Home » Modeling » TMF (Xtext) » generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13
generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781887] Wed, 14 February 2018 05:38 Go to next message
We've been facing an issue after updating from xtext 2.9.2 to xtext 2.13 and from Eclipse Luna to Eclipse Oxygen. The generated *ParsetreeConstructor files from our various grammars do not compile, because part of the .xtext input grammar ends up in it! Here's an excerpt of a generated ParsetreeConstructor:
/************ begin Rule EmbeddedSection ****************
 * /* opening and closing stratumId should match */ EmbeddedSection:
 * 	"*O" WS? stratumID=NON_ASTERISK_STRING CR
 * 	embeddedSmaps+=SMAP*
 * 	"*C" WS? closingStratumID=NON_ASTERISK_STRING CR;
Note how "EmbeddedSection" isn't in a comment. It comes from the corresponding part of the .xtext grammar:
EmbeddedSection:
It is related to the handling of comments, the disturbing part being "/* opening and closing stratumId should match */" in our grammar. If I remove it, generation works. I have several examples of the same kind (in the same grammar, and in other grammars too).
We are still using the old Generator class in our mwe2 files (org.eclipse.xtext.generator). I know it's not being maintained, but you know time flies and our grammars are 5 years old now :-)
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781888 is a reply to message #1781887] Wed, 14 February 2018 05:43 Go to previous messageGo to next message
so you dont use the old generator only but the old serializer too?
you could subclass and patch the fragment/xpt file
did you investigate where this is called. most places use
grammarFragmentToStr("// ", lineDelimiter)
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781890 is a reply to message #1781888] Wed, 14 February 2018 05:47 Go to previous messageGo to next message
p.S. could you provide a hello world project. createing a old style project by hand is pita
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781892 is a reply to message #1781890] Wed, 14 February 2018 06:08 Go to previous messageGo to next message
Maybe you could change your comment style in the grammar?
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781895 is a reply to message #1781892] Wed, 14 February 2018 06:18 Go to previous messageGo to next message
@ChristianDietrich> Yes we use the old serializer too (org.eclipse.xtext.generator.parseTreeConstructor.ParseTreeConstructorFragment). What do you mean by "investigate where this is called" ? I'm sorry I'm not the xtext guy in the company and don't really know which code is called by mwe2. I'll look into providing a simple example, it seems feasible.
@KarstenThoms> changing the comments to // indeed avoids the problem
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781897 is a reply to message #1781895] Wed, 14 February 2018 06:40 Go to previous messageGo to next message
Here's an example project to reproduce the problem: http://dl.free.fr/jWNrj1Pjx
Reproduction procedure:
* Unpack the archive
* Import the com.provenrun.smap project into Eclipse Oxygen 4.7.0 with Xtext 2.13 installed, it'll have errors; it's normal
* Right-click on src/com/provenrun/smap/SMAP.xtext > Run as MWE2 Workflow
* The generator will ask you to download http://download.itemis.com/antlr-generator-3.2.0-patch.jar, do it and then the generator should finish successfully
* Then witness that /com.provenrun.smap/src-gen/com/provenrun/smap/parseTreeConstruction/SMAPParsetreeConstructor.java has errors
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781901 is a reply to message #1781897] Wed, 14 February 2018 07:39 Go to previous messageGo to next message
you can try to patch like
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781905 is a reply to message #1781901] Wed, 14 February 2018 09:49 Go to previous messageGo to next message
Thanks Christian, but how exactly should I apply this patch (we're working against released versions of xtext, not the source) ?
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781906 is a reply to message #1781905] Wed, 14 February 2018 09:52 Go to previous messageGo to next message
i dont get your question:
import patch as project
add dependency from your project to patch project
exchange the current fragment with the patched one
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781910 is a reply to message #1781906] Wed, 14 February 2018 10:11 Go to previous messageGo to next message
I wasn't aware it was so easy to replace the fragment being used! I confirm it fixes the bug on all 3 grammars I tested, thank you very much; we can continue our update now.
And I've confirmed with the local xtext master that we'll update to the new generator soon :-) so hopefully we won't bother you again ☺
On a final note, I've tried to turn all multiline comments into single line comments (//) in our grammars, but there was one position where */ was used in a rule, which still triggered the bug:
ML_StandaloneSMDoc:
	{ML_StandaloneSMDoc}
	// first line
	body+=ML_StandaloneSMDocFirstLineBody
	// Intermediate lines
	(body+=NewLine //
	body+=ML_SMDocNextLineBody)* //
	// closing
	body+=NewLine?
	'*/';  // <- Here's the one
so it isn't a viable workaround after all.
[Updated on: Wed, 14 February 2018 10:13] by Moderator
Re: generated ParsetreeConstructor file doesn't compile after upgrade from xtext 2.9.2 to xtext 2.13 [message #1781911 is a reply to message #1781910] Wed, 14 February 2018 10:17 Go to previous message
yes the problem is your keyword.
Previous Topic:Trying to write a DSL with Xtext to specify an XML-like language
Next Topic:How to define a greedy version of Xtext until (->)?
Current Time: Thu Jul 24 23:28:15 EDT 2025
Powered by FUDForum. Page generated in 0.08836 seconds
