Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782479] |
Fri, 23 February 2018 15:22  |
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse SmartHome .................................. SUCCESS [ 0.442 s]
[INFO] Eclipse SmartHome Bundles .......................... SUCCESS [ 0.127 s]
[INFO] Eclipse SmartHome Test Components .................. SUCCESS [ 0.056 s]
[INFO] Eclipse SmartHome Core Components .................. SUCCESS [ 0.110 s]
[INFO] Eclipse SmartHome Core ............................. FAILURE [ 19.859 s]
[INFO] Eclipse SmartHome Configurations ................... SKIPPED
[INFO] Eclipse SmartHome Configuration Core ............... SKIPPED
[INFO] Eclipse SmartHome Configuration XML ................ SKIPPED
[INFO] Eclipse SmartHome AutoUpdate Binding ............... SKIPPED
[INFO] Eclipse SmartHome Test ............................. SKIPPED
[INFO] Eclipse SmartHome I/O Components ................... SKIPPED
[INFO] Eclipse SmartHome Console .......................... SKIPPED
[INFO] Eclipse SmartHome Thing ............................ SKIPPED
[INFO] Magic Bundle ....................................... SKIPPED
[INFO] Magic Bundle Tests ................................. SKIPPED
[INFO] Eclipse SmartHome Auth Components .................. SKIPPED
[INFO] Eclipse SmartHome JAAS Authentication .............. SKIPPED
[INFO] Eclipse SmartHome Configuration Dispatcher ......... SKIPPED
[INFO] Eclipse SmartHome Configuration Dispatcher Tests ... SKIPPED
[INFO] Eclipse SmartHome Configuration Core Tests ......... SKIPPED
[INFO] Eclipse SmartHome Configuration Discovery .......... SKIPPED
[INFO] Eclipse SmartHome mDNS Service ..................... SKIPPED
[INFO] Eclipse SmartHome Configuration mDNS Discovery ..... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML ................... SKIPPED
[INFO] Eclipse SmartHome Configuration Discovery Tests .... SKIPPED
[INFO] Eclipse SmartHome Configuration UPnP Discovery ..... SKIPPED
[INFO] Eclipse SmartHome Configuration Serial ............. SKIPPED
[INFO] Eclipse SmartHome Config XML Tests ................. SKIPPED
[INFO] Eclipse SmartHome Core Audio ....................... SKIPPED
[INFO] Eclipse SmartHome Core Binding XML ................. SKIPPED
[INFO] Eclipse Smarthome Audio Test ....................... SKIPPED
[INFO] Eclipse SmartHome Sample Extension Service ......... SKIPPED
[INFO] Eclipse SmartHome REST Interface ................... SKIPPED
[INFO] Eclipse SmartHome Core ID .......................... SKIPPED
[INFO] Eclipse SmartHome ID Tests ......................... SKIPPED
[INFO] Eclipse SmartHome Core Tests ....................... SKIPPED
[INFO] Eclipse SmartHome Thing Tests ...................... SKIPPED
[INFO] Eclipse SmartHome Core Persistence ................. SKIPPED
[INFO] Eclipse SmartHome Core Scheduler Service ........... SKIPPED
[INFO] Eclipse SmartHome Core Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Core Binding XML Tests ........... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML Tests ............. SKIPPED
[INFO] Eclipse SmartHome Core Voice ....................... SKIPPED
[INFO] Eclipse SmartHome Core Voice Test .................. SKIPPED
[INFO] Eclipse SmartHome Automation ....................... SKIPPED
[INFO] Eclipse SmartHome Automation API ................... SKIPPED
[INFO] Eclipse SmartHome Automation Commands .............. SKIPPED
[INFO] Eclipse SmartHome Automation Parser GSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Providers ............. SKIPPED
[INFO] Eclipse SmartHome Automation Provider File ......... SKIPPED
[INFO] Eclipse SmartHome Automation Core .................. SKIPPED
[INFO] Eclipse SmartHome Automation Core Tests ............ SKIPPED
[INFO] Eclipse SmartHome Automation Sample JSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Core Modules .......... SKIPPED
