreamPipe:write:eObject:org.eclipse.rcptt.ecl.core.impl.ConvertedToEMFPipeImpl
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.ConvertedToEMFPipeImpl@696dfef5
ECLBinaryResourceImpl:saveEObject:org.eclipse.rcptt.ecl.core.impl.ProcessStatusImpl@380153a4 (pluginId: unknown, code: 0, message: OK, severity: 0)
EclTcpSession:writeOutput
EclTcpSession:writeOutput:outputpipe:port:-1
EclTcpSession:writeOutput:pipe:port:7003
EMFStreamPipe:take:in:java.io.DataInputStream
ECLBinaryResourceImpl:doLoad
ECLBinaryResourceImpl:inputStream:java.io.BufferedInputStream
CoreFactoryImpl:create:id:14:eClass:ConvertedToEMFPipe
TeslaFactory:create:eClass:TeslaProcessStatus:id:3
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@41d859e0 (id: a10d314, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-25, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@652c436c (id: 2f59f157, stackTrace: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.socketRead(SocketInputStream.java:116), java.net.SocketInputStream.read(SocketInputStream.java:171), java.net.SocketInputStream.read(SocketInputStream.java:141), java.io.BufferedInputStream.fill(BufferedInputStream.java:246), java.io.BufferedInputStream.read1(BufferedInputStream.java:286), java.io.BufferedInputStream.read(BufferedInputStream.java:345), org.openorb.orb.iiop.IIOPTransport.readMagic(Unknown Source), org.openorb.orb.iiop.IIOPTransport.recvMessage(Unknown Source), org.openorb.orb.iiop.SocketQueue.process_or_enqueue(Unknown Source), org.openorb.orb.iiop.SocketQueue.receive(Unknown Source), org.openorb.orb.iiop.IIOPClientChannel.run_recv(Unknown Source), org.openorb.orb.net.ClientManagerImpl$ChannelRecvRunnable.run(Unknown Source), java.lang.Thread.run(Thread.java:745)], threadName: Receive Worker for ClientChannel: (iiop) ANZ16WTSF2.TYCOFS.COM:54757 (61191 -> 54757), threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6330936a (id: 4893b980, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-44, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@519e70db (id: 75a37ebb, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: Thread-9, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@520a3451 (id: 2d05291f, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: Thread-8, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@55ba3a5f (id: 33650678, stackTrace: [java.lang.Object.wait(Native Method), java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143), java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164), org.geotools.util.WeakCollectionCleaner.run(WeakCollectionCleaner.java:77)], threadName: WeakCollectionCleaner, threadClass: org.geotools.util.WeakCollectionCleaner)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@32f65841 (id: 7124323b, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.rcptt.ecl.internal.core.Process.waitFor(Process.java:51), org.eclipse.rcptt.ecl.internal.commands.ExecService.exec(ExecService.java:83), org.eclipse.rcptt.ecl.internal.commands.ExecService.service(ExecService.java:54), org.eclipse.rcptt.ecl.ast.commands.AstExecService.service(AstExecService.java:29), org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83), org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48), org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)], threadName: Worker-2, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@104cfe6c (id: 3ef77de8, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-15, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1367e888 (id: c5ed57e, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: SRB Client Post Queue (61131->localhost/127.0.0.1:14142), threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@178b5079 (id: 2119bb3d, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-41, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@17bf3699 (id: 7d45ffd, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: Thread-26, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6077159c (id: 76aef382, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-26, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@4cf892b2 (id: 2e3b7b0b, stackTrace: [java.lang.Thread.sleep(Native Method), org.eclipse.rcptt.runtime.ui.Q7Monitor.run(Q7Monitor.java:28)], threadName: Q7 Runner Monitor, threadClass: org.eclipse.rcptt.runtime.ui.Q7Monitor)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1bd1bcc (id: ef342c2, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-7, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6f58fe9c (id: 5c77cb42, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), org.eclipse.rcptt.internal.core.jobs.JobManager.run(JobManager.java:406), java.lang.Thread.run(Thread.java:745)], threadName: Q7 Indexer, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@375bdd1e (id: 287f5642, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.rcptt.ecl.internal.core.Process.waitFor(Process.java:51), org.eclipse.rcptt.ecl.internal.commands.SequenceService.service(SequenceService.java:45), org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83), org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48), org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)], threadName: Worker-1, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@3f3ea445 (id: 24ccb18d, stackTrace: null, threadName: Attach Listener, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@5634ab15 (id: 58f0d3b6, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-33, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@7e300351 (id: 5c72e534, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-27, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@17ea92a4 (id: bfa82bd, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-23, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@5dbc0090 (id: 