Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Generated *FactoryImpl is not an instance of Resource.Factory(Could the problem be in the source XSD?)
Generated *FactoryImpl is not an instance of Resource.Factory [message #1782066] Fri, 16 February 2018 12:11 Go to next message
All,
Is there any way code generated from an XSD can produce a *FactoryImpl class that is not an instance of Resource.Factory?
I am using an XSD developed by a third party.
I know about registering extensions and schemes. I don't believe that's the problem because correct *FactoryImpl class is found in the extension map. It just is not an instance of Resource.Factory.
I have included the XSD for good measure.
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
    xmlns:arf="http://scap.nist.gov/schema/asset-reporting-format/1.1"
    xmlns:ai="http://scap.nist.gov/schema/asset-identification/1.1"
    xmlns:core="http://scap.nist.gov/schema/reporting-core/1.1" xmlns:xlink="http://www.w3.org/1999/xlink"
    xmlns:dsig="http://www.w3.org/2000/09/xmldsig#"
    targetNamespace="http://scap.nist.gov/schema/asset-reporting-format/1.1" elementFormDefault="qualified"
    attributeFormDefault="unqualified" version="1.1.1">
    <xs:annotation>
        <xs:appinfo>
            <schema>Asset Reporting Format</schema>
            <author>David Waltermire, Adam Halbardier, John Wunder</author>
            <version>1.1.1</version>
            <date>2012-02-13</date>
            <sch:schema queryBinding="xslt2" xmlns:sch="http://purl.oclc.org/dsdl/schematron">
                <sch:ns prefix="xml" uri="http://www.w3.org/XML/1998/namespace"/>
                <sch:ns prefix="xsd" uri="http://www.w3.org/2001/XMLSchema"/>
                <sch:ns prefix="arf" uri="http://scap.nist.gov/schema/asset-reporting-format/1.1"/>
                <sch:ns prefix="core" uri="http://scap.nist.gov/schema/reporting-core/1.1"/>
                <sch:ns prefix="ai" uri="http://scap.nist.gov/schema/asset-identification/1.1"/>
                <sch:ns prefix="fn" uri="http://www.w3.org/2005/xpath-functions"/>
                <sch:ns prefix="xcf" uri="nist:scap:arf:xslt:function"/>
                <sch:pattern>
                    <!-- 2011-11-29 - Correcting defect.  The namespace is updated to match the namespace specified in NIST IR 7694, Section 6.1 -->
                    <!-- <sch:let name="arf-namespace" value="string('http://scap.nist.gov/vocabulary/arf/relationships/1.0#')"/> -->
                    <sch:let name="arf-namespace" value="string('http://scap.nist.gov/specifications/arf/vocabulary/relationships/1.0#')"/>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'isAbout' )]">
                        <sch:assert test="exists(ancestor::arf:asset-report-collection/arf:reports/arf:report[@id eq current()/@subject])">
                            <sch:value-of select="xcf:controlled-vocab-error-domain(current(),'report')"/>
                        </sch:assert>
                        <sch:assert test="every $m in core:ref satisfies current()/ancestor::arf:asset-report-collection/arf:assets/arf:asset[@id eq $m]">
                            <sch:value-of select="xcf:controlled-vocab-error-range(current(),'asset')"/>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'retrievedFrom' )]">
                        </sch:assert>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'createdBy' )]">
                        </sch:assert>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'hasSource' )]">
                        </sch:assert>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'recordedBy' )]">
                        </sch:assert>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'initiatedBy' )]">
                        </sch:assert>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'createdFor' )]">
                        </sch:assert>
                        <sch:assert test="every $m in core:ref satisfies current()/ancestor::arf:asset-report-collection/arf:report-requests/arf:report-request[@id eq $m]">
                            <sch:value-of select="xcf:controlled-vocab-error-range(current(),'report-request')"/>
                        </sch:assert>
                    </sch:rule>
                    <sch:rule context="core:relationship[fn:resolve-QName(@type, current()) eq fn:QName($arf-namespace,'hasMetadata' )]">
                        </sch:assert>
                        <sch:assert test="every $m in core:ref satisfies current()/ancestor::arf:asset-report-collection/arf:reports/arf:report[@id eq $m]">
                            <sch:value-of select="xcf:controlled-vocab-error-range(current(),'report')"/>
                        </sch:assert>
                    </sch:rule>
                </sch:pattern>
                <xsl:function name="xcf:controlled-vocab-error-domain" xmlns:fn="http://www.w3.org/2005/xpath-functions" xmlns:xcf="nist:scap:arf:xslt:function" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns="http://www.w3.org/1999/XSL/Transform">
                    <xsl:param name="node"/>
                    <xsl:param name="refName"/>
                    <xsl:value-of select="concat(concat(concat(concat(string('All @subject attribute in a relationship of type '),namespace-uri-from-QName(resolve-QName($node/@type, $node))),local-name-from-QName(resolve-QName($node/@type, $node))),string(' must reference a ')),$refName)"/>
                </xsl:function>
                <xsl:function name="xcf:controlled-vocab-error-range" xmlns:fn="http://www.w3.org/2005/xpath-functions" xmlns:xcf="nist:scap:arf:xslt:function" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns="http://www.w3.org/1999/XSL/Transform">
                    <xsl:value-of select="concat(concat(concat(concat(string('All &lt;ref> elements in a relationship of type '),namespace-uri-from-QName(resolve-QName($node/@type, $node))),local-name-from-QName(resolve-QName($node/@type, $node))),string(' must reference a ')),$refName)"/>
                </xsl:function>
            </sch:schema>
