Home » Modeling » TMF (Xtext) » Unit Test with cross-references to an external emf model
Unit Test with cross-references to an external emf model [message #1781440] Wed, 07 February 2018 06:09 Go to next message
Hi guys,
I have a similar setup to https://typefox.io/linking-xtext-models-with-other-emf-models. From my language it's possible to refer to elements of an instance of an external emf model.
Reference:
    'ref' ref=[ecore::EObject|ID]
This works well!
But I want to do some parsing test without the IDE now.
ref Element1
'''.parse.assertNotNull
So far I build the following class
class MydslWithDependenciesInjectorProvider extends MydslInjectorProvider {
	override internalCreateInjector() {
		ExternalModelStandaloneSetup.doSetup
		return super.internalCreateInjector
@RunWith(XtextRunner)
@InjectWith(MydslWithDependenciesInjectorProvider)
class ParsingTest {
And the StandaloneSetup of my external model looks like this
class ExternalModelStandaloneSetup implements ISetup {
	@Inject
	private FileExtensionProvider fileExtensionProvider;
	@Inject
	private IResourceServiceProvider resourceServiceProvider;
	@Inject
	private IResourceServiceProvider.Registry registry;
	override createInjectorAndDoEMFRegistration() {
		val injector = Guice.createInjector(new ExternalmodelRuntimeModule)
		injector.injectMembers(this)
		for(fileExt: fileExtensionProvider.fileExtensions)
			registry.extensionToFactoryMap.put(fileExt, resourceServiceProvider)
		// the following implicitly registers the EPackage to the registry
		val externalmodelPackage = ExternalmodelPackage.eINSTANCE
		return injector
	def static void doSetup() {
		new ExternalModelStandaloneSetup().createInjectorAndDoEMFRegistration()
But I have no idea how to continue. It would be very nice if someone can give me a small example.
Many thanks!!!
[Updated on: Wed, 07 February 2018 06:11] by Moderator
Re: Unit Test with cross-references to an external emf model [message #1781443 is a reply to message #1781440] Wed, 07 February 2018 06:38 Go to previous messageGo to next message
you need to "parse" all resources to the resourceset.
e.g. use one of the parse methods offering to pass a resourceset
and prepopulate it with your non text resources
Re: Unit Test with cross-references to an external emf model [message #1781460 is a reply to message #1781443] Wed, 07 February 2018 08:21 Go to previous messageGo to next message
Hi Christian,
first many thanks.
But currently I have the following problem in my test:
class ExpressionParsingTest {
	// Allows to obtain a new resource set
	@Inject Provider<XtextResourceSet> resourceSetProvider
	@Inject extension ParseHelper<mydslModel>
	@Test
	def void testExpression() {
        @Test
	def void testParsing() {
		val element = ExternalmodelFactory::eINSTANCE.createElement
                element.name = "element1";
		val resourceSet = resourceSetProvider.get
		val resource = resourceSet.createResource(URI.createURi("myExternalModel.externalmodel"))
		resource.contents.add(element)
 		val model = '''ref element1'''.parse(resourceSet)
 		model.assertNotNull
In this case
returns null
What did I miss in ExternalModelStandaloneSetup?
Re: Unit Test with cross-references to an external emf model [message #1781471 is a reply to message #1781460] Wed, 07 February 2018 10:51 Go to previous messageGo to next message
there do you register the epackage and factory for the external model?
Re: Unit Test with cross-references to an external emf model [message #1781472 is a reply to message #1781471] Wed, 07 February 2018 11:39 Go to previous messageGo to next message
For my external model I created an additional plugin as described under the following link
https://github.com/TypeFox/Xtext-XMI/blob/master/io.typefox.xtextxmi.tree.xtext/src/io/typefox/xtextxmi/tree/xtext/TreeStandaloneSetup.xtend
And this plugin has it's own StandaloneSetup that looks like this
	@Inject
	@Inject
	@Inject
		return injector
And currently I'm not sure how and where to register the factory and the package.
