Home » Modeling » TMF (Xtext) » Code coverage for Xtend (outside of maven build)
Code coverage for Xtend (outside of maven build) [message #1782462] Fri, 23 February 2018 11:48 Go to next message
I'm using jacoco to get code coverage reports. With Eclemma I can run a test with code coverage manually to get markup in the Java editor. All this works fine for Java code that is generated from xtend code.
I found a blog post https://christiandietrich.wordpress.com/2016/01/12/code-coverage-for-xtend/ that describes how to get the markup in xtend, but that works only when running a maven build. Is there a way to get colored markup in the xtend editor after running a test manually? I can't see any preferences in eclipse that correspond to the configuration settings for the xtend-maven-plugin described in the blog post.
Re: Code coverage for Xtend (outside of maven build) [message #1782467 is a reply to message #1782462] Fri, 23 February 2018 12:53 Go to previous messageGo to next message
i dont know any.
you have to set the following in the prefs,
outlet.DEFAULT_OUTPUT.installDslAsPrimarySource=true
but e.g. eclemma ignores that?
why: => you need to investigate
Re: Code coverage for Xtend (outside of maven build) [message #1782472 is a reply to message #1782467] Fri, 23 February 2018 13:54 Go to previous messageGo to next message
Ah, it's "Ignore generated Java source when debugging (Use for Android)" in the Xtend compiler settings.
Re: Code coverage for Xtend (outside of maven build) [message #1782475 is a reply to message #1782472] Fri, 23 February 2018 14:14 Go to previous messageGo to next message
yes. but eclemma does not seem to care.
Re: Code coverage for Xtend (outside of maven build) [message #1782627 is a reply to message #1782475] Tue, 27 February 2018 04:40 Go to previous messageGo to next message
Sonarqube will ignore that as well...
Re: Code coverage for Xtend (outside of maven build) [message #1841951 is a reply to message #1782627] Fri, 04 June 2021 02:51 Go to previous messageGo to next message
I know this is very old, but there is a solution.
(Working code, but could be cleaned up).
import java.util.List;
import java.util.Optional;
import javax.inject.Inject;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.runtime.IAdapterFactory;
import org.eclipse.eclemma.core.CoverageTools;
import org.eclipse.eclemma.internal.core.analysis.JavaElementCoverageAdapterFactory;
import org.eclipse.emf.common.util.URI;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.IJavaElement;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.xtext.ui.generator.IDerivedResourceMarkers;
import org.jacoco.core.analysis.ICoverageNode;
@SuppressWarnings("restriction")
public class JavaElementAdapterFactory implements IAdapterFactory {
	@Inject
	private IDerivedResourceMarkers derivedResourceMarkers;
	@Inject
	private IWorkspaceRoot wsRoot;
	public <T> T getAdapter(final Object adaptableObject, final Class<T> adapterType) {
		if (adaptableObject instanceof IFileEditorInput && adapterType == IJavaElement.class) {
			final IFileEditorInput input = (IFileEditorInput) adaptableObject;
			try {
				final List<IFile> resources = derivedResourceMarkers.findDerivedResources(wsRoot,
						URI.createPlatformResourceURI(input.getFile().getFullPath().toString(), true).toString());
				if (!resources.isEmpty()) {
					final String fileName = input.getAdapter(IFile.class).getFullPath().removeFileExtension()
							.lastSegment()
							+ ".java";
					final Optional<IFile> file = resources.stream()
							.filter(r -> r.getName().equals(fileName))
							.findFirst();
					if (file.isPresent()) {
						return adapterType.cast(JavaCore.create(file.get()));
			} catch (final Exception e) {
				// ignore
		if (adaptableObject instanceof ICompilationUnit && adapterType == ICoverageNode.class) {
			final ICoverageNode coverageInfo = (ICoverageNode) new JavaElementCoverageAdapterFactory()
					.getAdapter(adaptableObject, adapterType);
			if (coverageInfo != null && coverageInfo.containsCode()) {
				return adapterType.cast(coverageInfo);
			final ICompilationUnit unit = (ICompilationUnit) adaptableObject;
			return adapterType
					.cast(CoverageTools.getCoverageInfo(unit.getType(unit.getElementName().replace(".java", ""))));
		return null;
	public Class<?>[] getAdapterList() {
		return new Class<?>[] { IFileEditorInput.class, ICompilationUnit.class };
This must be registered via an extension point:
<extension
            point="org.eclipse.core.runtime.adapters">
         <factory
               adaptableType="org.eclipse.ui.IFileEditorInput"
               class="com.company.JavaElementAdapterFactory">
            <adapter
                  type="org.eclipse.jdt.core.IJavaElement">
            </adapter>
         </factory>
         <factory
               adaptableType="org.eclipse.jdt.core.ICompilationUnit"
            <adapter
                  type="org.jacoco.core.analysis.ICoverageNode">
            </adapter>
         </factory>
      </extension>
and additionally if using custom shortcuts, mode "coverage" needs to be added to these shortcuts.
 <extension
         point="org.eclipse.debug.ui.launchShortcuts">
      <shortcut
            label="My test"
            helpContextId="org.eclipse.jdt.junit.launch_shortcut"
            class="com.company.TestLaunchShortcut"
            modes="debug,run,coverage"
            id="com.company.debugLaunchShortCutProject">
Some UI widgets don't work this way, this can perhaps be improved. But you get the idea to go forward. Highlighting works in every xtext editor.
Re: Code coverage for Xtend (outside of maven build) [message #1842197 is a reply to message #1841951] Fri, 11 June 2021 09:14 Go to previous message
@Heinrich did you get this running with primarysource debug info only or with sourcedebugextension/smap too?
Previous Topic:How to export custom hovers as plug in ?
Next Topic:XBase EMF
Current Time: Mon Jul 21 07:02:49 EDT 2025
Powered by FUDForum. Page generated in 0.26698 seconds