[INFO] Eclipse SmartHome Automation Core Module Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Script Modules ........ SKIPPED
[INFO] Eclipse SmartHome Automation Media Modules ......... SKIPPED
[INFO] Eclipse SmartHome Automation Timer Modules ......... SKIPPED
[INFO] Eclipse SmartHome Automation Module Timer Tests .... SKIPPED
[INFO] Eclipse SmartHome Automation Script Default Scope .. SKIPPED
[INFO] Eclipse SmartHome Automation Script RuleSupport .... SKIPPED
[INFO] Eclipse SmartHome Automation Script Module Tests ... SKIPPED
[INFO] Eclipse SmartHome Automation Event Tests ........... SKIPPED
[INFO] Eclipse SmartHome Automation Integration Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Sample Extension Java . SKIPPED
[INFO] Eclipse SmartHome Automation REST API .............. SKIPPED
[INFO] Eclipse SmartHome Automation Sample REST API ....... SKIPPED
[INFO] Eclipse SmartHome Automation Java Demo ............. SKIPPED
[INFO] Eclipse SmartHome Automation Json Demo ............. SKIPPED
[INFO] Eclipse SmartHome Automation Module Type Demo ...... SKIPPED
[INFO] Eclipse SmartHome Console for OSGi framework Eclipse Equinox SKIPPED
[INFO] Eclipse SmartHome Console for OSGi Console RFC 147 . SKIPPED
[INFO] Eclipse SmartHome Console for OSGi runtime Karaf ... SKIPPED
[INFO] Eclipse SmartHome Monitor .......................... SKIPPED
[INFO] Eclipse SmartHome Network I/O ...................... SKIPPED
[INFO] Eclipse SmartHome Network I/O Tests ................ SKIPPED
[INFO] Eclipse SmartHome IO REST Tests .................... SKIPPED
[INFO] Eclipse SmartHome Authentication Support for the REST Interface SKIPPED
[INFO] Eclipse SmartHome Basic Auth for the REST Interface SKIPPED
[INFO] Eclipse SmartHome Core REST Interface .............. SKIPPED
[INFO] Eclipse SmartHome IO REST Core Tests ............... SKIPPED
[INFO] Eclipse SmartHome REST mDNS Announcer .............. SKIPPED
[INFO] Eclipse SmartHome REST JAX-RS Optimizations ........ SKIPPED
[INFO] Eclipse SmartHome SSE Interface .................... SKIPPED
[INFO] Eclipse SmartHome IO SSE Tests ..................... SKIPPED
[INFO] Eclipse SmartHome Models ........................... SKIPPED
[INFO] Eclipse SmartHome Model Core ....................... SKIPPED
[INFO] Eclipse SmartHome Model Lazy Generation ............ SKIPPED
[INFO] Eclipse SmartHome Model Sitemap .................... SKIPPED
[INFO] Eclipse SmartHome Model Items ...................... SKIPPED
[INFO] Eclipse SmartHome UIs .............................. SKIPPED
[INFO] Eclipse SmartHome UI ............................... SKIPPED
[INFO] Eclipse SmartHome Sitemap REST Interface ........... SKIPPED
[INFO] Eclipse SmartHome Sitemap REST Interface Tests ..... SKIPPED
[INFO] Eclipse SmartHome Core REST UI Logging Module ...... SKIPPED
[INFO] Eclipse SmartHome Voice REST Interface ............. SKIPPED
[INFO] Eclipse SmartHome DBus Transport ................... SKIPPED
[INFO] Eclipse SmartHome MQTT Transport ................... SKIPPED
[INFO] Eclipse SmartHome Mqtt Transport I/O Tests ......... SKIPPED
[INFO] Eclipse SmartHome UPnP Transport ................... SKIPPED
[INFO] Eclipse SmartHome IO UPnP Tests .................... SKIPPED
[INFO] Eclipse SmartHome Model Core Tests ................. SKIPPED
[INFO] Eclipse SmartHome Model Item IDE ................... SKIPPED
[INFO] Eclipse SmartHome Model Items Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Items Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Persistence ................ SKIPPED
[INFO] Eclipse SmartHome Model Persistence IDE ............ SKIPPED
[INFO] Eclipse SmartHome Model Script ..................... SKIPPED
[INFO] Eclipse SmartHome Model Rules ...................... SKIPPED
[INFO] Eclipse SmartHome Model Rule IDE ................... SKIPPED