In the StandaloneSetup of the external Model or in the StandaloneSetup of the myDsl language.
Re: Unit Test with cross-references to an external emf model [message #1781473 is a reply to message #1781472] Wed, 07 February 2018 11:47 Go to previous messageGo to next message
no i mean something like in the setups e.g. as it is generated
@SuppressWarnings("all")
public class DomainmodelStandaloneSetupGenerated implements ISetup {
public Injector createInjectorAndDoEMFRegistration() {
XbaseStandaloneSetup.doSetup();
Injector injector = createInjector();
register(injector);
return injector;
public Injector createInjector() {
return Guice.createInjector(new DomainmodelRuntimeModule());
public void register(Injector injector) {
if (!EPackage.Registry.INSTANCE.containsKey("http://www.xtext.org/example/Domainmodel")) {
EPackage.Registry.INSTANCE.put("http://www.xtext.org/example/Domainmodel", DomainmodelPackage.eINSTANCE);
IResourceFactory resourceFactory = injector.getInstance(IResourceFactory.class);
IResourceServiceProvider serviceProvider = injector.getInstance(IResourceServiceProvider.class);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("dmodel", resourceFactory);
IResourceServiceProvider.Registry.INSTANCE.getExtensionToFactoryMap().put("dmodel", serviceProvider);
Re: Unit Test with cross-references to an external emf model [message #1781479 is a reply to message #1781473] Wed, 07 February 2018 12:31 Go to previous messageGo to next message
Hi Christian,
my external model is not generated by a second DSL. It's a separate EMF-Project.
class ExternalmodelStandaloneSetup implements ISetup {
	@Inject
	@Inject
	override Injector createInjectorAndDoEMFRegistration() {
		val Injector injector = createInjector();
		register(injector);
		return injector;
		new ExternalmodelStandaloneSetup().createInjectorAndDoEMFRegistration()
	def public Injector createInjector() {
		return Guice.createInjector(new ExternalmodelRuntimeModule());
	def public void register(Injector injector) {
		if (!EPackage.Registry.INSTANCE.containsKey("http://www.example.com/externmodel/Externmodel")) {
			EPackage.Registry.INSTANCE.put("http://www.example.com/externmodel/Externmodel", ExternmodelPackage.eINSTANCE);
/* At this point I get the exception: "com.google.inject.ConfigurationException: Guice configuration errors:
1) No implementation for org.eclipse.xtext.resource.IResourceFactory was bound.
  while locating org.eclipse.xtext.resource.IResourceFactory */
		val resourceFactory = injector.getInstance(IResourceFactory.class);
val  serviceProvider = injector.getInstance(IResourceServiceProvider.class);
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("externalmodel", resourceFactory);
		IResourceServiceProvider.Registry.INSTANCE.getExtensionToFactoryMap().put("externalmodel", serviceProvider);
In the line "val service Provider ..." I get the following exception (see in code comment)
1) So where do I have to bound the IResourceFactory?
2) And is the Standalonesetup for the externalmodel okay or did I mis something?
3) Is it right that I have to register the factory for the XtextResourceSet? Would it be also okay to register the externalmodel in the Standalonesetup of mydsl?
@All
If someone has a link to an example, then I would be very grateful. I searched for examples but found nothing, only examples for multiple DSLs with cross references like this one https://github.com/szarnekow/testing-multiple-dsls.
