Eclipse Oxygen 4.7.2 unresponsive after update [message #1782397] |
Thu, 22 February 2018 11:45  |
My current version of Eclipse Oxygen 4.7.2 release spawned off of JDT version download. Machine is Dell Precision 7510, 32 GB RAM, 250 MB SSD HD. Windows Pro 7 SP1 64-bit.
Since last update, Eclipse has stopped completing a restart. It takes more than 5 minutes till requesting which workspace to use, then waits forever (more than 50 minutes last attempt).
Reading through the ".log" file found in workspace/.Metadata, I find that some kind of Java exception occurs: "sun.security.validator.ValidatorException: PKIX path".
Two separate log files are attached.
I was reading a webpage on how to turn off wst.Validation. This didn't seem to help.
What I would like to do, is force an interrrupt on the full load process, to only do what was in original package.
I would like to know how to troubleshoot as much as possible. I am a software developer. Admittedly, I have many more years C/C++, C# than Java. I can read java code quite well. If I knew how to shut services off in config files, this would be helpful.
Any direction or coaching on how to proceed next would be helpful.
Attachment: .log
(Size: 413.93KB, Downloaded 125 times)
Attachment: .bak_0.log
(Size: 0.98MB, Downloaded 131 times)
[Updated on: Thu, 22 February 2018 11:48] by Moderator
FUDForum. Page generated in 0.04463 seconds