[INFO] Eclipse SmartHome Model Script IDE ................. SKIPPED
[INFO] Eclipse SmartHome Model Sitemap IDE ................ SKIPPED
[INFO] Eclipse SmartHome Thing Model ...................... SKIPPED
[INFO] Eclipse SmartHome Model Thing IDE .................. SKIPPED
[INFO] Eclipse SmartHome Language Server .................. SKIPPED
[INFO] Eclipse SmartHome Language Server Tests ............ SKIPPED
[INFO] Eclipse SmartHome Model Persistence Runtime ........ SKIPPED
[INFO] Eclipse SmartHome Model Persistence Tests .......... SKIPPED
[INFO] Eclipse SmartHome Model Rules Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Model Rules Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Script Runtime ............. SKIPPED
[INFO] Eclipse SmartHome Model Script Tests ............... SKIPPED
[INFO] Eclipse SmartHome Model Sitemap Runtime ............ SKIPPED
[INFO] Eclipse SmartHome Thing Model Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Thing Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome UI Tests ......................... SKIPPED
[INFO] Eclipse SmartHome UI Icon Support .................. SKIPPED
[INFO] Eclipse SmartHome UI Icon Tests .................... SKIPPED
[INFO] Eclipse SmartHome Storages ......................... SKIPPED
[INFO] Eclipse SmartHome JSON Storage ..................... SKIPPED
[INFO] Eclipse SmartHome Storage JSON Tests ............... SKIPPED
[INFO] Eclipse SmartHome MapDB Storage .................... SKIPPED
[INFO] Eclipse SmartHome Storage MapDB Tests .............. SKIPPED
[INFO] Eclipse SmartHome Extensions ....................... SKIPPED
[INFO] Eclipse SmartHome Bindings ......................... SKIPPED
[INFO] Eclipse SmartHome Astro Binding .................... SKIPPED
[INFO] Eclipse SmartHome Astro Binding Tests .............. SKIPPED
[INFO] Eclipse SmartHome Bluetooth Binding ................ SKIPPED
[INFO] Eclipse SmartHome BlueZ Bluetooth Adapter .......... SKIPPED
[INFO] Eclipse SmartHome Bluetooth Binding Tests .......... SKIPPED
[INFO] Eclipse SmartHome DigitalSTROM Binding ............. SKIPPED
[INFO] Eclipse Smarthome DMX Binding ...................... SKIPPED
[INFO] Eclipse Smarthome DMX Binding Tests ................ SKIPPED
[INFO] Eclipse SmartHome hue Binding ...................... SKIPPED
[INFO] Eclipse SmartHome hue Binding Tests ................ SKIPPED
[INFO] Eclipse SmartHome FSInternetRadio Binding .......... SKIPPED
[INFO] Eclipse Smarthome FSInternetRadio Binding Test ..... SKIPPED
[INFO] Eclipse SmartHome LIFX Binding ..................... SKIPPED
[INFO] Eclipse SmartHome LIRC Binding ..................... SKIPPED
[INFO] Eclipse SmartHome NTP Binding ...................... SKIPPED
[INFO] Eclipse SmartHome NTP Binding Tests ................ SKIPPED
[INFO] SerialButton Binding ............................... SKIPPED
[INFO] Eclipse SmartHome Sonos Binding .................... SKIPPED
[INFO] TRÅDFRI Binding .................................... SKIPPED
[INFO] TRÅDFRI Binding Tests .............................. SKIPPED
[INFO] WeatherUnderground Binding ......................... SKIPPED
[INFO] Eclipse SmartHome WeMo Binding ..................... SKIPPED
[INFO] Eclipse SmartHome Wemo Binding Tests ............... SKIPPED
[INFO] Eclipse SmartHome YahooWeather Binding ............. SKIPPED
[INFO] Eclipse SmartHome Extension Service Extensions ..... SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Service SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Automation Support SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Service Test SKIPPED
[INFO] Eclipse SmartHome I/O Services ..................... SKIPPED
[INFO] Eclipse SmartHome JavaSound I/O .................... SKIPPED
[INFO] Eclipse SmartHome Web Audio Support ................ SKIPPED
[INFO] Eclipse SmartHome Transformation Services .......... SKIPPED