Many thanks and sorry for the newbie questions
[Updated on: Wed, 07 February 2018 12:58] by Moderator
Re: Unit Test with cross-references to an external emf model [message #1781489 is a reply to message #1781479] Wed, 07 February 2018 14:49 Go to previous messageGo to next message
arrrgggg
from terminal standalonesetup:
if (!Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().containsKey("ecore"))
"ecore", new EcoreResourceFactoryImpl());
if (!Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().containsKey("xmi"))
"xmi", new XMIResourceFactoryImpl());
if (!Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().containsKey("xtextbin"))
"xtextbin", new BinaryGrammarResourceFactoryImpl());
if (!EPackage.Registry.INSTANCE.containsKey(XtextPackage.eNS_URI))
EPackage.Registry.INSTANCE.put(XtextPackage.eNS_URI, XtextPackage.eINSTANCE);
Re: Unit Test with cross-references to an external emf model [message #1781490 is a reply to message #1781489] Wed, 07 February 2018 14:52 Go to previous messageGo to next message
and no simply regesiter your epackage and factory
Re: Unit Test with cross-references to an external emf model [message #1781491 is a reply to message #1781489] Wed, 07 February 2018 14:54 Go to previous messageGo to next message
Thanks Christian
Re: Unit Test with cross-references to an external emf model [message #1781511 is a reply to message #1781491] Thu, 08 February 2018 00:04 Go to previous messageGo to next message
P.s. did you reallly follow the example regarding the setup?
https://github.com/TypeFox/Xtext-XMI/blob/master/io.typefox.xtextxmi.tree.xtext/src/io/typefox/xtextxmi/tree/xtext/TreeRuntimeModule.xtend
https://github.com/eclipse/xtext-core/blob/master/org.eclipse.xtext/src/org/eclipse/xtext/resource/generic/AbstractGenericResourceRuntimeModule.java
Re: Unit Test with cross-references to an external emf model [message #1781527 is a reply to message #1781511] Thu, 08 February 2018 03:49 Go to previous messageGo to next message
Yes I did.
The only difference is that in the example it's possible to define elements of nodes in the DSL and in the external model. In my case it's possible to define some kinds of elements, like nodes, only in the external model and to refer these elements from the dsl.
Re: Unit Test with cross-references to an external emf model [message #1781529 is a reply to message #1781527] Thu, 08 February 2018 03:55 Go to previous messageGo to next message
Wait !!!!!!! Maybe .... I ..... fu**! I will check something. Maybe I did a stupid mistake
[Updated on: Thu, 08 February 2018 03:56] by Moderator
Re: Unit Test with cross-references to an external emf model [message #1781530 is a reply to message #1781527] Thu, 08 February 2018 03:56 Go to previous messageGo to next message
the point is:
your external stuff provides a IResourceSerivce provider for your external metamodel and files. this resourceserviceprovider enables you do refer to this elements from any xtext dsl.
if you want to make sure that this works standalone the code has to ensure
- epackage and resource factory are registered
- the resourceserviceprovider is registered.
both should be done from the standalonesetup you provider
you then can call the standalonesetup from your dsls standalonesetup and or injector provider
Re: Unit Test with cross-references to an external emf model [message #1781533 is a reply to message #1781530] Thu, 08 February 2018 04:20 Go to previous messageGo to next message
Okay no mistake so far ... most likely:)
Respect to the example of https://github.com/TypeFox/Xtext-XMI "both should be done from the standalonesetup you provider" means:
In the TreeStandalonesetup I have to
1) register the Epackage and create a ResourceFactory for the treemodel and register it
2) register the resource service provider
In the tests package of mydsl create a class
		TreeStandaloneSetup.doSetup
and call it in the unit test class/es with:
Hope understand you correct...
And many many thanks. I'm really happy about so much help!! You and the other guys do a really greate job !!!
[Updated on: Thu, 08 February 2018 04:34] by Moderator
Re: Unit Test with cross-references to an external emf model [message #1781534 is a reply to message #1781533] Thu, 08 February 2018 04:29 Go to previous messageGo to next message
yes that is what i meant
Re: Unit Test with cross-references to an external emf model [message #1781538 is a reply to message #1781534] Thu, 08 February 2018 05:15 Go to previous message
Thanks!!!! It works!!!!!
That's one small step for mankind, one giant leap for me :D
Have a nice day!
Previous Topic:Solving Maven dependency between two Xtext projects for production
Next Topic:Build xtext with maven
Current Time: Wed Sep 17 12:53:47 EDT 2025
Powered by FUDForum. Page generated in 0.07346 seconds
