Can't install Eclipse Neon : problem with files in .p2 [message #1765087] |
Tue, 06 June 2017 09:06  |
I have installed JRE 32 bits, then 64 bits
Then JDK 64 bits
I install my Eclipse and select d:\Eclipse as target.
I get this :
Fetching compositeContent.jar from http://download.eclipse.org/oomph/updates/milestone/latest/ (440B)
ERROR: org.eclipse.equinox.p2.repository code=0 An error occurred while downloading http://download.eclipse.org/technology/epp/packages/neon/content.xml.xz. The cache file C:\Users\gfernandes\.p2\org.eclipse.equinox.p2.repository\cache\downloading\2079680757 could not be renamed to C:\Users\gfernandes\.p2\org.eclipse.equinox.p2.repository\cache\2079680757.
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:428)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:396)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:199)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:463)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
Took 1 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
I closed the installer.
Went into Users\<myprofilename>
And there, I deleted the .p2 folder
Started the installer again : fails in standard mode
Also fails if I switch to advanced mode, with the same error.
Seems it downloads files, then it tries to "rename" and unless the log message is wrong, it seems to me it's trying not to rename, but move a file from a folder to another.
No idea how to fix this. Restarting the installer it always tries to use a .p2 folder inside c:\Users\<profile>
FUDForum. Page generated in 0.05444 seconds