        </xs:appinfo>
    </xs:annotation>
    <xs:import namespace="http://scap.nist.gov/schema/asset-identification/1.1"
        schemaLocation="https://scap.nist.gov/schema/asset-identification/1.1/asset-identification_1.1.0.xsd"/>
    <xs:import namespace="http://www.w3.org/1999/xlink" schemaLocation="https://www.w3.org/1999/xlink.xsd"/>
    <xs:import namespace="http://scap.nist.gov/schema/reporting-core/1.1"
        schemaLocation="https://scap.nist.gov/schema/reporting-core/1.1/reporting-core_1.1.0.xsd"/>
    <xs:element name="asset-report-collection">
        <xs:annotation>
            <xs:documentation>The top-level report element.</xs:documentation>
        </xs:annotation>
        <xs:complexType>
            <xs:complexContent>
                <xs:extension base="core:relationships-container-type">
                    <xs:sequence>
                        <xs:element name="report-requests" minOccurs="0">
                            <xs:annotation>
                                <xs:documentation>Contains one or more requests for reports. Each report request must be referenced in a relationship on a report in the same asset-report-collection.</xs:documentation>
                            </xs:annotation>
                            <xs:complexType>
                                <xs:sequence>
                                    <xs:element name="report-request" type="arf:ReportRequestType" maxOccurs="unbounded"
                                        > </xs:element>
                                </xs:sequence>
                            </xs:complexType>
                        </xs:element>
                        <xs:element minOccurs="0" name="assets">
                            <xs:annotation>
                                <xs:documentation>Contains the representation of one or more assets represented using the Asset Identification format.</xs:documentation>
                            </xs:annotation>
                            <xs:complexType>
                                <xs:sequence>
                                    <xs:element maxOccurs="unbounded" name="asset">
                                        <xs:complexType>
                                            <xs:choice>
                                                <xs:element ref="ai:asset"/>
                                                <xs:element ref="arf:remote-resource"/>
                                            </xs:choice>
                                            <xs:attribute name="id" type="xs:NCName" use="required">
                                                <xs:annotation>
                                                    <xs:documentation>An internal ID to identify this asset.</xs:documentation>
                                                </xs:annotation>
                                            </xs:attribute>
                                            <xs:anyAttribute namespace="##other">
                                                <xs:annotation>
                                                    <xs:documentation>A placeholder so that content creators can add attributes as
                                        desired.</xs:documentation>
                                                </xs:annotation>
                                            </xs:anyAttribute>
                                        </xs:complexType>
                                    </xs:element>
                                </xs:sequence>
                            </xs:complexType>
                        </xs:element>
                        <xs:element name="reports">
                            <xs:annotation>
                                <xs:documentation>Contains one or more reports.</xs:documentation>
                            </xs:annotation>
                            <xs:complexType>
                                <xs:sequence>
                                    <xs:element name="report" type="arf:ReportType" maxOccurs="unbounded">
                                        <xs:annotation>
                                            <xs:documentation>Contains a report, which is composed of zero or more relationships and a content payload.</xs:documentation>
                                        </xs:annotation>
                                    </xs:element>
                                </xs:sequence>
                            </xs:complexType>
                        </xs:element>
                        <xs:element minOccurs="0" name="extended-infos">
                            <xs:annotation>
                                <xs:documentation>Contain other information elements.  Used as an extension point.</xs:documentation>
                            </xs:annotation>
                            <xs:complexType>
                                <xs:sequence>
                                    <xs:element maxOccurs="unbounded" name="extended-info">
                                        <xs:annotation>
                                            <xs:documentation>Contains other information.  Use as an extension point for data that does not fall into the categories defined in asset-report-collection.</xs:documentation>
                                        </xs:annotation>
                                        <xs:complexType>
                                            <xs:sequence>
                                                <xs:any namespace="##other" processContents="lax"/>
                                            </xs:sequence>
                                                <xs:annotation>
                                                    <xs:documentation>An internal ID to identify this object.</xs:documentation>
                                                </xs:annotation>
                                            </xs:attribute>
                                                <xs:annotation>
