Home » Modeling » TMF (Xtext) » Problem with ID Terminal Rule
Problem with ID Terminal Rule [message #1782074] Fri, 16 February 2018 13:44 Go to next message
I have a problem identical to the one described in this thread:
https://www.eclipse.org/forums/index.php/t/166300/
I have solved it in exactly the way that Sven prescribed, however the solution creates another problem: the ID terminal seems to be treated as a generic string, allowing characters that my grammar considers illegal. Here is a relevant snippet from my grammar:
Variable_Primary returns PrimaryVariable:
	name=Variable_Name
Variable_Name:
	ID | 'E' | 'e'
Real_Value returns ecore::EDouble:
	Signed_Int '.' UNSIGNED_INT ('E' Signed_Int)?
terminal UNSIGNED_INT returns ecore::ELong:
	DIGIT ('_'? DIGIT)*
terminal fragment LETTER: 'a'..'z' | 'A'..'Z' | '_';
terminal fragment DIGIT: '0'..'9';
terminal ID:
 	DIGIT? LETTER (LETTER | DIGIT)*
The requirements for the grammar are as follows:
1. The name feature of Variable_Primary cannot include parentheses
2. The name feature of Variable_Primary can be the string literal 'E'
3. The value 1.23E-1 should match the Real_Value data type rule.
With the grammar stated above, requirement #1 is not satisfied, but requirements 2 and 3 are satisfied. Can anyone recommend a way to fulfill all three requirements?
Re: Problem with ID Terminal Rule [message #1782079 is a reply to message #1782074] Fri, 16 February 2018 14:32 Go to previous messageGo to next message
Sorry, I cannot see where rule 1# is infringed (include parentheses). But one thing that is possible to do when is not possible to do via the grammer is to use the validation approach.
Some thing like:
@Check
def checkVariableName(Variable_Primary toCheck) {
  if (toCheck.hasParentheses) {
      error('The name cannot has parentheses.', toCheck, ...)
Re: Problem with ID Terminal Rule [message #1782081 is a reply to message #1782079] Fri, 16 February 2018 14:45 Go to previous messageGo to next message
Thanks for the response. This should really be a parser rule, though. The detection of invalid characters should go there by design.
From my grammar, it is not evident to me, either, why a name like Y(x) passes through the parser and is not considered to be illegal.
Re: Problem with ID Terminal Rule [message #1782082 is a reply to message #1782079] Fri, 16 February 2018 14:47 Go to previous messageGo to next message
can you share a complete grammar and parsing test from what you've posted i can only guess
Re: Problem with ID Terminal Rule [message #1782083 is a reply to message #1782082] Fri, 16 February 2018 15:04 Go to previous messageGo to next message
Hi Christian, I created a Github Gist that contains my grammar and a related test:
https://gist.github.com/glusk/f7565cca0977b9ead21e6e0fbe1f7559
Re: Problem with ID Terminal Rule [message #1782085 is a reply to message #1782083] Fri, 16 February 2018 15:26 Go to previous messageGo to next message
Interestingly enough, the following test fails (as expected):
@Test def testParseIllegalVarName(){
		parseFunctionBlock('''
			FUNCTION_BLOCK 3V0
			 VAR_INPUT
			  e:BOOL;
			  E:BOOL;
			  X:NUMERIC:=1.23E-23;
			 END_VAR
			 VAR_OUTPUT
			  B:BOOL;
			  D:BOOL;
			 END_VAR
			 VAR
			  C(1):BOOL;
			 END_VAR
			END_FUNCTION_BLOCK
		''').assertNoErrors
But building a model with the Factory and trying to serialize an illegal variable name succeeds. I would expect that, if parsing faile, the semantic sequencer would throw an exception when backtracking during serialization too.
[Updated on: Fri, 16 February 2018 15:27] by Moderator
Re: Problem with ID Terminal Rule [message #1782086 is a reply to message #1782083] Fri, 16 February 2018 15:30 Go to previous messageGo to next message
so your question is about serialization and not parsing?
you need to implement a value converter service for that.
package org.xtext.example.mydsl;
import org.eclipse.xtext.common.services.DefaultTerminalConverters;
import org.eclipse.xtext.conversion.IValueConverter;
import org.eclipse.xtext.conversion.ValueConverter;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.conversion.impl.KeywordAlternativeConverter;
import org.eclipse.xtext.nodemodel.INode;
import com.google.inject.Inject;
public class MyDslValueConverterService extends DefaultTerminalConverters {
	@Inject
	private VarNameVC varNameVC;
	@ValueConverter(rule = "Variable_Name")
	public IValueConverter<String> Variable_Name() {
		return varNameVC;
	public static class VarNameVC implements IValueConverter<String> {
		public String toValue(String string, INode node) throws ValueConverterException {
			return string;
		public String toString(String value) throws ValueConverterException {
			if (value.contains("(")) {
				throw new ValueConverterException("mimimi", null, null);
			return value;
Re: Problem with ID Terminal Rule [message #1782087 is a reply to message #1782086] Fri, 16 February 2018 15:39 Go to previous messageGo to next message
Yes, the question is about serialization; the original problem surfaced during parsing, though. I will try the value converter service and post back how it works out. One question, though: since there are infinite combinations of possible illegal characters, in the toString() function, is there some means of accessing the grammar rule to see if it matches the expected regex to ensure that the value is valid instead of having to work through a bunch of specific exceptions?
Re: Problem with ID Terminal Rule [message #1782088 is a reply to message #1782087] Fri, 16 February 2018 16:05 Go to previous messageGo to next message
yes and now. its not really easy.
you would have to build a combination of AbstractLexerBasedConverter
and QualifiedNameValueConverter and KeywordAlternativeConverter
calling the parser manually i huge overhead and might be extremely inperformant
public static class MyDslParser2 extends MyDslParser {
		public IParseResult doParseVarName(CharSequence sequence) {
			try {
				return parse("Variable_Name", new ANTLRReaderStream(new StringReader(sequence.toString())));
			} catch (IOException e) {
				throw new WrappedException(e);
		@Inject
		MyDslParser2 p;
			return string;
			IParseResult result = p.doParseVarName(value);
			if (result.hasSyntaxErrors()) {
				System.err.println(result.getSyntaxErrors());
			return value;
=> what about using a positive regex instead of opting out?
Re: Problem with ID Terminal Rule [message #1782089 is a reply to message #1782088] Fri, 16 February 2018 16:10 Go to previous messageGo to next message
A positive regex was going to be my next option to ask about. I suppose that the only drawback might be that I will always have to manually synchronize the regex with the one that is in the grammar. But that would not be too big a price to pay. :)
Re: Problem with ID Terminal Rule [message #1782155 is a reply to message #1782089] Mon, 19 February 2018 10:45 Go to previous message
Christian,
Your solution worked perfectly! We used a positive regex to ensure that the variable names contain only legal characters, and now serialization works correctly. Thanks!
Previous Topic:Lexical syntax highlighting
Next Topic:Using indent for more than one level of indentation
Current Time: Thu Jul 24 21:53:09 EDT 2025
Powered by FUDForum. Page generated in 0.12661 seconds
