Home » Archived » Orion (Archived) » Emmet(Emmet wrap selection)
Emmet [message #1781355] Tue, 06 February 2018 06:15 Go to next message
I am new to Eclipse. Before I used Sublime text with emmet plugin. In Sublime I can select the sentence then hit Ctl+W to wrap the selection with a new abbreviation. How can I do with Eclipse ?
Example : if I select the word "Lorem" then hit ctl + w Sublime shows me the wrap abbreviation with the default "div tag". If I hit Enter key then I will get <div>Lorem</div>. I can define something else in the wrap abbreviation panel of course..
Thank.
Re: Emmet [message #1781646 is a reply to message #1781355] Sat, 10 February 2018 05:21 Go to previous message
Open Eclipse preferences - Keys - Go to down until you see:
Wrap with Abbreviation
Default keys are Shift+cmd+A. I changed to Shift + cmd + B to avoid conflict.
In the Editor type Lorem10 + tab key then select the sentence then hit shift+cmd+a. From the wrap with abbreviation window enter the tag you want to surround with (ex type div) + Enter.
Next time when you select a new sentence and hit shift+cmd+a use the down arrow key to select a previous recorded abbreviation tag or type a new one.
Nota: Emmet plugin must be installed prior to use it.
Hope will help someone.
[Updated on: Sat, 10 February 2018 05:22] by Moderator
Previous Topic:css content assist
Next Topic:Local Terminal
Current Time: Wed Jul 30 07:11:04 EDT 2025
Powered by FUDForum. Page generated in 0.03544 seconds
