Home » Eclipse Projects » Kura » How to write/add tabs in a configurable bundle
How to write/add tabs in a configurable bundle [message #1781317] Mon, 05 February 2018 19:01 Go to next message
Hey guys,
i need to write a conf bundle with tabs. How do i realize that ?
Please look into my attachment.
Same as in "Cloud Services" where the tabs are CloudService / Data Service / MqttData Transport.
Thanks in advance.
Greetings Amal
[Updated on: Mon, 05 February 2018 19:03] by Moderator
Re: How to write/add tabs in a configurable bundle [message #1781350 is a reply to message #1781317] Tue, 06 February 2018 05:25 Go to previous messageGo to next message
Hi, should that be fixed?
Or dynamically added to the UI?
For the first I would suggest changing the web2 bundle adding the sections you need.
Matteo
Re: How to write/add tabs in a configurable bundle [message #1781367 is a reply to message #1781350] Tue, 06 February 2018 08:21 Go to previous messageGo to next message
Hi Matteo,
The first 3 tabs in my bundle should be fix
And there should be the the option on button click to add dynamically more.
change the web?? Is there any example to adding tabs to a bundle.
I just know AD for adding field/options/combo etc...
Thanks.
Greetings Amal
[Updated on: Tue, 06 February 2018 08:23] by Moderator
Re: How to write/add tabs in a configurable bundle [message #1781392 is a reply to message #1781367] Tue, 06 February 2018 11:48 Go to previous message
I believe you should start working on this bundle: https://github.com/eclipse/kura/tree/develop/kura/org.eclipse.kura.web2
Matteo
Previous Topic:Need help to connect broker to kura and receive data into h2db
Next Topic:Error write with modbus_driver
Current Time: Thu Jul 24 02:42:23 EDT 2025
Powered by FUDForum. Page generated in 0.05411 seconds