7bfb46b2, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-5, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2ea36431 (id: 384abf00, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-19, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@5077c03f (id: 50c40f8f, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-31, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@134b1727 (id: adb1197, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-34, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2e4e3d5e (id: ac94285, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-22, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1bf9564a (id: 3925aa6a, stackTrace: [java.lang.Object.wait(Native Method), java.util.TimerThread.mainLoop(Timer.java:552), java.util.TimerThread.run(Timer.java:505)], threadName: GT authority factory disposer, threadClass: java.util.TimerThread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@75e11b32 (id: 4c336d66, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: Thread-23, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@3ed8c886 (id: 433dd165, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-10, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6123b6ce (id: 340a5c52, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), tycoint.utility.jobqueue.JobQueue.run(JobQueue.java:164), java.lang.Thread.run(Thread.java:745)], threadName: Thread-5, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@30b9e7a6 (id: 67a725fe, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-35, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@4dfc5208 (id: 6f8aecd3, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-6, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@35183fc9 (id: 7fe68a5, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-20, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@49716a62 (id: 7e9ffdff, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-14, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@360a203d (id: 33d6bdb7, stackTrace: [java.lang.Object.wait(Native Method), java.util.TimerThread.mainLoop(Timer.java:552), java.util.TimerThread.run(Timer.java:505)], threadName: Timer-0, threadClass: java.util.TimerThread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@19c958e6 (id: 739c2dfe, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.rcptt.ecl.internal.core.Process.waitFor(Process.java:51), org.eclipse.rcptt.ecl.internal.commands.PipelineService.service(PipelineService.java:39), org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83), org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48), org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)], threadName: Worker-7, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6ddbda61 (id: 64d347b0, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1093), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1067), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: Active Thread: Equinox Container: 6ea8ae42-00fe-4e8d-8ff6-9ed059f78596, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2fbb8fc2 (id: 714f3e27, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-11, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@48d749c0 (id: 3d3efa54, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-24, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1b0a2654 (id: b2b3a40, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-38, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@28b1ef86 (id: 88432f5, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-1, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@5b87b0cd (id: e124366, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-32, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@29ec7b34 (id: 302f535b, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-28, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@631ec0db (id: 2f9739e0, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-9, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@4474cee1 (id: 47a55fdf, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-49, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@22931f7a (id: 7335164e, stackTrace: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.socketRead(SocketInputStream.java:116), java.net.SocketInputStream.read(SocketInputStream.java:171), java.net.SocketInputStream.read(SocketInputStream.java:141), java.io.BufferedInputStream.fill(BufferedInputStream.java:246), java.io.BufferedInputStream.read1(BufferedInputStream.java:286), java.io.BufferedInputStream.read(BufferedInputStream.java:345), org.openorb.orb.iiop.IIOPTransport.readMagic(Unknown Source), org.openorb.orb.iiop.IIOPTransport.recvMessage(Unknown Source), org.openorb.orb.iiop.SocketQueue.process_or_enqueue(Unknown Source), org.openorb.orb.iiop.SocketQueue.receive(Unknown Source), org.openorb.orb.iiop.IIOPClientChannel.run_recv(Unknown Source), org.openorb.orb.net.ClientManagerImpl$ChannelRecvRunnable.run(Unknown Source), java.lang.Thread.run(Thread.java:745)], threadName: Receive Worker for ClientChannel: (iiop) ANZ16WTSF2.TYCOFS.COM:58528 (61189 -> 58528), threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@68ece5c7 (id: 53a86a22, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-16, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@7de1f819 (id: 2d7eb3f4, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.rcptt.ecl.internal.core.Process.waitFor(Process.java:51), org.eclipse.rcptt.ecl.internal.commands.WithService.service(WithService.java:34), org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83), org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48), org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)], threadName: Worker-0, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1f002282 (id: 