Home » Eclipse Projects » EGit / JGit » JGit Find Merge Base
JGit Find Merge Base [message #1781943] Wed, 14 February 2018 15:54 Go to next message
I am trying to find the common ancestor between any 2 commits, also known as the merge base.
I tried using code like the one found at https://stackoverflow.com/a/26436588/1016482 , but it seems to fail in a specific situation.
If I give it 2 branches, where one branch has diverged with many new commits, it returns the correct merge base commit.
However, if I give it a commit and the commit's parent, it doesn't return the commit's parent as the merge base. Instead it returns the commit 2 parents from that.
Example:
Code:
	public static RevCommit getCommonAncestor(Repository repository, RevCommit commit1,
			RevCommit commit2) {
		RevWalk walk = null;
		try {
			walk = new RevWalk(repository);
			walk.setRevFilter(RevFilter.MERGE_BASE);
			walk.markStart(commit1);
			walk.markStart(commit2);
			final RevCommit base = walk.next();
			if ((base != null) && (walk.next() == null)) {
				return base;
		catch (IOException e) {
			e.printStackTrace();
		finally {
			if (walk != null) {
				walk.reset();
				walk.close();
				walk.dispose();
		return null;
Repository:
Head -> A -> B -> C -> D
So Commit A is the parent of Head and so on.
Expected Result of `getCommonAncestor(repository, CommitA, HEAD)` should be commit A.
What is actually returned is commit C.
Is there something I am doing wrong? Can I not use merge base in this circumstance or is this a bug?
I am using `org.eclipse.jgit` version `4.10.0.201712302008-r`.
[Updated on: Wed, 14 February 2018 17:07] by Moderator
Re: JGit Find Merge Base [message #1781945 is a reply to message #1781943] Wed, 14 February 2018 17:51 Go to previous messageGo to next message
I don't know why, but the method works correctly when I re-parse the commits again before trying the merge base.
			walk = new RevWalk(git.getRepository());
			commit1 = walk.parseCommit(commit1);
			commit2 = walk.parseCommit(commit2);
The only thing I did with the commits outside the method was retrieve them via another method.
	public static RevCommit getCommit(Repository repository, String commitId) {
		RevCommit result = null;
		try {
			final ObjectId commitObject = repository.resolve(commitId);
			if (commitObject != null) {
				result = walk.parseCommit(commitObject);
		catch (RevisionSyntaxException | IOException e) {
		finally {
			if (walk != null) {
				walk.close();
				walk.dispose();
		return result;
Can any one explain if I am doing something wrong that would require this extra code?
Re: JGit Find Merge Base [message #1782580 is a reply to message #1781945] Mon, 26 February 2018 11:50 Go to previous messageGo to next message
JGit only knows the objectId of objects which weren't parsed yet. Only when you parse them jgit gets access to the object's data
Re: JGit Find Merge Base [message #1782581 is a reply to message #1782580] Mon, 26 February 2018 11:53 Go to previous message
RevCommits need to be produced by the same RevWalk instance otherwise you can't compare them
Previous Topic:EGit auto capitalize branch names
Next Topic:JGit DiffCommand result is different from command line Git
Current Time: Thu Jul 24 21:55:54 EDT 2025
Powered by FUDForum. Page generated in 0.07714 seconds
