Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » FBRT/UI/HMI in 1.9.0(What is the plan)
FBRT/UI/HMI in 1.9.0 [message #1781099] Thu, 01 February 2018 07:06 Go to next message
Can anyone tell me, or point me in the right direction, as to what is happening with the UI/HMI functionality that was provided by FBRT?
John
Re: FBRT/UI/HMI in 1.9.0 [message #1781332 is a reply to message #1781099] Tue, 06 February 2018 02:22 Go to previous messageGo to next message
we are still in the process of how we can provide non Eclipse Project content as part of an Eclipse project's release. As this will take some time and we do not want to further delay 1.9.0 we decided that in 1.9.0 this content will not be included. We hope that it will still again be there in hopefully even in an improved form in 1.10.0
However this does not mean that you can not use it in your projects. The FBRT support as 4diac functionality is the same as in previous 4diac versions. So you can open your old projects in 1.9.0 and use FBRT there. You can also copy the FBRT fbs and the FBRT (follwing the FBRT license agreement) from old projects into 1.9.0 and use it there.
I hope this clarifies the situation.
Alois
Re: FBRT/UI/HMI in 1.9.0 [message #1781335 is a reply to message #1781099] Tue, 06 February 2018 02:45 Go to previous messageGo to next message
I had some problems too that I reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=530178
is this the same issue you're having?
Re: FBRT/UI/HMI in 1.9.0 [message #1781336 is a reply to message #1781335] Tue, 06 February 2018 02:54 Go to previous messageGo to next message
Sorry for my last reponse. It wasn't the case. And actually the bug is not there anymore
Re: FBRT/UI/HMI in 1.9.0 [message #1781343 is a reply to message #1781332] Tue, 06 February 2018 04:23 Go to previous messageGo to next message
Hi Alois
Many thanks - I'll give this a go.
Kind regards
John
P.S. Excellent work - 4DIAC is exactly what I need!
Re: FBRT/UI/HMI in 1.9.0 [message #1781347 is a reply to message #1781343] Tue, 06 February 2018 05:04 Go to previous messageGo to next message
Thanks for your kind words. Great to hear that!
We are also experimenting with other HMI technologies (e.g., HTML5 connected via MQTT or OPC UA). Maybe this is even better suiting you.
Re: FBRT/UI/HMI in 1.9.0 [message #1782314 is a reply to message #1781347] Wed, 21 February 2018 11:21 Go to previous message
John Parker
If I can give you a suggestion, like FORTE implements OPC_UA you can use https://nodered.org/ with https://github.com/node-red/node-red-dashboard and https://www.npmjs.com/package/node-red-contrib-opcua.
With this tools you can create good HMIs.
Att.
Felipe
Previous Topic:Build Forte using libiec61850
Next Topic:IPv6
Current Time: Sat Nov 01 03:02:06 EDT 2025
Powered by FUDForum. Page generated in 0.06371 seconds
