Home » Eclipse Projects » Kura » HTTPS for Kura Web UI?
HTTPS for Kura Web UI? [message #1779526] Tue, 09 January 2018 04:15 Go to next message
It's possible to open Kura Web UI in https?
thanks for help
Re: HTTPS for Kura Web UI? [message #1779555 is a reply to message #1779526] Tue, 09 January 2018 10:01 Go to previous messageGo to next message
I believe so. Probably you need to change some parameters in the web2 bundle and open the 443 port in the firewall.
Maybe do a search in this forum if anyone else had the same issue and reported their solution.
Matteo
Re: HTTPS for Kura Web UI? [message #1781561 is a reply to message #1779555] Thu, 08 February 2018 10:18 Go to previous messageGo to next message
Hi Matteo,
I found this link:
https://dev.eclipse.org/mhonarc/lists/kura-dev/msg00712.html
I'm working on Raspberry Pi (kura 3.1.1) and i've follow the link's instuction but i have this exceptions:
(kura-console.log)
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.jetty.internal.Activator.start() of bundle org.eclipse.equinox.http.jetty.
Caused by: org.osgi.service.cm.ConfigurationException: default : no valid keystore
... 12 more
Caused by: java.lang.IllegalStateException: no valid keystore
... 17 more
Root exception:
Have you some ideas?
Any help is appreciated
Re: HTTPS for Kura Web UI? [message #1781604 is a reply to message #1781561] Fri, 09 February 2018 05:33 Go to previous messageGo to next message
I've personally never tried it. But, from the snippet provided it seems an issue with the Keystore you defined.
Matteo
Re: HTTPS for Kura Web UI? [message #1785559 is a reply to message #1781604] Mon, 16 April 2018 12:16 Go to previous messageGo to next message
Hi Matteo,
Can you give me some news about this issue?
I'm still stuck on it!
Thanks in advance
Re: HTTPS for Kura Web UI? [message #1785560 is a reply to message #1785559] Mon, 16 April 2018 12:23 Go to previous message
currently there is no official support for https. It could be that those instructions are not anymore working with newest versions of Kura.
I would suggest to review the steps and maybe open an issue in the official GitHub repository reporting carefully the steps done and where you are stuck in order to give all the information needed to provide help or create a fix, if needed.
Matteo
Previous Topic:GPIO access not working for me.
Next Topic:Azure IoT hub Certificate Authority Connection
Current Time: Sun Jul 20 23:52:05 EDT 2025
Powered by FUDForum. Page generated in 0.06488 seconds
