Home » Eclipse Projects » Eclipse Scout » [Neon] Scout Thread management in a Java EE container
[Neon] Scout Thread management in a Java EE container [message #1781263] Mon, 05 February 2018 04:11 Go to next message
Hi everyone
Currently I try to understand how Scout creates Threads when running in a Java EE container (Websphere).
In the monitoring system, I see that for every user there are two Websphere threads (one for the frontend and one for the backend I assume).
Now if I create custom Threads via Jobs.schedule(...), I see no additional Webspere threads.
Does this mean that these threads run outside of the Websphere container?
In the Technical Guide, I found this: https://eclipsescout.github.io/6.1/technical-guide.html#extending-job-manager about Java EE threads.
Does that mean if I want Scout to always create Webspere threads, I have to implement my own JobManager?
Many thanks
Adrian
Re: [Neon] Scout Thread management in a Java EE container [message #1781264 is a reply to message #1781263] Mon, 05 February 2018 04:34 Go to previous messageGo to next message
Hi Adrian
Scout uses its own thread pool based on a Java ThreadPoolExecutor.
See
org.eclipse.scout.rt.platform.job.internal.JobManager.createExecutor()
This is because Scout does not require a full Java EE container but just a servlet container to run.
If you want to use the WebSphere thread pool instead you have to replace the default job manager as explained in the documentation, yes.
The most interesting methods here are createExecutor() and submit().
Hope this helps
Matthias
Re: [Neon] Scout Thread management in a Java EE container [message #1781352 is a reply to message #1781264] Tue, 06 February 2018 05:33 Go to previous messageGo to next message
Hi Matthias
Thanks for the quick reply.
So how many Threads does Scout create, without any custom Scheduled Jobs from the application code?
As I understand, there is a UI thread (per user?) and a Model thread (also per user?).
Is this correct and are there any additional threads running (e.g. Longpolling for Client Notifications, etc.).
I try to understand how many running threads I have to expect (per user) if we change all Scout-threads from the Java ThreadPoolExecuto to the WebSpere pool.
Adrian
Re: [Neon] Scout Thread management in a Java EE container [message #1781422 is a reply to message #1781352] Wed, 07 February 2018 03:33 Go to previous message
Hi Adrian
This is hard to say. It may be different on client and on server side. And the jobmanager uses a thread pool. So not for every user new own threads are created. A single thread may be re-used by various users as long as there are no parallel requests. So it also depends on how many requests are processed at the same time.
The best way is to measure in a close-to-real-life scenario for your application.
Mat
Previous Topic:[7.0.300.001] [BUG] ListBox not working in Wizard
Next Topic:[Oxygen] Enabling/Disable Menus when Form is already open
Current Time: Sun Jul 20 20:28:33 EDT 2025
Powered by FUDForum. Page generated in 0.03240 seconds
