Home » Language IDEs » PHP Development Tools (PDT) » [RESOLVED] Eclipse Helios Crashes With Help > Help Contents
[RESOLVED] Eclipse Helios Crashes With Help > Help Contents [message #1781026] Wed, 31 January 2018 11:24 Go to next message
Resolved: I didn't have the latest version of Eclipse
Version: Helios Service Release 2
Build id: 20110218-0911
Redhat Enterprise Linux 6.9
java version "1.8.0_101"
Java(TM) SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
I downloaded the latest Eclipse Helios with the PDT preinstalled.
I pointed Eclipse to a new, blank directory called "workspace".
Whenever I click on Help > Help Contents Eclipse crashes.
As it crashes Eclipse creates an hs_err_pid*.log file. It is filled with a lot of raw data, not an error messages that would seem to point to what is wrong.
I would be grateful for any clues in resolving this.
[Updated on: Wed, 31 January 2018 12:06] by Moderator
Re: Eclipse Helios Crashes With Help > Help Contents [message #1781030 is a reply to message #1781026] Wed, 31 January 2018 11:34 Go to previous messageGo to next message
This is extremely old and unsupported Eclipse / PDT release, where did you find it?
Latest available here: http://eclipse.org/pdt/
Re: Eclipse Helios Crashes With Help > Help Contents [message #1781033 is a reply to message #1781030] Wed, 31 January 2018 11:50 Go to previous messageGo to next message
Dawid Pakula wrote on Wed, 31 January 2018 11:34
I Googled on "download Eclipse for php" and this URL was the first result:
https://www.eclipse.org/downloads/packages/eclipse-php-developers/heliossr2
I went there and clicked on the box in the lower left for Linux 64 bit.
I will try starting over with a download from your URL and post back.
[Updated on: Wed, 31 January 2018 11:51] by Moderator
Re: Eclipse Helios Crashes With Help > Help Contents [message #1781034 is a reply to message #1781033] Wed, 31 January 2018 11:52 Go to previous messageGo to next message
Even on this page latest release is Oxygen ;)
It supports PHP up to 7.1 (7.2 will be available soon).
Re: Eclipse Helios Crashes With Help > Help Contents [message #1781035 is a reply to message #1781034] Wed, 31 January 2018 12:01 Go to previous messageGo to next message
Dawid Pakula wrote on Wed, 31 January 2018 11:52
I didn't pick a version, I went directly to the button for Linux 64 bit in the lower left corner of the URL I quoted. I just assumed that would be the latest version.
Re: Eclipse Helios Crashes With Help > Help Contents [message #1781036 is a reply to message #1781030] Wed, 31 January 2018 12:03 Go to previous message
Okay, I started over with the latest version from the URL above.
It does not have that problem.
Thank You.
Previous Topic:bug, how to find the one i filed
Next Topic:[RESOLVED]What should I read? Getting started with PDT
Current Time: Thu Jul 17 19:49:05 EDT 2025
Powered by FUDForum. Page generated in 0.55698 seconds
