Home » Eclipse Projects » WindowBuilder » Resize/Move Problems in Designer(Unable to move/resize objects in designer.)
Resize/Move Problems in Designer [message #1781074] Thu, 01 February 2018 03:20 Go to next message
Using WindowBuilder to try and make a simple Swing window with a button on it, I'm unable to move to resize said button in the designer.
The resize dots appear in the designer, and I can drag them which shows coordinates like it normally would, but when I release the mouse button, the buttons size remains unmodified.
Same thing happens when attempting to just move the button instead. I can place a new button anywhere I want in the designer, but I can't move it once I've placed it, though the UI otherwise responds appropriately.
I'm only attempting to use a button for a example. This seems to happen with all UI elements I've tried so far.
I'm using the Absolute layout. Code, gif showing example, and versions below;
Halp
  • Attachment: Test.gif
    (Size: 87.22KB, Downloaded 18332 times)
  • Attachment: S2lcC4X.png
    (Size: 92.30KB, Downloaded 17820 times)
Re: Resize/Move Problems in Designer [message #1781402 is a reply to message #1781074] Tue, 06 February 2018 14:08 Go to previous messageGo to next message
I'm only guessing, but it may be related to the layout. Have you tried using a different layout, i.e. not absolute layout? Another guess, it may be related to component orientation. Are you using right-to-left orientation, perhaps?
What happens if you change the bounds values in the property sheet?
Re: Resize/Move Problems in Designer [message #1781485 is a reply to message #1781402] Wed, 07 February 2018 13:46 Go to previous messageGo to next message
Avi Abrami wrote on Tue, 06 February 2018 19:08
Same thing happens with the other layouts I've tried so far. I can put objects down, but not move them.
As for the orientation, where is that? I'm not seeing it anywhere on the UI, unless I'm blind. So whatever the default is?
Changing the values manually seems to work, so I'll probably continue doing that if I can't find a way to use the mouse right.
Re: Resize/Move Problems in Designer [message #1781492 is a reply to message #1781074] Wed, 07 February 2018 15:17 Go to previous messageGo to next message
Press the Show Advanced Properties button.
Re: Resize/Move Problems in Designer [message #1781510 is a reply to message #1781492] Wed, 07 February 2018 22:08 Go to previous message
Avi Abrami wrote on Wed, 07 February 2018 20:17
Ah, okay. Thanks for your patience.
It was set to 'UNKNOWN' by default. I've attempted to change it to LEFT_TO_RIGHT, and RIGHT_TO_LEFT to no effect on the designer.
Below is the source again, in case anything changed, and a picture of the properties menu of the button. All values are set to default, besides coords/size and orientation, which I left at LEFT_TO_RIGHT.
Stuff
  • Attachment: btnprop.png
    (Size: 98.95KB, Downloaded 17510 times)
Previous Topic:WindowBuilder Mars 2 IDE for JAVA developpers
Next Topic:Error in Designer using Observable Collections
Current Time: Fri Jul 25 19:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.05110 seconds
