Home » Eclipse Projects » Paho » MQTT Embedded Client C doesn't support retransmissions(MQTT retransmissions)
MQTT Embedded Client C doesn't support retransmissions [message #1780686] Thu, 25 January 2018 12:36 Go to next message
inspecting the code, it seems that MQTT embedded client in C doesn't support message retransmission when QOS > 0, as requested by the specification (Section 4.1 paragraph QOS Level 1):
"If the client does not receive a PUBACK message (either within a time period
defined in the application, or if a failure is detected and the communications
session is restarted), the client may resend the PUBLISH message with the DUP flag set."
In fact, in function MQTTPublish, if the send fails, an error code is simply returned.
Am I wrong?
Is there a reason for this?
Re: MQTT Embedded Client C doesn't support retransmissions [message #1780866 is a reply to message #1780686] Mon, 29 January 2018 06:20 Go to previous messageGo to next message
Hello.
it looks like you are reading the MQTT 3.1 specification which is pre-OASIS standardisation. The current spec is 3.1.1: http://docs.oasis-open.org/mqtt/mqtt/v3.1.1/os/mqtt-v3.1.1-os.pdf, which does not mention packet retries while the TCP connection remains active. The only requirement is that any outstanding QoS 1 or 2 flows are retried on the re-establishment of a TCP connection.
From personal experience I can attest that retries during an active connection usually cause more trouble than any help. The most common situation for a delay in an ack is that something is overloaded, network or broker for instance, and retrying packets only exacerbates the problem! If the TCP connection has failed or is failing, then a retrying on reconnection is all you need.
Re: MQTT Embedded Client C doesn't support retransmissions [message #1780890 is a reply to message #1780866] Mon, 29 January 2018 10:58 Go to previous message
Thanks Ian,
I'll read the new specification.
The reason for my request is that I have only UDP available and I'm looking for a way to make communication reliable.
In particular, my physical interface is Narrowband IoT and current chipsets offers only UDP to exchage packets in the network.
Possibly, I would have to implement retransmisssion in the library and make sure that the server support QOS > 0 and retransmission.
Bye
Previous Topic:PAHO library in C
Next Topic:Paho MQTT
Current Time: Thu Sep 18 04:21:34 EDT 2025
Powered by FUDForum. Page generated in 0.26149 seconds