[INFO] Eclipse SmartHome Exec Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Javascript Transformation Service SKIPPED
[INFO] Eclipse SmartHome Map Transformation Service ....... SKIPPED
[INFO] Eclipse SmartHome Map Transformation Service Tests . SKIPPED
[INFO] Eclipse SmartHome Scale Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome Scale Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome RegEx Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome RegEx Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome XPath Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome XPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome JSonPath Transformation Service .. SKIPPED
[INFO] Eclipse SmartHome JSonPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome Xslt Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Xslt Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome UI Extensions .................... SKIPPED
[INFO] Eclipse SmartHome Icon Sets ........................ SKIPPED
[INFO] Eclipse SmartHome Classic Icon Set ................. SKIPPED
[INFO] Eclipse SmartHome Basic UI ......................... SKIPPED
[INFO] Eclipse SmartHome Classic UI ....................... SKIPPED
[INFO] Eclipse SmartHome Paper UI ......................... SKIPPED
[INFO] Eclipse SmartHome Voice Services ................... SKIPPED
[INFO] Eclipse SmartHome MacOS TTS ........................ SKIPPED
[INFO] Eclipse SmartHome Mac TTS Tests .................... SKIPPED
[INFO] Eclipse SmartHome Features ......................... SKIPPED
[INFO] Eclipse SmartHome Runtime Core Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Model Feature ............ SKIPPED
[INFO] Eclipse SmartHome Runtime UI Feature ............... SKIPPED
[INFO] Eclipse SmartHome Runtime REST Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Automation Feature ....... SKIPPED
[INFO] Eclipse SmartHome Runtime Equinox Console Feature .. SKIPPED
[INFO] Eclipse SmartHome Runtime RfC147 Console Feature ... SKIPPED
[INFO] Eclipse SmartHome Runtime Binding Feature .......... SKIPPED
[INFO] Eclipse SmartHome Test Dependencies ................ SKIPPED
[INFO] Eclipse SmartHome Karaf Features ................... SKIPPED
[INFO] Eclipse SmartHome Target Platform Feature .......... SKIPPED
[INFO] Eclipse SmartHome Core Feature ..................... SKIPPED
[INFO] Eclipse SmartHome Extensions Feature ............... SKIPPED
[INFO] Eclipse SmartHome Karaf Feature Verification ....... SKIPPED
[INFO] Eclipse SmartHome Products ......................... SKIPPED
[INFO] Eclipse SmartHome p2 Repository .................... SKIPPED
[INFO] Eclipse SmartHome Tools ............................ SKIPPED
[INFO] Eclipse SmartHome Archetypes ....................... SKIPPED
[INFO] Eclipse Smarthome Binding Archetype ................ SKIPPED
[INFO] Eclipse Smarthome Binding Archetype Testsuite ...... SKIPPED
[INFO] Eclipse SmartHome Target Platform .................. SKIPPED
[INFO] Eclipse SmartHome Distribution ..................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:18 min
[INFO] Finished at: 2018-02-22T21:05:35-05:00
[INFO] Final Memory: 176M/480M
[ERROR] Failed to execute goal org.openhab.tools.sat:sat-plugin:0.4.1:findbugs (default) on project org.eclipse.smarthome.core: Execution default of goal org.openhab.tools.sat:sat-plugin:0.4.1:findbugs failed: A required class was missing while executing org.openhab.tools.sat:sat-plugin:0.4.1:findbugs: javax/xml/bind/JAXBException
[ERROR] -----------------------------------------------------
[ERROR] realm = plugin>org.openhab.tools.sat:sat-plugin:0.4.1
[ERROR] strategy = org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy
[ERROR] urls[0] = file:/root/.m2/repository/org/openhab/tools/sat/sat-plugin/0.4.1/sat-plugin-0.4.1.jar
FUDForum. Page generated in 0.09543 seconds
