Home » Language IDEs » C / C++ IDE (CDT) » Opening the "Preprocessor Include Paths, Macro's etc" settings dialog causes crash(Just opening and sitting at the "Preprocessor Include Paths, Macro's etc" dialog crashes Eclipse)
Opening the "Preprocessor Include Paths, Macro's etc" settings dialog causes crash [message #1781023] Wed, 31 January 2018 11:07 Go to next message
For reference, a screenshot of the dialog in question is attached.
For my project, just opening and sitting at the "Preprocessor Include Paths, Macro's etc" dialog causes eclipse to eventually crash with no error message and no messages added to the log on crash.
What is happening is the "Setting Entries" window is continuously expanding to the right. You can see this when you hover over the frame in the behavior of the slider. It continuous expands its width until eclipse simply disappears without any additional log or console message.
EDIT: If it matters I'm on:
Ubuntu 16.04
Oxygen from December with the latest updates applied.
[Updated on: Wed, 31 January 2018 13:16] by Moderator
Re: Opening the "Preprocessor Include Paths, Macro's etc" settings dialog causes crash [message #1781101 is a reply to message #1781023] Thu, 01 February 2018 07:34 Go to previous messageGo to next message
Did you have any success on this issue? I am asking because I have the same experience with Eclipse Oxygen2, but when I run it in Oxygen version from June 2017, it works correctly...Thanks
[Updated on: Tue, 06 February 2018 10:58] by Moderator
Re: Opening the "Preprocessor Include Paths, Macro's etc" settings dialog causes crash [message #1781385 is a reply to message #1781101] Tue, 06 February 2018 11:07 Go to previous messageGo to next message
Hi again.
Found this bug at https://bugs.eclipse.org/bugs/show_bug.cgi?id=529433
It is not very comfortable solution, but it works somehow for me:
Workaround: select the "Providers" tab in the right pane and the navigation pane selection takes effect.
Re: Opening the "Preprocessor Include Paths, Macro's etc" settings dialog causes crash [message #1782429 is a reply to message #1781385] Fri, 23 February 2018 04:21 Go to previous message
And one more news, if you install CDT version 9.4.2, the bug's gone
Previous Topic: STRICT_EXPECTED_CALL(mallocAndStrcpy_s(IGNORED_PTR_ARG, config)) .IgnoreArgument(1); #524
Next Topic:GNU ARM install problem
Current Time: Fri Jul 25 11:41:55 EDT 2025
Powered by FUDForum. Page generated in 0.05176 seconds