34a5dc29, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-43, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@255286d7 (id: 65cae15a, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-13, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2a1f9d67 (id: 27a18433, stackTrace: [java.lang.Object.wait(Native Method), java.util.TimerThread.mainLoop(Timer.java:552), java.util.TimerThread.run(Timer.java:505)], threadName: Timer-1, threadClass: java.util.TimerThread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@58cc990d (id: 3a7243e1, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-39, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@46c6b4a4 (id: 41c52f5d, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.rcptt.ecl.internal.core.Process.waitFor(Process.java:51), org.eclipse.rcptt.ecl.internal.commands.ExecService.exec(ExecService.java:83), org.eclipse.rcptt.ecl.internal.commands.ExecService.service(ExecService.java:54), org.eclipse.rcptt.ecl.ast.commands.AstExecService.service(AstExecService.java:29), org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83), org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48), org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)], threadName: Worker-4, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@7713e695 (id: 6e0a0baa, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-2, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@21b1a9b5 (id: a3ece9d, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-47, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@1d89487f (id: aa16802, stackTrace: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.socketRead(SocketInputStream.java:116), java.net.SocketInputStream.read(SocketInputStream.java:171), java.net.SocketInputStream.read(SocketInputStream.java:141), tycoint.utility.net.srb.ClientSocketConnection$ReceiveMessageThread.run(ClientSocketConnection.java:379)], threadName: SRB Client (61131->localhost/127.0.0.1:14142), threadClass: tycoint.utility.net.srb.ClientSocketConnection$ReceiveMessageThread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6e99acfe (id: c1dcdb9, stackTrace: null, threadName: Signal Dispatcher, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6d6d8f6 (id: 6f56e5c, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.run(TimerImpl.java:141), java.lang.Thread.run(Thread.java:745)], threadName: [Timer] - Main Queue Handler, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2a063598 (id: 3b477ce8, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-40, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@7d1b5a17 (id: 4840e7, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:59)], threadName: Worker-JM, threadClass: org.eclipse.core.internal.jobs.InternalWorker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@5ec6f716 (id: 78571fe6, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-17, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@6ee78550 (id: 1034f980, stackTrace: [java.lang.Object.wait(Native Method), org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:188), org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:220), org.eclipse.core.internal.jobs.Worker.run(Worker.java:52)], threadName: Worker-8, threadClass: org.eclipse.core.internal.jobs.Worker)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@75d6d7e1 (id: 10aa4210, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-48, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@52bae0ae (id: 675d209c, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-46, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@3badd3a8 (id: 143211f1, stackTrace: [java.lang.Object.wait(Native Method), java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143), java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164), sun.java2d.Disposer.run(Disposer.java:148), java.lang.Thread.run(Thread.java:745)], threadName: Java2D Disposer, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@69321c88 (id: 6ecd9708, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-42, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2a18a790 (id: 406794af, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078), java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418), java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1066), java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617), java.lang.Thread.run(Thread.java:745)], threadName: SRB Pool-29, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@2f228ded (id: 1a6c32a2, stackTrace: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:502), org.openorb.orb.net.ServerManagerImpl.wait_for_startup(Unknown Source), org.openorb.orb.net.ServerManagerImpl.access$000(Unknown Source), org.openorb.orb.net.ServerManagerImpl$ProtocolRunner.run(Unknown Source), java.lang.Thread.run(Thread.java:745)], threadName: Worker for ServerProtocol: (iiop) /0.0.0.0:61128, threadClass: java.lang.Thread)
ECLBinaryResourceImpl:loadEObject:org.eclipse.rcptt.tesla.core.info.impl.StackTraceEntryImpl@7a473b32 (id: 156542b7, stackTrace: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkN
Re: Some text fields cannot be filled when replaying [message #1783342 is a reply to message #1782684] Mon, 12 March 2018 04:59 Go to previous message
If you execute tests with RCPTT IDE, check execution details after the test fails (click 'Details...' button in 'Execution View')
The detailed info contains 'swt.info' section, it should help you to understand what controls RCPTT is able to verify
Check if it contains info about the test fields and verify if their labels are correct
Previous Topic:TestRunner not finding test suites in project
Next Topic:Error:process was terminated while waiting for aut startup data
Current Time: Sun Jul 27 10:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.05589 seconds
