Home » Eclipse Projects » Kura » how to remove configuration data when uninstall bundle(how to remove configuration data when uninstall bundle)
how to remove configuration data when uninstall bundle [message #1780992] Wed, 31 January 2018 00:18 Go to next message
how to remove configuration data in snapshot xml
Re: how to remove configuration data when uninstall bundle [message #1781050 is a reply to message #1780992] Wed, 31 January 2018 15:08 Go to previous message
actually it's not simple since that the configuration service merges the previous configuration with the one applied from a new snapshot loaded, for example, from the web UI.
The best approach I can suggest is to download from the web ui the latest snapshot, clean the parts that you want to remove, stop kura and replace all the existing snapshots, replacing them with the cleaned snapshot. Then you can start Kura.
Matteo
Previous Topic:Permanent deployment of plugins to kura
Next Topic:Kura wires to subscribe data from extern broker
Current Time: Sun Jul 20 21:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