                                                    <xs:documentation>A placeholder so that content creators can add attributes as desired.</xs:documentation>
                                                </xs:annotation>
                                            </xs:anyAttribute>
                                        </xs:complexType>
                                    </xs:element>
                                </xs:sequence>
                            </xs:complexType>
                        </xs:element>
                    </xs:sequence>
                    <xs:attribute name="id" type="xs:NCName">
                        <xs:annotation>
                            <xs:documentation>The id for this collection.</xs:documentation>
                        </xs:annotation>
                    </xs:attribute>
                        <xs:annotation>
                        </xs:annotation>
                    </xs:anyAttribute>
                </xs:extension>
            </xs:complexContent>
        </xs:complexType>
        <xs:key name="idKey">
            <xs:selector xpath=".//arf:report-request|.//arf:asset|.//arf:report|.//arf:extended-info"/>
            <xs:field xpath="@id"/>
        </xs:key>
        <xs:keyref name="relSubjKeyRef" refer="arf:idKey">
            <xs:selector xpath="core:relationships/core:relationship"/>
            <xs:field xpath="@subject"/>
        </xs:keyref>
        <xs:keyref name="relObjKeyRef" refer="arf:idKey">
            <xs:selector xpath="core:relationships/core:relationship/core:ref"/>
            <xs:field xpath="."/>
        </xs:keyref>
    </xs:element>
    <xs:complexType name="ReportRequestType">
        <xs:choice>
            <xs:element name="content">
                <xs:annotation>
                    <xs:documentation>Contains the content of the report request.</xs:documentation>
                </xs:annotation>
                <xs:complexType>
                    <xs:sequence>
                        <xs:any namespace="##other" processContents="lax">
                            <xs:annotation>
                                <xs:documentation>Holds the content of a report request.</xs:documentation>
                            </xs:annotation>
                        </xs:any>
                    </xs:sequence>
                        <xs:annotation>
                        </xs:annotation>
                    </xs:anyAttribute>
                </xs:complexType>
            </xs:element>
        </xs:choice>
            <xs:annotation>
                <xs:documentation>An internal ID to identify this report request.</xs:documentation>
            </xs:annotation>
        </xs:attribute>
            <xs:annotation>
            </xs:annotation>
        </xs:anyAttribute>
    </xs:complexType>
    <xs:complexType name="ReportType">
        <xs:choice>
                <xs:annotation>
                    <xs:documentation>Contains the content of the report.</xs:documentation>
                </xs:annotation>
                <xs:complexType>
                    <xs:sequence>
                    </xs:sequence>
                    <xs:attribute name="data-valid-start-date" type="xs:date"/>
                    <xs:attribute name="data-valid-end-date" type="xs:date"/>
                        <xs:annotation>
                        </xs:annotation>
                    </xs:anyAttribute>
                </xs:complexType>
            </xs:element>
        </xs:choice>
            <xs:annotation>
                <xs:documentation>An internal ID to identify this report.</xs:documentation>
            </xs:annotation>
        </xs:attribute>
            <xs:annotation>
            </xs:annotation>
        </xs:anyAttribute>
    </xs:complexType>
    <xs:element name="object-ref">
        <xs:annotation>
            <xs:documentation>Report creators can embedding this element in a report with the @ref_id referencing the ID of an asset, report, or report request.  This element effectively acts as a pointer, allowing content produces to reference higher level ARF constructs in a report, without duplicating the data in that ARF construct.</xs:documentation>
        </xs:annotation>
        <xs:complexType>
            <xs:attribute name="ref-id" type="xs:NCName"/>
        </xs:complexType>
    </xs:element>
    <xs:element name="remote-resource">
        <xs:annotation>
            <xs:documentation>Links to content stored external to this report.</xs:documentation>
        </xs:annotation>
        <xs:complexType>
            <xs:attribute ref="xlink:type" use="required" fixed="simple">
                <xs:annotation>
                    <xs:documentation>Fixed as a simple XLink.</xs:documentation>
                </xs:annotation>
            </xs:attribute>
            <xs:attribute ref="xlink:href" use="required">
                <xs:annotation>
                    <xs:documentation>A URI to the remote content. Producers and consumers should both know how to resolve the URI in order to be interoperable.</xs:documentation>
                </xs:annotation>
            </xs:attribute>
                <xs:annotation>
                </xs:annotation>
            </xs:anyAttribute>
        </xs:complexType>
    </xs:element>
</xs:schema>
<!-- CHANGELOG
  date           change                    remarks
  02/13/12       Update the version number Updated the schema version to 1.1.1 based on the change made on 11/29/11
                 Update the schema date    Updated the schema date to 2012-02-13
  11/29/11       changed relationship      The namespace for relationships in the Schematron did not match the NIST IR 7694, Section 6.1
                 namespace in Schematron
Re: Generated *FactoryImpl is not an instance of Resource.Factory [message #1782073 is a reply to message #1782066] Fri, 16 February 2018 13:35 Go to previous messageGo to next message
I'm not clear.
a) do you want or not want a ResourceFactory that implements Resource.Factory?
b) what is the relevance of your observation that *FasctoryImpl is found in the extension map?
