createSAXParseException on Windows [message #1781912] |
Wed, 14 February 2018 10:30  |
I have an Xtext application in an E4 RCP. There I call the Xtext parser from different things to have sources in an EMF.
Under linux in the RCP and in my units test on the Jenkins build server also linux it works fine.
But not on a Windows system it does not work. My first thought was that I have a problem with decoding. The sources are also UTF-8, I have attached the stack trace and the location of my code where I call it.
@Inject
protected XtextResourceSet resourceSet;
private void parseInputStream() {
URI uri = URI.createURI(file.getFullPath().toString());
resource = resourceSet.getResource(uri, false);
if (resource == null) {
resource = resourceSet.createResource(uri);
final Map<Object, Object> loadOptions = resourceSet.getLoadOptions();
loadOptions.put(XtextResource.OPTION_ENCODING, "UTF-8");
resource.load(in, resourceSet.getLoadOptions()); // <-- Stacktrace entry Point
Quote:during parsing: C:\Users\user\Desktop\de.company.rcp.rcp.product-win32.win32.x86_64\workspace\Library\tia_import\plcsoft\Main.awl
IOException: Content ist nicht zulässig in Prolog.
at de.company.rcp.common.source.parser.Parser.parseInputStream(Parser.java:155)
at de.company.rcp.common.source.parser.Parser.parse(Parser.java:78)
at de.company.rcp.common.source.parser.XTextAWLParser.parse(XTextAWLParser.java:24)
at de.company.rcp.common.source.parser.XTextParser.parse(XTextParser.java:37)
at de.company.rcp.common.source.parser.XTextParser.parseAwl(XTextParser.java:24)
at de.company.rcp.datamodel.importer.generation.source.SourceCrossPathGeneration.getPossibleCrossCallAwl(SourceCrossPathGeneration.java:128)
at de.company.rcp.datamodel.importer.generation.source.SourceCrossPathGeneration.getAllCrossLinkedSourcePathes(SourceCrossPathGeneration.java:95)
at de.company.rcp.datamodel.importer.generation.source.SourceCrossPathGeneration.generate(SourceCrossPathGeneration.java:50)
at de.company.rcp.datamodel.importer.generation.source.SourceCrossPathGeneration.generate(SourceCrossPathGeneration.java:1)
at de.company.rcp.datamodel.importer.importer.Import.runGenerator(Import.java:87)
at de.company.rcp.datamodel.importer.importer.ImportPlcSource.generateCrossSourcePath(ImportPlcSource.java:77)
at de.company.rcp.datamodel.importer.importer.ImportPlcSource.doImport(ImportPlcSource.java:49)
at de.company.rcp.datamodel.importer.wizard.ImportWizard.importPlcSource(ImportWizard.java:147)
at de.company.rcp.datamodel.importer.wizard.ImportWizard.access$2(ImportWizard.java:146)
at de.company.rcp.datamodel.importer.wizard.ImportWizard$1.execute(ImportWizard.java:104)
at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:107)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:128)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:980)
at de.company.rcp.datamodel.importer.wizard.ImportWizard.performFinish(ImportWizard.java:135)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:778)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:417)
at org.eclipse.jface.dialogs.Dialog.lambda$0(Dialog.java:619)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:81)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at de.company.rcp.datamodel.importer.handlers.ImporterHandler.execute(ImporterHandler.java:59)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:431)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:446)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:472)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at de.company.rcp.rcp.Application.start(Application.java:30)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content ist nicht zulässig in Prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at de.company.rcp.common.source.parser.Parser.parseInputStream(Parser.java:153)
... 76 more
Caused by: org.xml.sax.SAXParseExceptionpublicId: c:\Users\user\Desktop\de.company.rcp.rcp.product-win32.win32.x86_64\workspace\Library\tia_import\plcsoft\Main.awl; systemId: file:///c:/Users/user/Desktop/de.company.rcp.rcp.product-win32.win32.x86_64/workspace/Library/tia_import/plcsoft/Main.awl; lineNumber: 1; columnNumber: 1; Content ist nicht zulässig in Prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 79 more
FUDForum. Page generated in 0.06470 seconds
