Home » Language IDEs » PHP Development Tools (PDT) » Help! Cannot be solved to a type
Help! Cannot be solved to a type [message #1776929] Wed, 22 November 2017 15:28 Go to next message
I am a PHP noob here, and it's my first time using Eclipse PHP. I installed joomla and used xampp to host. Everthing works very well, I can create project base on the joomla folder and able to run the web application inside the Eclipse. However, the joomla I used is very fresh, I didn't touch anything. But eclipse shows a lot of errors....most of them like "Cannot be solved to a type". I am doing something wrong in building the project???
Thank you,
Fang
Re: Help! Cannot be solved to a type [message #1780699 is a reply to message #1776929] Thu, 25 January 2018 18:04 Go to previous messageGo to next message
Did you upgrade from lower v. PHP to a higher v. PHP?
Re: Help! Cannot be REsolved to a type [message #1815682 is a reply to message #1780699] Tue, 08 October 2019 07:23 Go to previous messageGo to next message
Check the Joomla! version. This appears to be a known problem from version 3.8 of Joomla! onwards.
Symptoms are many hundreds of Error messages in Eclipse of two forms:
  • "The import ******\******\****** cannot be resolved"
  • "****** cannot be resolved to a type"
For advice on how to address this problem see:
[Updated on: Tue, 08 October 2019 23:57] by Moderator
General guidance for debugging Joomla! in Eclipse [message #1815684 is a reply to message #1815682] Tue, 08 October 2019 07:34 Go to previous messageGo to next message
For general guidance also see here:
Configuring Eclipse for joomla development - Joomla! Documentation. (Dated June/August 2019.)
Webinar: Using Eclipse for Joomla! Development - Joomla! Documentation. (Dated April/June 2009.)
Joomla! framework classes migrated out of global namespace: unable to infer information about alias [message #1815722 is a reply to message #1815684] Wed, 09 October 2019 00:12 Go to previous message
There are problems running the file "stubGenerator.php" (version 3.9.2 RC, 2019-01-11) in Eclipse 2019-09 with PHP 7.3.5.
From the command line (outside Eclipse, using the PHP installed with my WAMP) calling "php stubGenerator.php" I get:
Fatal error: Class StubGenerator contains 2 abstract methods and must therefore be declared abstract or implement the remaining methods (Joomla\CMS\Application\CMSApplicationInterface::getName, Joomla\CMS\Application\CMSApplicationInterface::getMenu) in C:\wamp64\www\Joomla_4-0-0-a11\Build\stubGenerator.php on line 52
From Eclipse I got the same Error. I tried the two automated 'fixes' offered by Eclipse, but still couldn't get the file to run correctly.
The "stubGenerator.php" file is supposed to generate a file "stubs.php" in the root of the Joomla! installation (for example, "C:\wamp64\www\myJoom"). Tuan Pham Ngoc uploaded the appropriate "stubs.php" that was generated from an amended version of "stubGenerator.php" in September 2017. (This fixed a problem with the original "stubGenerator.php" creating class names with the wrong capitalisation.)
A further problem noted within the comments of the current "stubGenerator.php" file itself is:
Note that this file will raise some IDE errors as it will generate stub classes extending a final class (something not allowed in PHP). Therefore it is suggested that inspections on this file are disabled.
Errors shown for the 2017 "stubs.php" file in Eclipse include:
  • "The type ****** must implement the inherited abstract method ******::***()"
It is not clear to me how to disable "inspections" on an individual file (especially given that "stubs.php" is supposed to be placed in the Joomla! root directory, not its own subdirectory).
[Updated on: Wed, 09 October 2019 00:28] by Moderator
Previous Topic: I want to enable .php_cs.dist
Next Topic: Eclipse PDT IIS 7 and xdebug!!!!!
Current Time: Tue Sep 16 05:42:11 EDT 2025
Powered by FUDForum. Page generated in 0.03754 seconds
