Home » Eclipse Projects » Eclipse Titan » Debug: Using the value of an optional field containing omit
Debug: Using the value of an optional field containing omit [message #1780159] Thu, 18 January 2018 04:36 Go to next message
Hello everyone,
At the beginning, happy new year and all the best! :)
It is possible that I (or someone else) have written this question already, but here it is:
How we are supposed to debug the DTE: Using the value of an optional field containing omit? If I only knew at least the name of the field it would have been a lot easier.
Thanks in advance.
Naum
Re: Debug: Using the value of an optional field containing omit [message #1780168 is a reply to message #1780159] Thu, 18 January 2018 05:24 Go to previous message
Hi Naum,
in general, reading the log file should lead you quickly to the desired answer.
Just to remind you , granularity of the log file can be finely tuned with config parameters
(see "ch 7.2 Logging" of the refguide)
For this it would probably be overkill, but Titan also has a built-in debug feature,
(refguide ch 11, The TTCN3 debugger )
If you could attach a concrete piece of code, maybe I could give you more specific hints.
Also, I hear you: your polite suggestion is that the debug message should be clearer.
Please bear in mind that we have to carefully weigh usage of our (scarce ) resources and as such, commodity features are
typically towards the bottom of my list, the top being occupied by features that have no replacement or workaround.
Best regards
Elemer
[Updated on: Thu, 18 January 2018 07:27] by Moderator
Previous Topic:Default Parameters in Template Bug ?
Next Topic:Some Titan project statistics
Current Time: Sat Jul 26 21:35:31 EDT 2025
Powered by FUDForum. Page generated in 0.03749 seconds
