Home » Eclipse Projects » WindowBuilder » WindowBuilder Offline Install
WindowBuilder Offline Install [message #1780492] Tue, 23 January 2018 06:00 Go to next message
Greetings,
  • I installed Eclipse Oxygen 2 Java IDE.
  • I downloaded file "repository.zip" from here.
The offline install did not work. (See attached file.)
Note that I launched Eclipse with the "-clean" option, i.e. eclipse.exe -clean
The other attached file shows the error I got.
The same procedure was successful for Eclipse Oxygen 1a last September.
At my work I can only perform an offline installation.
On my home computer I can perform an online installation and that was successful.
Has something changed between Eclipse Oxygen 1a and Eclipse Oxygen 2 ?
Has something changed between WindowBuilder 1.9.0 and WindowBuilder 1.9.1 ?
Avi.
Re: WindowBuilder Offline Install [message #1780600 is a reply to message #1780492] Wed, 24 January 2018 06:38 Go to previous message
Update:
In the end I simply copied my Eclipse installation from my home computer to my work computer.
Avi.
Previous Topic:WindowBuilder in Eclipse Java Neon/Oxygen
Next Topic:WindowBuilder 4.7 & java.beans.BeanInfo
Current Time: Mon Jul 21 03:35:50 EDT 2025
Powered by FUDForum. Page generated in 0.07221 seconds