Resource.Factory is a very thin interface, so I'm not sure why it is a problem. The default EMF generators reuse abstract classes, but you can reimplement to taste.
When I generate from your XSD, ignoring some bad ExtendedMetaData value warnings, I see perfectly normal ResourcFasctoryImpl's that extend Resource.Factory.
What is the problem?
Ed Willink
Re: Generated *FactoryImpl is not an instance of Resource.Factory [message #1782078 is a reply to message #1782073] Fri, 16 February 2018 14:16 Go to previous messageGo to next message
Ed,
Thanks for a quick response.
When I try to read an XML file that conforms to said schema, (uploaded) I get a class cast exception. Upon investigation, I see that my factory class is found in the registry but when I test it with an "instanceof" it is not of type Resource.Factory, which is what the error message says.
You say you've generated code from the schema I posted. and you're telling me it appears normal. I believe you.
In the past, I only had the class cast exception when things were not registered properly. I am under the impression I am registering correctly in this case. So why the cast problem?
Here's where the error is thrown:
public class ResourceFactoryRegistryImpl implements Resource.Factory.Registry
... <more code> ...
  public static Resource.Factory convert(Object resourceFactory)
    return
      resourceFactory instanceof Resource.Factory.Descriptor ?
        ((Resource.Factory.Descriptor)resourceFactory).createFactory() :
        (Resource.Factory)resourceFactory;  // This cast worketh not.
... <more code> ...
Here's me registering the class in question and everything else:
getResourceSet().getResourceFactoryRegistry().getExtensionToFactoryMap().put("xml", new gov.nist.scap.schema.asset.reporting.format._1.impl._1FactoryImpl());		resourceSet.getPackageRegistry().put(gov.nist.scap.schema.asset.identification._1._1Package.eNS_URI,  gov.nist.scap.schema.asset.identification._1._1Package.eINSTANCE);
resourceSet.getPackageRegistry().put(gov.nist.scap.schema.asset.reporting.format._1._1Package.eNS_URI,  gov.nist.scap.schema.asset.reporting.format._1._1Package.eINSTANCE);
resourceSet.getPackageRegistry().put(gov.nist.scap.schema.reporting.core._1._1Package.eNS_URI,  gov.nist.scap.schema.reporting.core._1._1Package.eINSTANCE);
resourceSet.getPackageRegistry().put(oasis.names.tc.ciq.xsdschema.xAL._2._0._0Package.eNS_URI,  oasis.names.tc.ciq.xsdschema.xAL._2._0._0Package.eINSTANCE);
resourceSet.getPackageRegistry().put(oasis.names.tc.ciq.xsdschema.xNL._2._0._0Package.eNS_URI,  oasis.names.tc.ciq.xsdschema.xNL._2._0._0Package.eINSTANCE);
		Registrar.registerPackage(org.mitre.cpe.naming._2._2Package.eNS_URI,  org.mitre.cpe.naming._2._2Package.eINSTANCE);
resourceSet.getPackageRegistry().put(org.w3.xml._1998.namespace.NamespacePackage.eNS_URI,  org.w3.xml._1998.namespace.NamespacePackage.eINSTANCE);
  • Attachment: arf.xml
    (Size: 5.02MB, Downloaded 350 times)
Re: Generated *FactoryImpl is not an instance of Resource.Factory [message #1782090 is a reply to message #1782078] Fri, 16 February 2018 16:23 Go to previous messageGo to next message
Your model has many packages so I can only guess at what you did and what mistake you might have made.
If you post a repro project, I would not have to guess.
Ed Willink
Re: Generated *FactoryImpl is not an instance of Resource.Factory [message #1782093 is a reply to message #1782090] Sat, 17 February 2018 01:23 Go to previous message
My guess would be that you are (or something is) mixing up two different factories. In the impl package there should be an XyzPackageImpl and an XyzFactoryImpl that extends EFactoryImpl. In your util package there is an XyzResourceFactoryImpl. The latter should be registered with the URI converter. If you generated the *.test project, there will be an XyzExample.java that shows how to do the registrations correctly for a stand-alone application.
Previous Topic:Model Explorer view reload
Next Topic:EMF Forms Widget Disposed Exception
Current Time: Mon Nov 03 10:22:47 EST 2025
Powered by FUDForum. Page generated in 0.03934 seconds
