Home » Eclipse Projects » WindowBuilder » WindowBuilder Design is Updown(Design is Updown)
WindowBuilder Design is Updown [message #1779438] Sun, 07 January 2018 20:26 Go to next message
I install Eclipse Oxygeon on Mac and also install WindowBuilder,but the design is updown.Why?
index.php/fa/31734/0/
Re: WindowBuilder Design is Updown [message #1779573 is a reply to message #1779438] Tue, 09 January 2018 13:10 Go to previous messageGo to next message
Hello
This is bug #526091 which is now fixed. I am still not sure about the marketplace, but you may try follow comment [1] to install the fixed version.
Hope that helps
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=526091#c10
Re: WindowBuilder Design is Updown [message #1780991 is a reply to message #1779438] Tue, 30 January 2018 23:02 Go to previous messageGo to next message
I am also having this issue. I see that it has been resolved, but I can't figure out how to install this fix. I am new to Eclipse, so not completely sure how to get this fix applied.
Re: WindowBuilder Design is Updown [message #1782026 is a reply to message #1780991] Fri, 16 February 2018 02:21 Go to previous messageGo to next message
Same issue with Bin Liu. How can I update last fixed to my eclipse
Re: WindowBuilder Design is Updown [message #1782880 is a reply to message #1782026] Fri, 02 March 2018 22:36 Go to previous messageGo to next message
First uninstall the Windows Builder plugin from the Installation Details window (Access it from the About )
After you uninstall, go through "Install New Software.." procedure and use that Jenkin link for the Location.
Hope this helps.
Re: WindowBuilder Design is Updown [message #1785435 is a reply to message #1782880] Fri, 13 April 2018 13:30 Go to previous messageGo to next message
I've uninstalled Window Builder but don't understand "use that jenkin link for the Location"
What link is that"
TIA
Re: WindowBuilder Design is Updown [message #1785436 is a reply to message #1782880] Fri, 13 April 2018 13:30 Go to previous message
What link is that"
TIA
Previous Topic:Invisible garbage chars in text input into Eclipse
Next Topic:Installing Window Builder
Current Time: Mon Oct 27 06:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.05348 seconds
